Old Nov 25, 2013, 10:21 AM
R055Y is offline
Find More Posts by R055Y
Joined Nov 2013
Question
What sailplane to get?
Hi everyone i'm just getting into sail planes and am after a decent electric sailplane but i haven't a clue where to start. I was looking at the skip miller models Speedo PNP Electric 1.2m but there doesn't seems to be many videos or many reviews of it. So can anyone point me in the right direction?.
R055Y is offline Find More Posts by R055Y
Old Nov 25, 2013, 10:57 AM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Millsboro
Joined Sep 2008
Not stating your budget, I put up some links to vendors who have e-sailplanes and excellent reputations and have good flying birds. Pick one you like, it's not easy choosing just one.
http://www.espritmodel.com/f5j-alesl...ailplanes.aspx
http://www.soaringusa.com/F5J-LMR-ALES-Electrics/
http://www.icare-rc.com/power_glider.htm
http://www.arthobby.com/#
http://www.kennedycomposites.com/index.html
http://www.skipmillermodels.com/Electric_s/6.htm
http://www.skybench.com/index.html?h....com/home.html
Leadchucker is offline Find More Posts by Leadchucker
Old Nov 25, 2013, 11:07 AM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
As is all models, bigger flies better. The 1.2 meter you are looking for is a slope glider, really. Not having a slope around, then you use the eletric version. The DLG gliders are in a 1.5m size and weigh around 6-9 oz. Those are hand launched. I would not want to go any smaller wingspan than 1.5 for eletric gliders. I am intersted in thermal flight - if you are after slope type flight - then you may be able to go with a smaller wing.
Usually 2m is about the general span recommended for starter gliders. That is a good mix in visibility, equipment size and capabilities.
JimNM is offline Find More Posts by JimNM
Old Nov 25, 2013, 11:38 AM
R055Y is offline
Joined Nov 2013
Originally Posted by Leadchucker View Post
Thanks so lots to choose from. I'm only after a 1.5m tops as i'm only after something you can take up highwith the motor then glide back down.
Old Nov 25, 2013, 02:40 PM
benedict is offline
Find More Posts by benedict
benedict's Avatar
United States, HI, Waimea
Joined Feb 2013
I'll chime in on what Jim said. The Speedo is a slope plane. If you have slopes nearby, I encourage you to play with them. Slopes are FUN! The cool thing is you can slope just about any glider. If you decide slope is the thing for you, then getting dedicated slope planes is probably a good route to go.
In the meanwhile, for motoring up and gliding a 2m really is a nice size to learn on. Smaller than that and they really do start to feel every bump and wiggle in the air. I've got a 2m motor glider and love it. I can already tell I'll eventually want something bigger. But not smaller.
Tom
benedict is offline Find More Posts by benedict
Old Nov 25, 2013, 03:59 PM
olmod is online now
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
Cermack used to produce the Newtimer (2 piece wing)which was an update on a Playboy ,I have one of the Newtimers and would recommend it for very relaxed 3 channel climb and glide, If not available Playboy kits are around and not hard to build, almost as good as glider is a Funcub recommended first plane imho.
olmod is online now Find More Posts by olmod
Old Nov 25, 2013, 04:22 PM
peterlngh is online now
Find More Posts by peterlngh
Joined Apr 2012
If you are interested in learning to soar in thermals then it's just about impossible to beat the standard Parkzone Radian. It's simple to assemble and fly, has a two piece wing so will fit in a small trunk, it's available as anything from a "kit" to a ready to fly from several vendors so you can find the balance of price and completeness to suit your budget, is easy to repair and has spare parts available, and soars every bit as well as many sailplanes that cost 5-10 as much.
If you really want ailerons then the Flyzone Calypso would be an excellent choice. It's a little more versatile but doesn't quite match the pure floating ability of the Radian though it's probably better than the Radian Pro (I have not flown a Radian Pro so I'm going by reputation.). It's also available from several vendors with or without electronics and spare parts are available.
When model sailplanes get much below 6 foot wind span one really starts to lose soaring ability unless you are going for an ultra light hand launch/DLG. The extra wing area is pretty much a necessity if one wants a useful power system.
If you want to stay away from foam then we would really need an idea of your price range. Esprit Models offers several glass fuse/ balsa wing sailplanes between 1.8 and 2.5 meters that would be good choices for a first sailplane if you have some flying experience. Also check out Soaring U.S.A. and Art Hobbies.
Cheers!
peterlngh is online now Find More Posts by peterlngh
Old Nov 25, 2013, 04:51 PM
Bob Cook is offline
Find More Posts by Bob Cook
The Lone Blue Plaid Flyer
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi RO55Y,
Radian is the hands down winner in this kind of voting.
But, like Peter said, Art Hobby or Sky Bench get my votes. I have a Lil Bird from Sky Bench, and a Castor from Art Hobby. The Orion has replaced the Castor. All good stuff.
Bob in Seattle
Bob Cook is offline Find More Posts by Bob Cook
Old Nov 25, 2013, 04:58 PM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
The question is rather like the " I want to date a girl.... which one should I ask" question.
Old Nov 25, 2013, 05:17 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
That's right Jim. For me, the answer has always been this, blond, green eyes, size 5 or less.
Bob in Seattle
Old Nov 25, 2013, 09:27 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
Another vote for 2 meter minimum on wingspan. (Ok, 6 feet is acceptable, but 100 inches is better.)
I concur that, if you don't want to build and can't make it to an auction, the Radian is a good choice. Note that the Radian PNP is less expensive than the Speedo PNP. But, at least around here (Boston) there are some auctions where decent balsa gliders will go very inexpensively. In fact, we've got one coming up on Sunday.
You might as well pick something that is light, big, and slow. Easier to fly, will come down more slowly, is more visible, and so on.
If I have a student who is willing to build, I usually recommend the Olympic II. It's a bit easier to fly than a 2 meter model, it stays up longer, and it's more visible. You might even find one for sale in an auction. Some other decent trainers would include the Gentle Lady (wing spar requires somewhat more delicacy on winch than some) and the Sig Riser 2 meter, Olympic 650, and many others. The Paragon has a good reputation but may require significantly more power. And these are models that you might see at an auction. BTW, you don't need high tech to stay up for a long time. At least, not on a good day. The high tech models deal with wind and strong sink better, because they are faster. Also, if you get the ailerons, flaps, programming etc. set up right they are easier to land exactly where you want. At least if you've practiced. I've flown an Oly II for over an hour a couple of times, or maybe more. I've flown it until my neck hurt many more times.
Note that most motor recommendations, IMHO, are for far more power than required. This is not necessarily a problem if they 're not too heavy or expensive, but not everyone needs to get to 200 meters in 30 seconds, or to hover. The original Allegro E Lite weighed maybe 23ounces and used a Speed 400 direct drive. Maybe that's 75 to 100 watts into a less than efficient motor. The climb was adequate as long as you kept it moving.
lincoln is offline Find More Posts by lincoln
Old Nov 26, 2013, 02:18 AM
R055Y is offline
Joined Nov 2013
The parkzone radian pro it is.
Discussion Sometimes You Get What Pay For And Sometimes You Pay For What You Get dharban Electric Competition Soaring-F5J/ALES/e-Soaring 31 May 20, 2013 11:00 AM
Discussion What to do when I didn't get what was promised? Sessholvlaru Trader Talk 30 Feb 11, 2013 07:17 PM
Discussion What sailplane should i get? grossmanator Slope 7 Jun 02, 2008 10:07 PM
What motor should I get for this sailplane? AllThumbs Electric Sailplanes 7 May 26, 2008 09:35 AM
Question What high start to get for RES type sailplanes? ozmo01 Thermal 41 Apr 20, 2008 12:05 AM
