Old Jun 01, 2015, 09:13 PM
rodney00 is offline
Find More Posts by rodney00
rodney00's Avatar
United States, GA, Butler
Joined Mar 2014
First Gas Plane
Hello guys, need some advise on which way I need to set up my first gas plane. I acquired a Pilot RC 26% Extra 260 and mounted a AGM30 Gas engine.
First question: What size prop would be the best for this plane? The manual says use a 18x6, 18x10, 19x8 or 20x8
2nd: If I get aluminum servo arms for it what size would I need 1", 1 1/4" ?
3rd: Batteries what do I need to use for the receiver and what do I need to use for the ignition Type and voltage? Thanks for the help
rodney00 is offline Find More Posts by rodney00
Old Jun 05, 2015, 12:27 PM
exf3bguy is offline
Find More Posts by exf3bguy
exf3bguy's Avatar
United States, CA, Sacramento
Joined Oct 2011
Rodney, welcome to gas. For a prop I would take a look at a 18x8 Xoar or Wood Falcon. Unless you plan to do 3D 1" servo arms will be plenty long. Choose servos wisely, not all center well and this type of airplane needs quality servos. On an airplane this size a 2000 mah LiFe RX battery will work just fine and you can run the ignition off the same battery Via IBEC. I use the Tech Aero IBEC so I have the ability to shut the ignition down via the TX.
exf3bguy is offline Find More Posts by exf3bguy
Question What's a good first gas plane? RCmaster823 Fuel Plane Talk 81 Aug 26, 2015 11:44 AM
Question What's a good first gas plane? RCmaster823 Fuel Plane Talk 30 May 10, 2015 09:30 AM
Discussion What do I look for in first gas plane? weedsnager Beginner Training Area (Fuel) 11 Apr 22, 2015 04:30 AM
Help! First big plane... first gas motor.. now what? 9sec240 Fuel Plane Talk 4 Jan 09, 2012 11:12 PM
