Old Aug 09, 2009, 04:45 AM
Canada, ON, Toronto
Joined Jun 2009
Help!
70 - 80 inch wing span ep sport plane???
where can i get a sport or 3d plane that's around 70 - 80 inch wing span that's electric can any1 help please
fearlesshugo is offline Find More Posts by fearlesshugo
Old Aug 09, 2009, 04:52 AM
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
http://www.3dhobbyshop.com/
Murocflyer is online now Find More Posts by Murocflyer
Old Aug 09, 2009, 06:06 AM
Christchurch, New Zealand
Joined Jun 2006
http://www.hyperion-world.com/products/type/10
Scroll right down to the end.
Also, nearly anything in that size range can be converted to electric.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Aug 09, 2009, 06:25 AM
Murocflyer's Avatar
Joined Nov 2005
And a few more.
3D Hobby… www.3dhobbyshop.com/
Ace Hobby Distributors (Ace,TT)… www.acehobby.com/ace/index.htm
Aero Works… www.aero-works.net/store/
AirWild Hobbies… www.airwildhobbies.com/
AK Models… www.ak-models.com/
Carl Goldberg Products LTD… www.carlgoldbergproducts.com/
Carden Aircraft… www.carden-aircraft.com/
Cactus Aviation… www.cactusaviation.com/index.html
Cermark… www.cermark.com/
Chief Aircraft Inc…. www.chiefaircraft.com/
Composite-ARF RC… www.composite-arf.com.hk/
Dawg House RC… www.dawghouserc.net/index.html
Dietrich Performance Aircraft… www.dietrichaircraft.com/
East RC… www.eastrc.org/
Extreme Flight RC… www.extremeflightrc.com/
Fedon Aircraft… www.fedonaircraft.net/
Fliton… www.fliton.com/main/main.php
Glens Models… www.glensmodels.com/2005.htm
Golden Skies R/C Aircraft… www.goldenskiesrc.com/
Hobby People… www.hobbypeople.net/categories/glowairplanes.asp
JTEC Radiowave… www.jtecrc.com/index.htm
Kangke… www.kangkeusa.com/superkraft.htm
Knox Hobbies… www.knoxhobbies.com/shop/catalog/index.php
Krill Aircraft Kits… www.krill-model.com/eu/en/
Tower Hobbies (Multiple)… www.towerhobbies.com/
Maxford USA… www.maxfordusa.com/glowgasarfproducts.aspx
Netbox Hobby (CA Models)… www.netboxhobby.com/main.sc
NitroPlanes… www.nitroplanes.com/nitro.html
Ohio Model Products… www.ohiomodelplanes.com/
Pacific Aeromedel Inc…. www.pacaeromodel.com/
Peak Models… www.peakmodel.com/
Performance A/C Unlimited… www.flypau.com/
Pilot RC… www.pilot-rc.com/Index.aspx
Precision Aviation Designs… www.bobflies.com/
RC Guys… www.rcguys.com/
Richmond Models… www.richmondrc.com/frameset.htm
SIG Manufacturing… www.sigmfg.com/
Texas ARF Airplanes… www.texasrcplanes.com/
Troy Built Models… www.troybuiltmodels.com/
VQ Models… www.vqwarbirds.com/
Wholesale Planes (Multiple)… http://www.wholesaletrains.com/Airpl...&Item=giantarf
Wild Hare RC… www.wildharerc.com/
Frank
Old Aug 09, 2009, 11:18 AM
WARNING: May contain spam
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
^Just a few, eh?
Xpress.. is offline Find More Posts by Xpress..
Old Aug 09, 2009, 11:54 AM
Murocflyer's Avatar
Joined Nov 2005
Originally Posted by Xpress..
^Just a few, eh?
It's always good to give yourself options.
Frank
Old Aug 09, 2009, 12:01 PM
Xpress..'s Avatar
Joined Oct 2007
Yeah, true. Options are good..
FYI, Hobby People aircraft can sometimes be low quality, and a lot ofthem have additional info sheets that weren't added into the manual (based on past experience and local modelers)
Old Aug 09, 2009, 07:49 PM
Canada, ON, Toronto
Joined Jun 2009
Thanks alot guys exspeacially muroc that's alot of sites lol
Old Aug 09, 2009, 10:26 PM
Flutter-Bys are fun
Conehead's Avatar
United States, MI, Honor
Joined Dec 2005
Choices, choices,
15 and a half thousand posts. Now there is someone who knows just about every site to get an airplane. muroc is th expert!
If you can't find a plane in that list, there has to be at least 15 to 20 at least that will work.
Conehead
Orrin Eldred
Honor, MI.
Conehead is offline Find More Posts by Conehead
Latest blog entry: TRAMPS Air Show, 28-June 2014
Old Aug 09, 2009, 11:16 PM
Murocflyer's Avatar
Joined Nov 2005
Originally Posted by Conehead
Choices, choices,
Conehead
Orrin Eldred
Honor, MI.
Thanks Orrin. Blame it on my bad memory. I write it all down. If I write them down, I figure I might as well share them with others.
Always glad to help and thanks again for the kind words.
Frank
Old Aug 09, 2009, 11:23 PM
Deletedfor proving Nauga wrong
Joined Mar 2005
The main issue with setting up a 75 to 85 inch span 3D capable model wil be:
Cost of the electric power system.
You'll need a lot of power... that means a big motor, high voltage high current ESC and a fairly large, expensive battery.
to support the large battery you'll need a good charger and source of power. (field charging can be problematic...)
Fortunately if you want to keep your costs down there are some decent, relaively low cost motors, speed controls and batteries at Hobby City and othere on-line sources.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Aug 09, 2009, 11:56 PM
Xpress..'s Avatar
Joined Oct 2007
^For around $600 you can get a Castle Creations HV controller and a Hacker outrunner- for the price, doesn't seem too bad for such quality
Old Aug 10, 2009, 03:19 PM
Joined Mar 2005
I went with the Turnigy Sentilon and a huge Turnigy outrunner... 3 X 4S Zippy 5000 mah packs for 12S
I'm still assembling the aircraft.
The power system is RATED to swing a 22X12 appx 8000 rpm, which would make a DA-50 look a bit anemic...
We'll see what results I actually get. I plan on putting a 20X8 on the plane.
cost of the complete system (batteries, ESC and motor) less than $400... bringing cost in line with a low-mid range gasoline engine.
Old Aug 10, 2009, 03:42 PM
Flutter-Bys are fun
Conehead's Avatar
Joined Dec 2005
Frank,
I got a lot of bookmarks, but your list is about as extensive as any I have seen.
There are so many planes, some good, some not so, but everyone has many choices and the problem is, what do you want and how much do you want to spend.
Just typing that list Frank is a labor of love.
So many people on this form can help new people out and what is really neat, is that they do it willing and over and over.
Hats off to all of you "old timers" who take care of all of us who have only been at this a few years. Thanks a bunch!!
Conehead
Orrin Eldred
Honor, MI.
Build Log The "Big P-40 Build" 70.5 Inch Wing Span JAM Foamies (Scratchbuilt) 1223 Jul 22, 2013 12:16 PM
Video The "Big P-40 Build" 70.5 Inch Wing Span guapoman2000 Electric Plane Talk 1 Jan 31, 2009 10:20 PM
Wanted Looking for Large Electric Sail Plane with 70 to 80" Wing Span rhampton Aircraft - Sailplanes (FS/W) 16 Jan 22, 2009 09:11 PM
Discussion Need some help here with an 80 inch wing span Cub Vyceroy Scale Kit/Scratch Built 3 Jan 28, 2008 06:31 PM
Alert FS: Mystery Plane 80" wing span Looks like CAP ?? LOOK AT THE PICTURE harikay Aircraft - Fuel - Airplanes (FS/W) 6 Mar 14, 2005 12:20 AM
