Old Dec 21, 2011, 08:26 PM
steve crewdog is offline
Find More Posts by steve crewdog
Old Tyme Electric
steve crewdog's Avatar
Joined Mar 2005
Whoops!
Resetting low voltage cutoff on a SS-60?
Hi all,
I did a DS thing and did my first power up of a SS-60 with a half-full battery pack. Nothing in the manual about resetting it, any SS-60 users know if it's possible?
TIA,
Steve
steve crewdog is offline Find More Posts by steve crewdog
Old Dec 21, 2011, 08:38 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Is it a HK SS 60 ESC? Like this:
http://www.hobbyking.com/hobbyking/s...0_70A_ESC.html
If so, it reads the battery voltage ench time it is a connected to the ESC and uses that to decide what the cell type and count it. So connecting to a charge battery will just have it starting over on deciding that.
On the LVC, it says it is programmed to "..Slow down at 3.0V per cell Lipo, Cut-off at 2.9V per cell Lipo 0.8V NiMh.." and it should still be doing that.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Dec 21, 2011, 08:43 PM
Old Tyme Electric
Joined Mar 2005
Ah sorry, Jack. It's an ElectriFly Silver Series 60A.
http://www.electrifly.com/escs/silverseries.html
I was hoping I could do it without buying the programming card.
Old Dec 21, 2011, 10:22 PM
Jack
USA, ME, Ellsworth
Joined May 2008
If I understand the info at that link, that one reads the battery voltage at each startup too. There is a manual there for setting the options using the throttle stick too. That's not my favorite way to do that but if you can use the defaults it might not need any programming.
Good luck with it!
Jack
Old Dec 22, 2011, 11:32 AM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
The default is 74% of starting voltage. Always start with a full pack. If you put in a partly depleted pack the LVC will be set to a potentially damaging low level.
About the only thing you can set on that is the brake. For that you may as well stick program it.
Electrifly is not my favorite ESC by a long shot. They want a high price for a product that has not kept up with the battery technology. The 67% LVC setting on many of their ESC is quite low.
flydiver is offline Find More Posts by flydiver
Discussion Blade 120 SR Low Voltage Cutoff Level dakilen Electric Heli Talk 2 Sep 25, 2011 04:46 AM
Discussion 11.1v low voltage cutoff? Balr14 Electric Power Cars 3 Jul 10, 2011 01:51 PM
Discussion Battery low voltage cutoff Paul5910 Batteries and Chargers 5 Jun 14, 2011 01:33 AM
Discussion Too early low voltage cutoff on HZSC? Ickarusmelt Beginner Training Area (Aircraft-Electric) 16 Mar 31, 2008 11:37 PM
Low Voltage Cutoff issue on Mikro Designs GFS! ESC? kosmonot Electric Plane Talk 0 Apr 21, 2004 06:47 PM
