Old Mar 25, 2013, 03:22 PM
cumulus 1 is offline
Find More Posts by cumulus 1
Valparaiso, Chile
Joined May 2004
GWRD-8Rx
.................does anybody know why my Futaba FP T6VA FM radio,with TP 3S 2070 mah,and my Electrifly SS-35 Brushless ESC Silver Series doesnīt work,itīs plugged in channel 3 in my GWRD-8 Receiver(GWS)Micro Type FM Ultra Narrow Band.
It just beeps every one second and it doesnīt stop.Iwant to program my Electrifly ESC with brake.
Iīve tried ESC connector plugged in all channels,and itīs the same,it doesnīt stop beeping every one second.
I really appreciate any help.
Carlos
cumulus 1 is offline Find More Posts by cumulus 1
Old Mar 28, 2013, 10:47 AM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
If so, I'd like to suggest checking all plugs between the ESC and the motor, as one of the 3 leads might have not been soldered firmly in its connector, the male one or the female one. If all of them have been soldered well enough, and the beeps still bother you, now you have to check the leads of the motor to see if they are with the same ohm by using a multimeter, I also doubt that the threads inside of any one of the 3 leads might have been broken, as the leads' tubes look OK, but the threads inside are broken already. Probably the leads have been bent too much before.
twn Chen is offline Find More Posts by twn Chen
Sold Fatshark Dominators w 5.8rx + headtracker j5cub FPV Equipment (FS/W) 2 Oct 27, 2012 06:59 PM
For Sale GWS GWRD-8 receiver darkside212 Aircraft - General - Radio Equipment (FS/W) 0 Aug 25, 2007 03:53 PM
Sold GWS receiver 8 channel shift select GWRD 8 lower price dumbthumbs Aircraft - General - Radio Equipment (FS/W) 2 Dec 02, 2006 02:50 PM
Discussion problems with GWS GWRD-8 receiver diego84 GWS (Grand Wing Servo) 4 Mar 06, 2006 04:32 PM
Discussion problems with GWS GWRD-8 receiver diego84 Radios 0 Mar 05, 2006 09:39 PM
