Old Feb 06, 2010, 08:51 PM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
FPV Slow Stick
A few days away from getting the last bit of the puzzle to FPV my slow stick, as an FPV trainer (My Easy Glider is my primary, but the SS can take a knock a lot better during my training...)... so today I was itching to check it with weight... Added some dead weight to see how it flys. We're having some storms, but in between some torential rain, I tried a quick flight. Wind was dead at take off, but quickly got a bit gusty (within 30 seconds of take off! )
Plane survived, but it was very scarey!
Slow Sticks don't like wind (1 min 49 sec)
Underwear change possible required...
galaxiex, or other Slow Stick masters... - how does your SS handle wind, and are there ways to make it happier? I only added a few extra grams. In real life, I'll be adding a heavy GWS 360* serveo, camera and 500mw 900Mhz video Tx.... I might have to upgrade my motor. I'm using an Integy 200W Outrunner+ESC System.
Motor
Speed: 1000Kv
Output: 200W
Input: 15A max
Speed Control
BEC output: 6V 3A
RPM: 0 to 30,000
Input: 6V-16.8V
Current: Electronically controlled
3S 2200mah Lipo.
Note: This isn't FPV.... It's conventional flying.
Cralis is offline Find More Posts by Cralis
Old Feb 06, 2010, 08:54 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
Did you see this?
http://www.rcgroups.com/forums/showthread.php?t=1189357
All for the SS.
Kmart is offline Find More Posts by Kmart
Old Feb 06, 2010, 10:12 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Well.... My SS FPV plane handles quite a bit of wind. I have flown in 22 mph wind with gusts over that.
It wasn't really fun but the plane could handle it.
Mind now....
My FPV SS is outfitted with gyros on all 3 axis.
One gyro for pitch, and one gyro tilted to handle both yaw and roll.
Also....
Heavily reinforced wing. (to handle the added weight)
Extra long fuse/stick. 1200mm overall length (makes the plane even more stable)
Raised wing mount. (stability again, all the weight "hangs" below the wing)
AUW 42 oz.
Sooooo, it is quite far from a stock SS configuration.
I'm sure you have seen this vid before....
Sorry I don't have anything new recorded...
This is in 22 mph winds.....
SLOW STICK FPV IN A BIT TOO MUCH WIND (4 min 49 sec)
galaxiex is offline Find More Posts by galaxiex
Old Feb 06, 2010, 10:30 PM
galaxiex is offline
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
And just for fun....
A very old vid...my first SS with camera.
Mostly stock, (wing, tail, fuse) no gyro's, but with a mild brushless motor....
oops, forgot.... custom vertical fin and rudder....
GWS SLOW STICK in TOO MUCH WIND!!! (2 min 17 sec)
Old Feb 06, 2010, 11:43 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
In the windy one, you can see the vertical stabiliser bending in the wind, before you take off!! hehe.. That was excellent.
Gyros... mm... Which do you use? I've seen some really small light ones at HobbyKing... Might invest in one of those... That would make life a load easier... Not sure how the one gyro handles two axis though?
Old Feb 07, 2010, 12:35 AM
galaxiex is offline
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Maybe this picture will help.
Old Feb 07, 2010, 12:40 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Thanks. Nice work. What gyros do you use, and would you recommend them?
Old Feb 07, 2010, 12:42 AM
Leon Chen is offline
Find More Posts by Leon Chen
Chinese FPV Customer
Xiamen,China
Joined Nov 2008
http://www.vimeo.com/822035
in china,we can't see vimeo.bad...
Leon Chen is offline Find More Posts by Leon Chen
Old Feb 07, 2010, 12:52 AM
galaxiex is offline
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Those are the Blue Arrow nano gyro. HK sells them.
http://www.hobbycity.com/hobbycity/s...idproduct=4320
I like them because they are so small and light, and they work very well.
The bad part is.... out of a dozen or so that I have bought from HK, 3 have been NFG right out of the package.
I still buy them, knowing I could get a bad one.....
They are not the cheapest, but they are the smallest and lightest I have seen.
I also have about 6 of the HK Turnigy TG380 gyro. They are also small and light and work well.
But of the 6 I have....2 are NFG.
http://www.hobbycity.com/hobbycity/s...idproduct=6755
Gyro threads....
Do some reading.
http://www.rcgroups.com/forums/showthread.php?t=931091
http://www.rcgroups.com/forums/showthread.php?t=923947
http://www.rcgroups.com/forums/showp...&postcount=334
Old Feb 07, 2010, 12:54 AM
galaxiex is offline
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Sorry, can't help you there.
Old Feb 07, 2010, 02:14 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Thanks galaxiex. I'll gyro may SS up a bit... Start with just one... Probably on yaw?
That 'thing' you use to lift the wing up a bit - is it a custom made thing, or are they buy-able? That seems like a pretty good fix for stability. My x-gear has also seen better days...
Old Feb 07, 2010, 04:42 AM
draron is offline
Find More Posts by draron
draron's Avatar
Australia, QLD
Cralis, I fly my slow stick FPV. Had decent success with it too, only I wasn't flying in gusty wind When I eventually get around to meeting up with you guys you can see my slow stick. It's probably not the best by any means but may help with ideas? I'm thinking about the gyro deal myself!
Edit: Forgot to mention that the mounting tabs and wing raisers that Galaxiex uses can be purchased here: www.radicalrc.com/shop/?cat=249
Dave has stacks of great slow stick upgrades that come in handy, I have got a couple of small things off him before
draron is offline Find More Posts by draron
Old Feb 07, 2010, 05:02 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Thanks draron! Will check the site. Are you flying the SS FPV at the moment? I will be getting my video Tx, so will maybe try it FPV this weekend. (So, might need to replacement parts pretty soon. )
Old Feb 07, 2010, 05:07 AM
draron is offline
draron's Avatar
Australia, QLD
No probs! Yeah the SS is my only fpv plane at the moment, have my head tracker going now, and I'm just waiting on my simple OSD I don't have the wing raisers but still find it quite steady to fly (not that I fly in a lot of wind)
Old Feb 07, 2010, 05:18 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Ok, where and when do you fly! I'll come and do some formation flying (as my maiden) with you. Where abouts in Brisbane? I'm 'North Side'..
Discussion Slow Stick FPV UPDATED! MAR 31 09 galaxiex FPV Talk 369 Mar 28, 2013 07:35 PM
Discussion FPV Slow Stick - Weight? Cralis FPV Talk 65 May 09, 2010 08:32 PM
Discussion Slow Stick Canard Pusher for FPV! Kmart FPV Talk 6 Dec 08, 2009 04:31 PM
New Product From Slow Stick AP to Slow Stick FPV Qrome Aerial Photography 4 Aug 24, 2009 11:24 AM
Discussion FPV Slow Stick Zaviation FPV Talk 1 May 04, 2007 12:15 PM
