Old Apr 27, 2015, 04:31 PM
mattnat is offline
Find More Posts by mattnat
United States, NC, Asheville
Joined Sep 2012
square or tapered trailing edges?
hay all
my plane tracks well but im wondering if it can be better. some wag in yaw and hunting in the wind. the plane is a 3dhobbyshop extra 72. i have rebuilt it a bunch of times and have added inch to the elevator and the plane ways 10.5 lbs on 8s. cg = slight pitch coupling on knife edge/ 04% mix rudder to up elevator.
was thinking of tapering the trailing edges of rudder and ailerons finer than the ARF stock. will this help? the other option is to add basa to the trailing edge to continue the lines of stock airfoil.
do pattern guys worry about the trailing edges?
matt
mattnat is offline Find More Posts by mattnat
Old Apr 27, 2015, 05:08 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
wag in yaw?... can't say I've ever seen a 72 wag.
if you want to remove the coupling, push the battery forward.
trailing edges actually do have an effect to control, kind of like a mechanical expo of sorts, it wont help the tracking. actually making them worse may help the tracking and centering: add a half inch strip of 1mm plywood to the trailing edge in a T shape. Have done it myself, and pattern guys do it a lot especially on rudder.
Do an image search for F3A planes, they've tried all kinds of crazy things to their planes.
theKM is offline Find More Posts by theKM
Old Apr 28, 2015, 02:17 PM
Aeroplayin is online now
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Yeah, I wish I had the time to experiment with it a little more, but when I was building planes with Godfrey, we used to make sure the trailing edge was no thicker than the two 1/16” balsa sheets plus just enough adhesive to keep them together. Not many planes that track as well in IMAC, but there are other differences. The wings and stabs are in the 16 to 18 percent thickness range as well, which will add a bit more stickiness to the airfoil, and maintain it through a a higher AoA. This is easy to do without adding weight on the sheeted foam wings, but this thickness could add weight to the built-up wings with the material, adhesive, and assembly techniques we typically see from China.
A 50cc kit used 6mm and 3.5mm ply, heavier Monokote, thick aluminum LG (my undercarriage weighed 583g), heavy split 388g cowl, and a thick plastic, heavily framed canopy (327g), and 10mm stringers, and still came in at 17.4 pounds wet (7890g). 35% planes were 22.5 pounds wet, and 40% were 37 pounds. Wag and yaw would self-correct before you had a chance to input a correction if built correctly, yet some guys still think a heavier plane tracks better. I think it's more about design from what I've seen, than about weight. but a 10.5 pound 330 should be no problem.
I just wonder if the thinner wings and stabs we see more of has something to do with it, but all in all, the 3DHS and EF planes track incredibly well and if I had one that didn't, I’d tend to look for a problem somewhere, like a warped control surface, incidence issue, etc.
Another thing to consider is precession and slipstream and how the vertical stab is configured. For a hint about this, look no further than the design files that were declassified after WWII for the P-51 and look closely at what they did.
Aeroplayin is online now Find More Posts by Aeroplayin
Old Apr 28, 2015, 04:43 PM
mattnat is offline
Joined Sep 2012
i admit i am being picky...... i moved the lighter batteries and esc foreword and it seems better..
so 1/8 inch is the standeed eh? i wont sharpen them when i recover...
what about the p-51? may i have a link?
matt
Old Apr 28, 2015, 06:11 PM
Xpress.. is offline
Find More Posts by Xpress..
Hitec RCD CSR
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
Generally with 3D airplanes you won't get them to track arrow straight like a pattern ship will. They can track pretty good but if there is enough wind they'll just wander all over the place especially if there is turbulence. For the most part, they're designed to not fly arrow straight, rather be all over the place, wadded up into a ball
Xpress.. is offline Find More Posts by Xpress..
Old Apr 28, 2015, 07:29 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
...well, if ever there was a chance to disagree with Xpress.. it's this one.
Discussion square trailing edges? mattnat Competition Aerobatics 3 Yesterday 11:56 PM
Question Straight or tapered wing, round or blunt wing tips, which is better? Edubarca Vintage & Old-Timer Designs 12 Jan 10, 2015 03:41 PM
Discussion Trailing edge, blunt or tapered learn2turn Foamies (Scratchbuilt) 8 Aug 03, 2010 04:56 PM
Discussion Round of leading edge and taper trailing edges?! Pukin_Dog Foamies (Scratchbuilt) 28 Aug 29, 2009 01:47 AM
Discussion Making tapered trailing edge coosbaylumber The Builders Workshop 2 Dec 09, 2006 01:59 PM
