Old Jan 21, 2015, 06:28 PM
flycatch is offline
Find More Posts by flycatch
United States, CA, Barstow
Joined May 2004
I have the same retracts on mine and they worked fine until last month. The left one worked but the right one refused to come down. Made my first one wheel landing and naturally can't duplicate the malfunction.
flycatch is offline Find More Posts by flycatch
Old Jan 22, 2015, 07:35 PM
SmokeDogg is offline
Find More Posts by SmokeDogg
"Fly Low, Fly Fast, Turn Left"
SmokeDogg's Avatar
United States, CA, Red Bluff
Joined Jul 2009
It seems like it's usually the dang micro switches on the electric retracts that cause them to stop working. The new models coming from e-flite no longer use the micro switches. I hope they go back and update the existing line to operate without them!
SmokeDogg is offline Find More Posts by SmokeDogg
Latest blog entry: Miss Foxy Lady eBuild
Old Jan 23, 2015, 11:31 AM
OneS4Avant2envy is offline
Find More Posts by OneS4Avant2envy
OneS4Avant2envy's Avatar
United States, MD, Montgomery Village
Joined Aug 2012
just want to let people know my P-51 is up for sale
http://www.rcgroups.com/forums/showthread.php?t=2331117
OneS4Avant2envy is offline Find More Posts by OneS4Avant2envy
Old Mar 09, 2015, 02:12 PM
md_cobra is online now
Find More Posts by md_cobra
md_cobra's Avatar
United States, TN, Nashville
Joined Mar 2012
I maiden mine this weekend. It flew great, however my FG-21 seems to be having a fuel delivery problem. Anybody else have this issue? I flew it without the lower cowling as it's a new engine and wanted it to have the best cooling that it could. It started spitting in the mid range. Idle and WOT are rock solid. After I landed I noticed air bubbles in the fuel line. I am planning on pulling the tank to see if my clunk came off or if there is a split in the line somewhere. I may add some foam padding around the tank to dampen the vibration it gets. Open to suggestions. Thanks in advance.
md_cobra is online now Find More Posts by md_cobra
Old Mar 10, 2015, 05:32 PM
md_cobra's Avatar
Joined Mar 2012
I pulled the engine and tank last night. All looked good. I did put some hose clamps on all the connections inside of the tank. I didn't find any cuts, splits or holes. I didn't see a way to add any isolation foam to dampen vibration to the tank with out doing some surgery. If it still acts up and has air bubbles in the line I will take the extra time to add the foam. Until then, Happy Landings.
Old Aug 03, 2015, 06:07 AM
Claydoc is offline
Find More Posts by Claydoc
Flying is Fun.Even if U Crash!
Claydoc's Avatar
Australia, VIC, Ringwood
Joined Jul 2010
So guys, 85 deg or 90 deg eflites for this girl please
Thxs chris
Claydoc is offline Find More Posts by Claydoc
Old Aug 03, 2015, 11:50 AM
md_cobra's Avatar
Joined Mar 2012
I tried both as I had them on hand. I used the 85*. Has a slight toe in ( wheels are slightly closer to each other) but it doesn't bother me any. The toe out ( wheels are out towards the wing tips)from the 90* bothered me more. I did place washers under the inboard screws of the retracts to keep them from bottoming out in the wheel tubs. I used the stock wire struts but had to cut a little of the end that goes into the retract and re grind the flat spot so that the loop fits in the wing. Have about 40 - 50 flights on it now. Power is a Saito FG-21 rx is a AR9110.
The hardest part of the install is getting the wire thru the ribs.
Old Aug 03, 2015, 12:04 PM
md_cobra's Avatar
Joined Mar 2012
Description:
Description:
Old Aug 06, 2015, 11:03 AM
Night Pilot is offline
Find More Posts by Night Pilot
United States, PA, Easton
Joined Aug 2006
I've had my TF 60 size Mustang for about five years. I used Robart air up spring down retracts, 90 degrees. I modified the mounts for a little more forward rake and so they were not splayed out. Gear door is at an angle to the strut so they fit fairly flush. Started out with a Magnum 91 FS, but it self destructed, so replaced it with a DLE 20 with pitts muffler. I had problems with the engine. I would run fine on the ground and ok at first. then would start acting up in flight after about 5 minutes. I would try to land, but it wouldn't throttle back enough, then when I tried to go around, it would quit. Had numerous gear up and off field landings. Plane got really beat up. I finally determined it was vapor lock because of the carb location above the muffler. I installed air ducts from the scoop under the spinner to the upper rear cowl area and then an air dam to help the hot air out. It worked. No more engine problems. Repainted in RAAF colors to help cover all the repairs. Over 300 flights on this plane now.
Night Pilot is offline Find More Posts by Night Pilot
Old Aug 21, 2015, 01:31 PM
MNEman is offline
Find More Posts by MNEman
United States, MN, Lake George
Joined Sep 2012
Does anyone have some good pics of how they modified the retract mounts on this. I want to build it up before I fly it.
Dennis
MNEman is offline Find More Posts by MNEman
Old Aug 31, 2015, 06:06 PM
Willstonesracing is offline
Find More Posts by Willstonesracing
Using glue to fly high...R/C!
Willstonesracing's Avatar
Australia, QLD, Highvale
Joined Feb 2013
Can someone please measure the tail plane on this model or any other 60 size mustang? I have a kit of a 60 size mustang with 64" span wing, but the kit has no tail or rudder and no plans, I can fab one up, I just need the dimensions, Width from the fuselage to tip of tail plane and also any other dimensions(total width etc) would be great. Thanks guys.
Will
Willstonesracing is offline Find More Posts by Willstonesracing
Sold Top Flite P-51D .60 size NIB collectors edition ch47dfe293 Aircraft - Fuel - Airplanes (FS/W) 2 Mar 17, 2014 11:57 PM
Discussion Top Flite P-40 Warhawk ARF .60-.91,64.5" mike early Fuel Warbirds 12 Aug 27, 2010 07:35 AM
Discussion TOP FLITE P-51D Mustang .60 Retracts help rcflyer44 Fuel Warbirds 7 Jun 28, 2010 08:28 AM
Discussion Need muffler help w/.60 size top flite P-51D and OS.91 FSR sstewart1 Fuel Warbirds 1 May 03, 2010 06:25 PM
