Old Jun 02, 2013, 12:13 PM
busta1 is offline
Find More Posts by busta1
Joined Jul 2005
Vacuum forming Micro parts
Hi,
I built a vacuum former from and have had success with thin document wallet plastic but it's too thin to make the parts I need.
I ordered this from ebay , it's plasticard
http://www.ebay.co.uk/itm/2008771042...84.m1497.l2649
I can't seem to get it to mold well , I have had it in a 210 degree oven for 2 minutes and I'm sure this would be long enough, anyone have any experience , is it even suitable?
It molds but doesn't pick up the detail , maybe it's just not getting hot enough.
busta1 is offline Find More Posts by busta1
Old Jun 02, 2013, 02:12 PM
DynamicFoamy is offline
Find More Posts by DynamicFoamy
DynamicFoamy's Avatar
Ohio
Joined Nov 2007
The plastic should start to sag when it is at the correct temp. You must position and start vacuum very quickly without delay. If you are lacking detail my guess is you do not have enough vacuum pressure and temp is off. Are you using a shop vac as a vacuum?
Bert
DynamicFoamy is offline Find More Posts by DynamicFoamy
Site Sponsor
Latest blog entry: Customer Support Forum
Old Jun 02, 2013, 03:11 PM
busta1 is offline
Joined Jul 2005
Hi,
Thanks for advice, I have the vacuum on when I put the plastic over the mold, It's a dyson vac and it's really powerfull (it actually pulled the plywood lid into the box and snapped it in hald when I covered the holes with my hand)
So I think its the temp, I have seen it sag but don't think I am getting it hot enough , guess I will have to give it another 30 secs.
Old Jun 02, 2013, 05:10 PM
alset is offline
Find More Posts by alset
Gunbarrel, CO
Joined Dec 2006
Could it be the thickness? It seems like 1/4 mm is fairly thick.
alset is offline Find More Posts by alset
Old Jun 03, 2013, 02:04 PM
busta1 is offline
Joined Jul 2005
Hi,
not sure 1/4mm is the thinnest I couls find , maybe it is too thick
Discussion can you vacuum form foam using a regular vacuum former? John Molnar Jr. Scratchbuilt Indoor and Micro Models 14 Apr 26, 2013 12:22 AM
Help! Vacuum forming problem payne9999 The Builders Workshop 7 Jan 24, 2013 10:34 PM
Question Anyone vacuum form their own parts? turbojoe Balsa Builders 30 Jan 21, 2013 09:26 PM
Question anyone got a vacuum former willing to form some parts?? mrbaseballny The Builders Workshop 0 Sep 08, 2005 09:01 PM
Vacuum Forming - Duplicating an existing part Joedy Composites Fabrication 16 Oct 26, 2004 07:18 PM
