Old Sep 11, 2001, 01:10 AM
Senior Member ??
ETKing's Avatar
Southern California, USA
Joined Sep 2001
Crystal swap didn't work
I swapped a 555 RX in for a Feather RX in my Zagi tonight. I swapped crystals in RXs so that I could continue to use the TX that I modified with dual rate elevator, but the 555 won't work with the crystal from the Feather. They look the same, but is there a difference? HELP!
ETKing is offline Find More Posts by ETKing
Old Sep 11, 2001, 01:21 AM
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
Dual or Single?
I know the 555 takes a dual conversion crystal. What's in the Feather? If it's a single, you've discovered the source of your problem.
Daren
Daren is offline Find More Posts by Daren
Old Sep 11, 2001, 01:24 AM
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Doesn't work. I think I read somewhere that the feather uses an AM crystal which I thought was strange tor an FM Rx. Why don't you ask "MIKE at Hitec" He has a thread running.
DavidN
DavidN is offline Find More Posts by DavidN
Old Sep 11, 2001, 03:05 AM
Yoe
Skellefteċ, Sweden
Joined Sep 2001
The feather reciever has single conversion while the 555 has dual conversion. The crystals are different for the different types of Hitec recievers.
Yoe is offline Find More Posts by Yoe
Old Sep 11, 2001, 07:05 AM
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
The problem is that the Feather is a single conversion (SC) Rx. The xtal is offset from the receive frequency by 455kHz. The 555 is dual conversion (DC) and the crystal offset is 10.7mHz.
There is no difference between an AM and an FM xtal that is related to the modulation scheme. There may be designe differences in the Rx's local oscillator that require a different "cut" to the crystal, but this has nothing to do with AM/FM. Usually, the difference between AM and FM crystals from the same manufacturer is that the AM Rx's are SC and the FM are DC, but both AM and FM could be either SC of DC - it's purely a marketing/feature/engineering trade off.
gnofliwr is offline Find More Posts by gnofliwr
Old Sep 11, 2001, 10:47 AM
Senior Member ??
ETKing's Avatar
Joined Sep 2001
Thanks for the input. Now I have read
http://www.torreypinesgulls.org/Radio%20Article.htm
I guess I shouldn't just go around changing stuff I don't understand!
Discussion Transmitter didn't include crystal... infinitum Radios 6 May 12, 2006 08:08 AM
USB Powered Cam: Didn't work??? eta Aerial Photography 5 Jan 22, 2003 04:03 PM
DOH! Didn't range check on new setup..... Steve McBride Electric Plane Talk 10 Jul 17, 2001 02:46 PM
Plastic battery holders from Radio Shack don't work!!!! atckirk Beginner Training Area (Aircraft-Electric) 3 Jun 07, 2001 02:49 AM
Simple 400 Pictures don't work......... ChrisD High Performance 15 May 29, 2001 10:00 AM
