Old Sep 18, 2011, 01:04 AM
tahoelight's Avatar
North Lake Tahoe
Joined Nov 2009
Boom Clamps for round tubing
I am hoping to go back to building with round tubing rather than the square aluminum I have been using. I am wondering if anyone has a good source for boom clamps for say 17mm-21mm tubing sizes. A recommendation anywhere in that size range would be helpful. I have a simple 2d drawing to have some cut from Delrin, but have not approached anyone yet about cutting them. Many of the frame manufacturers have some nice looking clamps, but I am not willing to pay $35 for one set of clamps. I need them for both motor side and frame side.
tahoelight is offline Find More Posts by tahoelight
Old Sep 18, 2011, 05:35 AM
A man with too many toys
United States
Joined Feb 2001
http://www.shop.aglhobbiesllc.com/Fr...ing-Block.html
RC Man is offline Find More Posts by RC Man
Old Sep 18, 2011, 09:18 AM
United States, FL, Melbourne
Joined Mar 2011
Rusty at aglhobbies is a great guy and has great customer service. Fully recommended!
Dbasileccim is offline Find More Posts by Dbasileccim
Old Sep 18, 2011, 09:33 AM
tahoelight's Avatar
North Lake Tahoe
Joined Nov 2009
Nice, that is perfect. Rusty used to only sell parts to frame order customers. This is great.
Old Sep 19, 2011, 05:58 PM
Joined Aug 2011
I have just had the same problem, but found these boom clamps which fit a 19.1mm tube, 3/4 inch if I remember correctly. They are small and lightweight, and also have a stop to prevent the tube sliding out the end...and only $5 for 4.
http://www.ronlund.com/rcheli-prod/MA127-19.html
Gunter is offline Find More Posts by Gunter
Old Sep 19, 2011, 08:17 PM
VA
Joined Nov 2009
And for those that wish to use Rusty 12mm blocks with 1/2" round alum tube. Assemble the bolts to a block half and then install two washers on each bolt. Slide the other half block on and install nuts and tighten. Drill out center hole with 31/64 drill bit. Disassemble block and now it will clamp 1/2" tube very tightly. Good if you need something a little tougher than kite tube or tail booms.
pug398 is offline Find More Posts by pug398
Old Feb 12, 2013, 07:53 AM
Joined Oct 2012
Please look at my proposition http://www.rcgroups.com/forums/showthread.php?t=1814310
Shop: http://www.pitlab.com/pitlabshop.htm...&category_id=7
Enjoy!
ArtFobia is offline Find More Posts by ArtFobia
Old Feb 12, 2013, 08:13 PM
Canada, NL, St John's
Joined Sep 2011
Its hard to come across 17 and 18mm boom clamps. I bookmarked it once upon a time, but I'm not on that computer right now. I'll try to dig it up later if thats the size your looking for.
Razzil is offline Find More Posts by Razzil
Old Feb 13, 2013, 10:13 AM
tahoelight's Avatar
North Lake Tahoe
Joined Nov 2009
I have been getting 25mm 22mm and 16mm from www.omgfly.com or www.goodluckbuy.com
Old Feb 14, 2013, 03:12 AM
Who's got the Tx ?
Boeing744's Avatar
United Kingdom, Whitchurch
Joined Jul 2010
16 mm and 21.5mm boom blocks here http://quadframe.com/collections/boo...s-motor-mounts also several other useful parts !
Boeing744 is offline Find More Posts by Boeing744
Old May 19, 2013, 12:20 PM
Copenhagen Denmark
Joined Jan 2011
booms/motormount
I believe sexycopter.com has some too......
Barsoe is offline Find More Posts by Barsoe
Old Apr 11, 2014, 04:01 AM
Joined Apr 2014
25mm aluminium clamp for Brushless Gimbals
Sunnylaw is offline Find More Posts by Sunnylaw
Old Apr 11, 2014, 04:07 AM
Joined Apr 2014
RC car parts
Provide more RC car parts/racing car parts
www.jiaxinmp.com
Old Jun 04, 2014, 05:13 AM
New Zealand, Auckland
Joined Jan 2012
I've got 20mm ABS with nylon clamps if you are still looking.
echo9alpha is offline Find More Posts by echo9alpha
Question Round boom mounting? themicahmachine Multirotor Talk 8 Jul 18, 2011 05:54 PM
For Sale Macs 12" 5/8" tuned pipe coupler tubing and Hatori clamps and pipe mount justplainold Aircraft - Fuel - Engines and Accessories (FS/W) 0 Aug 13, 2008 11:46 AM
Discussion Can an S9650 be mounted with these boom clamps? StarmanDXE Mini Helis 11 Oct 23, 2007 10:13 PM
Zoom Boom Servo Clamps mdttb Mini Helis 3 Nov 14, 2004 10:06 PM
Hornet 2 boom mount clamps HighFreq Micro Helis 11 Feb 15, 2004 02:09 AM
