Old Jul 30, 2008, 07:18 PM
starzak is offline
Find More Posts by starzak
Tye
Chacotoma, NM
Joined Jan 2004
Remote glow plug connector ?
Looking for a good glow plug connector to use together with on-board ignition, for a fully cowled in engine. Looking for the type that connects to the glow plug post reliably, and stays in place. Commercial, or home made I'm not fussy, as long as it's reliable, and stays in place.
What are you using ?
Thanks.
... zak
starzak is offline Find More Posts by starzak
Old Jul 30, 2008, 09:29 PM
Wayne V is offline
Find More Posts by Wayne V
Wayne V's Avatar
London, Ontario, Canada
Joined Jan 2006
I like these ones http://www.horizonhobby.com/Products...ProdID=HAN3025 they have a spring and you pull on the wire then put it on the plug and it locks on quite well.
Wayne V is offline Find More Posts by Wayne V
Old Jul 31, 2008, 12:02 AM
jetmech05 is online now
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
I am using an Expert on board glow it came with the connector described in the second post
jetmech05 is online now Find More Posts by jetmech05
Old Jul 31, 2008, 05:40 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
I use the metal insert from a 3Amp chock block connector with an insulating washer to connect to the plug stem, a solder loop to connect to the crankcase and a bulkhead mounting phono-socket to plug in to. Some reasonably thick wire to carry the current to connect it all up, insulate with some heat-shrink sleeve, job done for a fraction of the cost of a commercial remote glow kit.
Andy.
AndyOne is offline Find More Posts by AndyOne
Old Jul 31, 2008, 09:35 AM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
Solder a wire to a wheel collar and put it on the glow plug post with a cardboard washer between it and the plug body. Put the other wire under a motor mount bolt.
howell
gwinhh is offline Find More Posts by gwinhh
Old Jul 31, 2008, 11:45 AM
rwp is offline
rwp
Find More Posts by rwp
rwp
rwp
rwp's Avatar
Joined Nov 2003
Thanks.
... zak
Here is a good connector
http://www.hobbypeople.net/gallery/279953.asp
rwp is offline Find More Posts by rwp
Old Jul 31, 2008, 10:24 PM
Arceenut is offline
Find More Posts by Arceenut
Arceenut's Avatar
Canada, BC, Langley
Joined Nov 2007
Glo plug connector
I use a wheel collar with a wire silver soldered to it. The whole thing is then insulated with heat shrink.
Arceenut is offline Find More Posts by Arceenut
Old Aug 02, 2008, 05:11 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
http://www.sullivanproducts.com/Mode...sMainFrame.htm
Scroll down a ways and they have the Head Lock Remote and Extended Head Lock Remote connectors.
I use one my my heli.
Pinecone is offline Find More Posts by Pinecone
Discussion Remote glow plug hook-up IronKnees Fuel Plane Talk 3 Dec 22, 2005 07:07 AM
Remote glow plug pics edv2122 Motorcycles 5 Feb 06, 2005 12:56 PM
