Old Jan 22, 2013, 06:05 PM
IloveFLIGHT! is offline
Find More Posts by IloveFLIGHT!
Michigan
Joined Aug 2004
Test
I just spun up a http://www.hobbyking.com/hobbyking/s...dProduct=14742 . I got 39 amps with a Flightmax 2200 20C 3S spinning a GWS HD 3 blade 10x6 at 9600 rpm peak. It settled down to about 340 watts after about 8 seconds. After about 20 seconds the wattage started to climb so I would put its max wattage somewhere below 350? I think its a great motor for the price!
IloveFLIGHT! is offline Find More Posts by IloveFLIGHT!
Old Jan 22, 2013, 06:18 PM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
Yea. Most of those bell motors aren't the most efficient; but cheap was cheap can get and WILL fly your plane just fine. Good enough for the average Joe flyer.
rcalldaylong is offline Find More Posts by rcalldaylong
Old Jan 22, 2013, 07:41 PM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
For the power to start rising after some time under load sounds wrong. I believe Kv rises as magnets get hot and start to demag, so this might be what you are seeing. It's a vicous circle - as the magnets weaken Kv goes up so the load with the same prop and pack goes up, so the motor gets hotter...
scirocco is offline Find More Posts by scirocco
Old Jan 22, 2013, 08:46 PM
Michigan
Joined Aug 2004
I noticed after the run that the battery was a bit warm. I would say 120F? Maybe that was the reason for the 10 watt increase?
Old Jan 22, 2013, 08:48 PM
Michigan
Joined Aug 2004
Either way, I would not put the 10x6 3 blade out of the good props for this motor!
Old Jan 22, 2013, 09:28 PM
scirocco is offline
scirocco's Avatar
Joined Feb 2001
Could well be. Forgot it's kinda cold where you are. LiPos don't like cold.
Old Jan 23, 2013, 05:42 PM
Michigan
Joined Aug 2004
Ok I saw 360 watts with a GWS HD10x6 2 blade at 10,600 rpm. I tried a 10x8 and saw 430+ watts so I immediately stopped without taching. Dr Kiwi, where are you? This is where you are the king!
Old Jan 23, 2013, 07:50 PM
Joined Dec 2007
The good doc isn't needed.
For these cheap motors, here's how I test:
put prop on, rev for 5 sec increments. If it doesn't get hot and has enough thrust, I throw it in the air and go fly. End of story.
Old Jan 23, 2013, 07:56 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Rule of thumb would suggest about 250W max.. but, heck, it's a cheap motor.. enjoy it while it lasts..my suspicion is that it will cook before too long at that level...but maybe it will surprise us all. I checked 10x6 HD at 10500rpm and 350W.. would you believe that those figures exactly matched what I got when I tested a Mega 600/20/6!
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 23, 2013, 09:01 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
A buyer posted some testing and thrust data on the motor on the HK page for the motor, that can be seen here:
http://www.hobbyking.com/hobbyking/s...X652823X45.txt
Test results
Turnigy L3010C-1300kv (420w)
H-KING 50A Fixed Wing ESC10 X 6 Windsor Propeller S2 Series Master Air Screw Sabre Shaped blades
Turnigy 3C 2200mAh discharge 20C
Thrust results
1632 Grams, 415 Watts, 37.6 Amps Grams/Watts 3.93
1490 Grams, 356 Watts, 31.5 Amps Grams/Watts 4.18
1231 Grams, 264 Watts, 23.1 Amps Grams/Watts 4.66
1071 Grams, 214 Watts, 18.2 Amps Grams/Watts 5.00
750 Grams, 139 Watts, 11.6 Amps Grams/Watts 5.39
He said it was just getting a wee bit warm on the full load tests. This is bell type motor but it is a newer one. Not sure who made it but it looks to have something in common with a similar TurBORIX motor so they might be the maker maybe.
Looks like you can rely on it for an honest 4-5 Watts per gram peak rating.
jackerbes is offline Find More Posts by jackerbes
Old Jan 24, 2013, 01:46 PM
Michigan
Joined Aug 2004
Anybody play with winds on this one? There seems to be plenty of room left for copper. Some of you guys kill me with how much wire you can pack in there!
Old Jan 24, 2013, 08:06 PM
Jack
USA, ME, Ellsworth
Joined May 2008
It had been mentioned here and there, at least once on the DT750 thread, but I don't think I remember anyone doing a rewind on it yet. I'd expect it to be as rewindable as those are. And the results could be just as rewarding.
Jack
Discussion How can I test the server DELL A930P-00 eletmoraes Batteries and Chargers 15 Sep 21, 2015 09:22 AM
Discussion Motor heating up to 80+ deg C during no load tests Nereth Electric Motor Design and Construction 10 Jan 17, 2013 06:52 AM
Discussion photo test Jim T. Graham Test Forum 0 Jan 16, 2013 12:44 PM
Sold Go Pro Hero2 motorsports package (tested once) with NIP FPV Manuals "Layer Lens" phoneguy FPV Equipment (FS/W) 5 Jan 15, 2013 09:32 PM
Discussion Testing..testing askmi Test Forum 0 Jan 10, 2013 03:13 AM
