Old Oct 18, 2004, 06:58 PM
pkrska is offline
Find More Posts by pkrska
pkrska's Avatar
Toronto, Ontario, Canada
Joined Jan 2004
Most of those pics are for craft that flies in space, not in air type worlds. But we could get aways with it if we were to use clear plastic film or something to hide all those holes!!!
Why not use clear plastic to produce the lift, wing like, and have the details within it's frame. That would allow you to make the Y-wing and still have wings in there.
pkrska is offline Find More Posts by pkrska
Old Oct 18, 2004, 09:07 PM
tmproff is online now
Find More Posts by tmproff
Inverted Electric Flyer
tmproff's Avatar
United States, TX, Humble
Joined Jan 2004
Any new pics of this? I am really excited to see this thing fly!!
BTW, how in the world would you land a B wing?
tmproff is online now Find More Posts by tmproff
Old Oct 18, 2004, 09:13 PM
Trikster is offline
Find More Posts by Trikster
Zoom, zoom...
Trikster's Avatar
Roseville, CA (Sacramento area)
Joined May 2003
Very carefully...
Trikster is offline Find More Posts by Trikster
Old Oct 18, 2004, 09:55 PM
adrive7 is offline
Find More Posts by adrive7
Parkflyer
adrive7's Avatar
Rockville, Maryland
Joined Nov 2003
you would just belly it in, unless you wanted to add the retractable landing skids...or jet thrusters
adrive7 is offline Find More Posts by adrive7
Old Oct 18, 2004, 10:12 PM
RMihara is offline
Find More Posts by RMihara
Aerial Shutterbug
RMihara's Avatar
San Mateo, California, United States
Joined Nov 2001
Originally Posted by cormu
havent u guys seen that flying lawnmower ???
If that flys this should be a shinch
You mean this?
Flying lawnmower built and flown by Chris Luvara
Photo Credit: Eric Greenwood
RMihara is offline Find More Posts by RMihara
Old Oct 18, 2004, 10:20 PM
RMihara is offline
Aerial Shutterbug
RMihara's Avatar
Joined Nov 2001
Of course the Tie Fighter more closely resembles Snoopys Doghouse in terms of lifting surfaces? i.e. doghouse roof = tie fighter tilt panels...
Of course, you could always add clear lexan (or other thin, tough plastic) to box in the wing panels to create true lifting surfaces but that would take away from the beauty of what you're trying (and will get!) accomplish.
Good Luck and I'm in line for a kit should you produce one!
-Roger
Old Oct 23, 2004, 06:33 AM
jskrebs is offline
Find More Posts by jskrebs
Evil Plane Doer
jskrebs's Avatar
Westport, Pennsylvania, United States
Joined Dec 2002
Back from Atlantic City should get some done this weekend prior to leaving for Orlando.
or jet thrusters
Great Idea.......... 4 CDR motors..............
jskrebs is offline Find More Posts by jskrebs
Old Oct 23, 2004, 06:53 AM
JJfromUK is offline
Find More Posts by JJfromUK
Spent too much already..
JJfromUK's Avatar
East Yorkshire, England
Joined May 2001
Just to keep up the enthusisam - tie.wav
I'm sure this can be found at countless locations on the WWW by now
JJfromUK is offline Find More Posts by JJfromUK
Old Oct 23, 2004, 07:32 AM
jskrebs is offline
Evil Plane Doer
jskrebs's Avatar
Joined Dec 2002
Center Fuselage and Elevons
Old Oct 23, 2004, 08:24 AM
jskrebs is offline
Evil Plane Doer
jskrebs's Avatar
Joined Dec 2002
Must do family stuff now.
Hope to cut the fuselage parts out this evening. It will be hollow to allow the gear to be inside and I will radius the leading edge much like the wing.
Old Oct 23, 2004, 11:35 AM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Cox has a U-control Y-wing that does OK. H-stab is fitted between the TE of teh engines. You'd have to make that out of clear sheet.
rdeis is offline Find More Posts by rdeis
Old Oct 23, 2004, 12:01 PM
jimsky is offline
Find More Posts by jimsky
Trying to defy gravity...
jimsky's Avatar
USA, NY, East Northport
Joined Dec 2003
OK, I'm in, this looks just too fun figuring out how to make one fly. I'm going to take a stab at a small Bluecor J250 direct drive version.
Jimsky
jimsky is offline Find More Posts by jimsky
Old Oct 23, 2004, 12:14 PM
WillowPtarmigan is offline
Find More Posts by WillowPtarmigan
Lagopus lagopus
WillowPtarmigan's Avatar
Houston Hobby, Texas, United States
Joined Jul 2003
Sounds cool to me. Go for it. While, you're at it, build yourself a Death Star.
WillowPtarmigan is offline Find More Posts by WillowPtarmigan
Old Oct 23, 2004, 12:22 PM
jimsky is offline
jimsky's Avatar
Joined Dec 2003
DeathStar...talk about a challange getting something to fly.
Jimsky
Old Oct 23, 2004, 09:16 PM
jimsky is offline
jimsky's Avatar
Joined Dec 2003
Well I had the evening free so I cut some Bluecor and build a Vader Tie Fighter. I’m not calling this original; it’s obvious mine is heavily influenced from ideas presented in this thread. I just wanted to make something small and J250 powered. My 20” J250 Scram Blur flies great with just 150 square inches of wing area, so I decided to build something with a similar wing area.
I fabricated an airfoil shaped, double layered center “wing” to create aerodynamic lift. I’ve made a similar airfoil shape on my Insulator and it flies great. I made up simple single layer side panels. I was going to go direct drive but I think the huge duel side rudders are going to be a lot of drag, so I decided to use a gearbox to up the thrust.
Span: 13”
Length: 16”
Wing Area: 156 square inches
Flight Control: Elevons
Motor: J250 in GWS100 “B” gearbox
Prop: APC 9075
Tomorrow if the winds die down I’ll play glider pilot and find where the CG wants to be. Lock up the control surfaces, get some clay and obtain the best glide. Once I do that, I’ll load in the “budget” flight electronics.
Receiver: Blue Bird 4 Channel BMR-04
Antenna: Litenna
ESC: Blue Bird 10Amp SDC-10AN
Servos: Blue Bird BMS-306
Battery: Thunder Power 2S1P 1320maH, 2nd generation
MotorClac says I should get 9.7 ounces of thrust at a pitch speed of 38.4 mph, drawing 9.1 amps from the battery. Actually this is the same setup I have in my Insulator, it works very well. It should be enough thrust and speed to maiden it and see if she flies. If so, I’ve got some ideas using carbon fiber to fabricate the “pilots pod” that will captivate the motor & prop if this ever gets to direct drive. The photos show a GWS prop, it will replaced with an APC 9075.
I really have no clue if this will fly, if the glider tests are a bust…oh well it was just some Bluecor and a bit of my time.
Jimsky
This is not your father's Sky Scooter - Video Duf Parkflyers 14 Apr 12, 2003 06:32 AM
Your Thoughts on My Wild Idea Craig Logan Power Systems 1 Mar 06, 2002 07:35 PM
Need your advice on my FMS House Fly model JStory Electric Heli Talk 4 Dec 29, 2001 05:44 PM
This is my last Tiger Moth question for the day! FlySilent Parkflyers 4 Sep 11, 2001 07:18 PM
Am I going to burn this up? avdflyer Electric Plane Talk 1 May 12, 2001 08:53 PM
