Old Oct 12, 2012, 04:40 PM
toffa is offline
Find More Posts by toffa
Zombie flyer....
toffa's Avatar
United Kingdom, Huddersfield
Joined Mar 2010
Question
PZ SU26M new motor help?
Having just bought one of the older PZ Su26m's, I realise that it is quite underpowered for what it is designed for ( Even with the Nanotech 35-60c 160mah lipos). Whilst there is a wealth of information regarding brushless swap outs, I'd rather not go down this route (Money tight, use what I've got if I can),
To which end I'm just wondering if anyone has swapped out the stock motor for an ERC spitfire motor? ( similar size, but seems to push the larger plane with quite a bit more vigour! ) Any info or help would be appreciated!
Chris.
toffa is offline Find More Posts by toffa
Old Oct 12, 2012, 07:27 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Chris.
The ERC spitfire should have a 7mm motor. The Nine Eagles Spitfire uses a 8.5mm motor.
Your Local hobby shop should have a black belled "mustang" motor from a Mustang, T-28 or UM 4 site, corasair or a Sukhoi XP. All will work, after you swap the prop to one from a 4-site (EFL9051), T-28 or Champ. Kyosho 130X70mm props work good, too.... or swap on a GWS 5030 or 5043 prop (you'll need an adapter)
If you stick with 1S, a mustang motor will have more power than any cheap brushless motor anyway, so its best to stay brushed.
UNGN is offline Find More Posts by UNGN
Old Oct 13, 2012, 01:44 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
Mustang motor
mustang prop.
Or sx motor from rcbabbel and mustang prop.
airpower is offline Find More Posts by airpower
For Sale new pz 370 bl motor bethelflier8036 Aircraft - Electric - Power Systems (FS/W) 0 Sep 10, 2012 11:00 AM
For Sale new pz 370 bl motor bethelflier8036 Aircraft - Electric - Power Systems (FS/W) 0 Sep 02, 2012 07:58 AM
Sold PZ SUKHOI SU26m with XP Motor/gear/prop update LOWERED PRICE $39 scharlach Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Nov 18, 2010 09:02 PM
Discussion Which motor for the SU26m micro? Aber Micro Ready-to-Fly 7 Apr 09, 2010 07:39 PM
Discussion PZ Su26m vs Kyosho Edge 540 (4ch) airkoyote Micro Ready-to-Fly 7 Jul 23, 2009 04:59 PM
