Old Feb 20, 2012, 04:35 PM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Rx/BEC question
Ok, I think I goofed. I have a 2.4 Rx, Optima 6 lite.
I wanted to use a CC BEC, as I found that the BEC in the Eflite 60 amp ESC cannot handle thier own electric retracts.
But.....here's the rub: I have Ail, Ele,Throttle,Rudder, Flaps, and Retracts.....so where do I run the CC BEC to??? Do I need the get the 7Ch Rx to run that?
I can't believe I made such a simple mistake after 30 years in the hobby lol
Mark
mrittinger is offline Find More Posts by mrittinger
Old Feb 20, 2012, 05:45 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by mrittinger View Post
Ok, I think I goofed. I have a 2.4 Rx, Optima 6 lite. I wanted to use a CC BEC, as I found that the BEC in the Eflite 60 amp ESC cannot handle thier own electric retracts. But.....here's the rub: I have Ail, Ele,Throttle,Rudder, Flaps, and Retracts.....so where do I run the CC BEC to??? Do I need the get the 7Ch Rx to run that? I can't believe I made such a simple mistake after 30 years in the hobby lol Mark
A switchmode regulator can be input via Y with any servo, even better distribute the load and run
two leads, one in with the Retract and one with say Flaps - both draw high currents and will get ample feed.
Optima Transceiver (RX) - Dual or Multiple Batteries may be installed - Avoid Brownout & Add Redundancy,
even one for each servo.
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Feb 20, 2012, 07:29 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
So, what you are saying is run a Y connector from the Rx on a retract channel with one lead to the retracts, and one to the BEC?
Old Feb 21, 2012, 12:05 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I can't follow Alan T's instructions with all the links and cross-references to other instructions that often don't seem to relate to my original question. I'm still not completely sure how to connect Optima receiver's SPC port to motor batteries and add-on BEC's following the confusing diagrams included in the receiver instruction sheets. BTW, Park BEC's from Dimension Engineering with the "bypass feature" do not connect the same as other brands of BEC's or speed controls with built in switch mode BEC's. This stuff shouldn't be so confusing and I know it's not just me that's confused.
E-Challenged is offline Find More Posts by E-Challenged
Old Feb 21, 2012, 12:35 AM
A.T. is offline
Joined Aug 2002
Yes, as stated: "A switchmode regulator can be input via Y (lead) with any servo"
and referred:
"User can supply power to the servos by one battery (switchmode Regulator aka CC BEC)
plugged into any unused channel, not just the one marked "BAT" or multiple batteries,
even one per servo."
quote CC BEC:
"Our Battery Eliminator Circuits are small devices that eliminate the need for a receiver and servo battery pack.
They draw higher voltage from the motor batteries and drop it to a voltage level
that is suitable for your receiver and servos.
This is required in applications which draw high power for multiple servos or use more
than 3S motor packs, as most ESCs with linear BECs are not designed for these applications.
NOTE:CC BECshould never be operated in series or parallel with another BEC
or backup receiver pack connected to the RX/Servo side of the circuit."
Alan T.
Old Feb 21, 2012, 01:47 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
Interesting...
Discussion Rookie question...BEC or no BEC X650 61retro Multirotor Talk 1 Nov 04, 2011 06:38 AM
Question BEC / RX pack question. bp_968 Batteries and Chargers 3 Aug 20, 2007 01:19 PM
A solution for the BEC backup-RX-battery question pullin-gs Power Systems 3 Apr 29, 2002 06:05 PM
A solution for the BEC backup-RX-battery question pullin-gs Electric Plane Talk 0 Apr 29, 2002 08:36 AM
BEC and Seperate RX battery question DaleM Power Systems 12 Mar 01, 2002 08:14 AM
