Old Nov 06, 2012, 09:12 AM
Halford is offline
Find More Posts by Halford
Belgium, Brussels
Joined Jul 2010
pcb covering
Hi everyone,
I've started doing my own pcb lately and enjoy it a lot.
I learned from the internet and do them with a laser printer, transparent sheet, iron to transfer the schematic and acid to dissolve.
but what do you put over it once you have done all that to protect the circuit? mine are naked and a drop of water or a finger can create an issue... is there a liquid cover to protect the pcb?
thank you for any tip.
Hal
Halford is offline Find More Posts by Halford
Old Nov 06, 2012, 09:28 AM
RealGambler is online now
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
You can coat it relatively easily. Do a search on google for PCB silver plating.
RealGambler is online now Find More Posts by RealGambler
Old Nov 06, 2012, 11:58 AM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
immerse tin plating crystals not very cheap at all. In US they got something cheaper and name escapes me no matter no shipping overseas. I use thin coat of spay paint. Needs to be very thin when thick soldering burns it quite badly.
or if your setup with UV light http://www.aliexpress.com/item/UV-So...542613164.html
SadSack is offline Find More Posts by SadSack
Old Nov 07, 2012, 04:39 AM
Halford is offline
Belgium, Brussels
Joined Jul 2010
thanks a lot for the tips and directions, I really appreciate it.
Hal.
Old Nov 07, 2012, 05:30 AM
Julez is online now
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Conrad Electronic carries a spray called "Plastic 70".
It smells horrible, but covers PCBs nicely and does not cause problems when resoldering is required.
But clear spray paint works well also.
Julez is online now Find More Posts by Julez
For Sale It turns out that the 53 had a plain rocker cover and the 63 had a black rocker cover rpwarehime Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 01, 2012 10:54 PM
Discussion servoless retract pcb module houstonderk Flight Accessories 0 Feb 26, 2012 11:49 PM
Discussion Designspark PCB - Free PCB design tool CrashingDutchman DIY Electronics 1 Aug 26, 2010 06:03 AM
Discussion Exposed camera pcb, cover or not? vic20owner FPV Talk 18 Jan 02, 2010 05:08 PM
Discussion Convert PCB for a 2CH heli to a plane type PCB,,,mixing disabled !!! khaled_abobakr Scratchbuilt Indoor and Micro Models 9 Nov 17, 2009 12:25 AM
