Old Feb 17, 2005, 07:07 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Yippee!
GWS EDF55 will be 9% more thrust than Varsa55 at 130W!
http://www.rcgroups.com/forums/showthread.php?t=336095
I am very proude to inform you that GWS EDF55 will be 9% more thrust than Varsa55 at 130W! Varsa55 will get 280g but GWS EDF55 was measured with 305g under the same condition!
The France editor wrote this test report of EDF50, EDF55 and EDF64 in 5 pagesn with many datas on the France RC models' magazine.
The top end of GWS EDF55 can be up to 450g; GWS EDF64 can be up to 570g if you put a strong BL motor insteaed of original EM300H motor.
Did you ever tested GWS EDF units with BL motors and have test datas to be posted here?
GWS4CEO is offline Find More Posts by GWS4CEO
Old Feb 17, 2005, 07:35 PM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
can you tell us what motor/pack setups have been used to achieve the 450gm? I currently run a 280watt input on a hacker B2012L 3s lipo for about 522 grms (that is in a fully ducted setup)
dave morris is offline Find More Posts by dave morris
Old Feb 17, 2005, 07:58 PM
orlando fl
Joined Oct 2000
here is an early thrust test, used a 3s2p 2100 TP pack. Now it uses a 3s2p 1570 apogee about 3.5 oz lighter and runs stronger or a 3s 2600 polyquest pack (about the same as the old TP 3s2p power wise) but about 4.5 oz lighter
Old Feb 17, 2005, 08:54 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Your 522g measured on which EDF?
That's an article on a France magazine of 5 pages report about GWS EDF50, EDF55, and EDF64.
Need to find more detail in the contain, but I am in USA now. GWS staffs will bring back this magazine back to Taiwan on 18th. I will ask them to fax to GWS USA.
Old Feb 17, 2005, 09:29 PM
orlando fl
Joined Oct 2000
oh sorry about that, it was with the vasa 55. I have thought about trying the GWS 55 as a lower cost alternative, but was unsure about how much power it could safely absorb.
I am a big fan of the EDF40, when powered with one of the new BL 12mm motors it is very impressive.
I also like the heat sinks for the 280 and 300 motors. It would be nice to have an extrusion based heat sink that would fit a 20mm motor, just what is needed when exceeding 200 watts with the current 20mm BL motors
Old Feb 17, 2005, 09:38 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Hello Mr. Lin
My own tests show that the fans are very similar in performance, with the Vasa55 having a 2-3% advantage over the EDF55 with the same motor.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Feb 17, 2005, 09:50 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Like Dave said, the EDF40 is a lot of fun with the Feigao brushless 12mm motor. Plenty of thrust and speed in a ducted install.
Eric B.
AirX is offline Find More Posts by AirX
Old Feb 17, 2005, 10:12 PM
Jackspt28 is online now
Find More Posts by Jackspt28
Levittown,PA
Joined Jan 2003
Airx, what Feigoa 12mm motor do you use in the edf40 fan and how many lipoly cells,Thanks Jack
Jackspt28 is online now Find More Posts by Jackspt28
Old Feb 18, 2005, 12:08 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
I have both the 5300 and the 5800kv motors, both work well on 3s, the 5800 will produce more thrust if the battery can hold its voltage. The 5300 is not as hard on the battery. For EDF and these small motors I only use 3s, the 5800 will need a heatsink though and the GWS 12mm heatsink will work until something more appropriate comes along.
Eric B.
Old Mar 04, 2005, 04:52 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Here is the test datas about GWS EDF units.
Wish this will do some help.
Old Mar 04, 2005, 04:54 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
France RC mag: Passion' Ailes, Jan. 2005.
See the detail article reported on France RC mag: Passion' Ailes, Jan. 2005.
Old Mar 06, 2005, 03:22 AM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
I tried inlet vanes on the stock GWS 55 with the 150 motor on 9,6 volt
in the model i do have 200 gr. of thrust. with the vanes.. and that is 50 gr more than before.
Next logic step to me will be this tranformation to fan and motor integrated somthing like this
Claus
clausxpf is offline Find More Posts by clausxpf
Old Mar 06, 2005, 06:39 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Great ideal!
Claus
Thanks Claus.
Old Mar 06, 2005, 06:49 PM
rcguy01 is offline
Find More Posts by rcguy01
Permanently Banned
Joined Apr 2003
Mr Lin;
Could you please stop joking around
But I have to consider that 130 watts is the sweet spot
for EDF 55, not at the higher wattage, 130+ watts, where the
other fans like vasa, Wemotec, kyosho really shine
rcguy01 is offline Find More Posts by rcguy01
Old Mar 06, 2005, 07:30 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
take it eazy...
Looking at the wemotec fan and looking at the gws fan... they are different yes... but so are the price..but if you look at the skills put into the fan production ... gws is the winner. It is not constructed for 1 KW. but a deasent produc for the money, and sure the way into fans.... for a lot of people.
Claus
Yippee! GWS EDF55 will be 9% more thrust than Varsa55 at 130W! GWS4CEO GWS (Grand Wing Servo) 497 Aug 04, 2009 02:50 AM
Discussion After Jan. 2005, there will be no more GWS Dragonfly with EM300 in GWS new production GWS4CEO GWS (Grand Wing Servo) 89 Sep 05, 2005 10:12 PM
Discussion After Jan. 2005, there will be no more GWS Dragonfly with EM300 in GWS new production GWS4CEO GWS (Grand Wing Servo) 37 Jul 05, 2005 08:28 PM
Discussion After Jan. 2005, there will be no more GWS Dragonfly with EM300 in GWS new production GWS4CEO Micro Helis 0 Dec 28, 2004 11:36 AM
GWS 10 x 4.7 prop gives more thrust than APC Red Baron 47 Power Systems 3 Sep 30, 2001 09:24 AM
