Old Oct 01, 2010, 06:42 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
Actual current for some Cheap chargers
Would some of us please check the current on many of the cheap chargers out there? I wish I had more , but the worst one for voltage inaccuracy was the e-bay B610a so I checked it.
B 610 a It is just over half of what is displayed on screen. Very bad.
10 = 5
8 = 4.5
7 = 3.85
5 = 3
4.7 = 2.7
1.3 = .85
gulio is offline Find More Posts by gulio
Old Oct 01, 2010, 06:45 PM
gulio is offline
That's a funny word
NE Ohio
Joined Apr 2003
I'll check the turnigy 5 amp accucel 6 and the B-6 too. (soon)
(the older original 5 amp one)accucel6 5 amps on screen = 4.7-4.8 amps actual
Imax B-6 5 amps on screen = 4.8-4.9 amps actual
Old Oct 01, 2010, 06:53 PM
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Just don't check them with a cheap eBay Wattmeter.
They can be just as inaccurate on the current range.
jj604 is offline Find More Posts by jj604
Old Oct 01, 2010, 06:55 PM
gulio is offline
That's a funny word
NE Ohio
Joined Apr 2003
Ha, yes. What tipped me off to this one was that I was using 2 packs in series and then charging them with 2 different chargers. The b-610 a kept returning far too much capacity than the other one. It was over 50% more capacity and should've been equal or less.
Old Oct 01, 2010, 07:02 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
First thing I do with any new charger is test its' input and out put readings ( volts,amps, mAhs)against know accurate in-line watt meters as well as the per cell voltage readings.
Even fairly good ones have errors in their firmware which at times can slip thru Alpha and beta testing. One charger I tested recently was very accurate except when doing discharges above 27 amps. where it was way off capacity wise.
Charles
Old Oct 01, 2010, 07:06 PM
gulio is offline
That's a funny word
NE Ohio
Joined Apr 2003
Yea, I'm kinda interested in the ones that are way off so to avoid them (or at least be aware of them)
Old Oct 01, 2010, 07:28 PM
Southern Pride
But it takes a lot of testing to find errors sometimes. The one I mentioned was the icharger 3010B and it was extremely accurate except when doing Regenerative discharges above 27amps, at which point it was extremely bad. I notified them and it was fixed with a Firmware Rev.
My point is that you can not check at one or two points and sssume the rest of thier range will be accurate. As I have posted many times I hate Firware updates as each one means the charger needs to be tested all over again and it can take 40 hours or longer.
If I am working with a programmer I know and trust then perhaps not all functions and ranges have to be tested but they are human and make mistakes also.
Charles
Old Oct 01, 2010, 08:06 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
10 = 5
8 = 4.5
7 = 3.85
5 = 3
4.7 = 2.7
1.3 = .85
Looks like you are reporting current readings.
Current depends on the charge state of the battery and how far along it is in the charge. Once it reaches the CV stage, the current drops.
Did you put a 1/2-3/4 charged lipo and make those measurements. If so they are probably correct.
hoppy is offline Find More Posts by hoppy
Old Oct 01, 2010, 08:27 PM
Southern Pride
But he stated
Shown on screen 10A actual 5A etc. or at least I think that was his mmeaning. I have seen the oposite where a charger indicated it was charging at 1A but in fact was charging at 1.5Amps.
Charles
Old Oct 01, 2010, 08:36 PM
gulio is offline
That's a funny word
NE Ohio
Joined Apr 2003
Yes, they are the screen displayed readings vs. the actual.
Old Oct 02, 2010, 01:35 PM
gulio is offline
That's a funny word
NE Ohio
Joined Apr 2003
The idea here isn't to ask for an all inclusive green light on chargers , but rather if there's a known problem to post it. Thanks.
I'd be curious to see someone else do a B610a. I've thought for a few weeks now I've been charging at 10 amps , but no.
Old Jan 01, 2011, 12:33 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
I just got a HobbyKing ECO 6-10 200W charger which is showing charging current higher than the actual (measured with a $100+ meter):
Displayed vs. Actual:
0.1A --- 0.129A
0.2A --- 0.196A
0.3A --- 0.275A
0.4A --- 0.360A
0.5A --- 0.438A
0.6A --- 0.515A
0.7A --- 0.590A
0.8A --- 0.672A
0.9A --- 0.750A
1.0A --- 0.829A
1.1A --- 0.900A
1.2A --- 0.985A
1.3A --- 1.064A
1.4A --- 1.142A
1.5A --- 1.210A
1.6A --- 1.285A
1.7A --- 1.363A
1.8A --- 1.440A
1.9A --- 1.520A
2.0A --- 1.615A
2.1A --- 1.692A
2.2A --- 1.770A
2.3A --- 1.848A
2.4A --- 1.920A
2.5A --- 2.000A
2.6A --- 2.074A
2.7A --- 2.149A
2.8A --- 2.229A
2.9A --- 2.290A
3.0A --- 2.370A
3.1A --- 2.443A
3.2A --- 2.510A
3.3A --- 2.576A
3.4A --- 2.660A
3.5A --- 2.730A
3.6A --- 2.800A
3.7A --- 2.870A
3.8A --- 2.940A
3.9A --- 3.010A
4.0A --- 3.085A
As a result the calculated capacity (mAh) going into the pack is off by the same amount as the current.
OTOH the current displayed during discharge is correct.
I also have a number of Turnigy and Imax chargers which display the charging current more or less correctly (within a 2% margin).
ivanc is offline Find More Posts by ivanc
Old Jan 01, 2011, 05:04 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Are we all expecting laboratory accuracy from hobby equipment ?
Did we pay for laboratory accuracy ?
As long as the errors do not create a major battery life shortening of some other hazard, I can accept less than perfection.
Rich
cyclops2 is offline Find More Posts by cyclops2
Old Jan 01, 2011, 05:55 PM
gulio is offline
That's a funny word
NE Ohio
Joined Apr 2003
No , but 25-50% error is ok? Not by me. I bought a 10 amp charger to do 10 amps , not 5. I had plenty of other 5,6,7,8,10 amp chargers to choose from already.
Old Jan 01, 2011, 07:30 PM
cyclops2 is offline
Joined Mar 2003
You are right.
That is a reject by any standard. But is that their normal quality or a rare bad batch ?
Sold Chargers for sale cheap 2.4ghz Aircraft - Electric - Batteries & Chargers (FS/W) 3 Sep 20, 2010 05:06 PM
Discussion Which of these chargers do you recommend? Or is my 'current' fine? TheNiceGuy Batteries and Chargers 8 Aug 17, 2010 02:02 PM
Discussion want some ideas for cheap chargers/method on many cells at once. Draconious Batteries and Chargers 10 Jan 19, 2006 05:17 AM
