Old Dec 22, 2011, 07:00 AM
heliwill10 is offline
Find More Posts by heliwill10
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
How much Vacuum?
How much vacuum are you pulling on your wings? For high load 60 and the standard Dow blue wallmate foam.
heliwill10 is offline Find More Posts by heliwill10
Old Dec 22, 2011, 10:48 AM
Curtis Suter is offline
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
I don't know what wallmate is but here's some suggestions:
White bead foam about 5-6" in hg
Dow square edge (blue) foam from the large box store about 15" in hg
Dow Hi-load 60psi foam 20" in hg
This doesn't mean that you can't build a nice wing using less pressure either.
Hope this helps
Curtis
Montana
Curtis Suter is offline Find More Posts by Curtis Suter
Old Dec 22, 2011, 01:50 PM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
That's does help I am a little high. I'm finding in some of my wings depressions that really I can only narrow down to foam.
I think wall mate is the same as the blue square foam.
Do you have any issues with the leading edge pulling down evenly at 15in? .014 mylar?
Will
Old Dec 22, 2011, 05:16 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Will
.014 mylar will conform to the LE at 15" Hg. I typically thin the LE portion of the mylar with a properly sharped cabinate scraper.
wyowindworks is offline Find More Posts by wyowindworks
Discussion Would a vacuum formed lexan fusulage weigh too much for a micro? Speedfreak Micro EDF Jets and Power Systems 19 Dec 01, 2011 12:54 PM
Discussion vacuum pump & accessories how much is it worth? dhauch Composites Fabrication 3 Nov 23, 2011 05:39 PM
Discussion How Much Should Government Do? How Much Is Too Much? How Much Debt? LcJ Life, The Universe, and Politics 80 Jul 28, 2011 07:43 PM
Question How much vacuum should a fridge compressor pull? Bosk Composites Fabrication 20 Jul 09, 2009 02:27 PM
Discussion How much vacuum? _King_Pin_ Composites Fabrication 5 Aug 27, 2007 08:05 PM
