Old Oct 02, 2012, 12:58 AM
highnpressurized is offline
Find More Posts by highnpressurized
Joined Jan 2007
Favorite Plans Covering Material?
So I built my first model on a glass table top with the plans underneath. It was a micro so if anything stuck it was pretty easy to remove with a razor blade. Building a larger model now (Stevens Aero, no pinning necessary) and its not so easy. I've seen a few options in a few threads, just thought I'd try to consolidate some answers. What non stick material do you like to cover your plans in.
highnpressurized is offline Find More Posts by highnpressurized
Old Oct 02, 2012, 02:16 AM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
waxed paper
rick.benjamin is offline Find More Posts by rick.benjamin
Old Oct 02, 2012, 03:10 AM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
It depends, but usually wax paper or saran wrap (glad wrap here in australia)
Curare is offline Find More Posts by Curare
Old Oct 02, 2012, 09:10 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Have them laminated at an office supply store like Staples.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Oct 02, 2012, 10:53 AM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
United States, AK, Anchorage
Joined Jan 2010
Parchment paper. The kind used for baking.
Compared to waxed paper it's a little more expensive and a little harder to see through but it already has a coating of silicone on it.
-Mike
Stone1295 is offline Find More Posts by Stone1295
Old Oct 02, 2012, 12:11 PM
earlcbrown is offline
Find More Posts by earlcbrown
United States, CA, Stockton
Joined Jan 2006
I use the backing off MonoKote, when ever I start a new covering job I save this backing rather than throw it away. Works great.
earlcbrown is offline Find More Posts by earlcbrown
fleaz is offline
Find More Posts by fleaz
fleaz's Avatar
United States, CO, Colorado Springs
Joined Apr 2007
Out of curiosity, which plane are you building?
fleaz is offline Find More Posts by fleaz
Old Oct 02, 2012, 01:25 PM
MCarlton is offline
Find More Posts by MCarlton
Cromer,Norfolk, UK
Joined Nov 2006
Cling film for me. Or whatever its called. Food wrap stuff, is that saran wrap??
MCarlton is offline Find More Posts by MCarlton
Old Oct 02, 2012, 01:45 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
I'm a wax paper fan myself. I like that it doesn't bunch up as easily as the stretch/cling food wrap plastic.
BMatthews is offline Find More Posts by BMatthews
Old Oct 02, 2012, 03:38 PM
Joined Jan 2007
Larger is relative of course. My first was a Buzz Bomb 100. Just started on a SHAFT 400. There was so little wood/glue on the Buzz that I could just pop it free from the glass if some CA bled through. With the tail surfaces on the SHAFT however, there is more wood, and therefore glue, and I've lost some balsa trying to remove a couple of stuck parts (trying to use CA sparingly). I think I can fill it with balsa filler, but I may order a new tail sheet. I do know that SA suggests using the plastic bag the kit came in, but I'd like to cover the entire work surface/plan sheet at once. The bag wont do that.
Thanks for all the suggestions folks.
Old Oct 02, 2012, 04:41 PM
Captain Dunsel is online now
Find More Posts by Captain Dunsel
United States, NJ, Southampton Township
Joined May 2005
I use plastic sandwich wrap (Saran, Glad, etc., although a cheaper brand will do).
To make it easier to hold the wrap in place, put short strips of masking tape on the wrap, then stick thumbtacks through the tape. It distributes the stress and keeps the plastic wrap from tearing.
CD
Captain Dunsel is online now Find More Posts by Captain Dunsel
Old Oct 02, 2012, 05:14 PM
epoxyearl is online now
Find More Posts by epoxyearl
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
+1 on Monocote backing-free and clear.
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: My "Take" on the AMA
Old Oct 02, 2012, 05:21 PM
old_dude is offline
Find More Posts by old_dude
Groundloop World Champion
old_dude's Avatar
USA, AZ, Glendale
Joined Jan 2002
-Mike
I agree with Mike, parchment paper is the best. Over the years I've tried all the others. Only recently has the parchment paper by Reynolds come to my perview.
Old_dude
old_dude is offline Find More Posts by old_dude
Old Oct 02, 2012, 08:46 PM
Curare is offline
KE your cub.
Curare's Avatar
Joined Jun 2005
I'll give the parchment paper a go next build.
Old Oct 03, 2012, 08:08 AM
Al Offt is online now
Find More Posts by Al Offt
Boston, MA subburb
Joined Sep 2004
I like the clear (non-shrink) plastic window insulation found at home improvement stores such as http://www.amazon.com/3M-Indoor-Insu...tic+insulation Nothing sticks to it and you can see the plan clearly.
Alan
Al Offt is online now Find More Posts by Al Offt
Discussion What is Your Favorite Material to Work With? Tail Spin1 Scratchbuilt Multirotors 21 Aug 30, 2012 06:24 PM
Sold 5 rolls of Flite Kote covering material Steve H. Aircraft - General - Miscellaneous (FS/W) 1 Aug 19, 2012 02:47 AM
Wanted Finishing and Covering Material RSUnderwood Aircraft - Fuel - Engines and Accessories (FS/W) 2 Mar 22, 2012 03:23 PM
Question Plan covering material? mag1 Scale Kit/Scratch Built 10 Apr 19, 2011 05:37 PM
Discussion Plan Covering Material - CA No Stick! hoppy The Builders Workshop 1 Dec 03, 2008 12:56 PM
