Old May 28, 2012, 10:59 AM
Kenbogunz is online now
Find More Posts by Kenbogunz
Joined Sep 2008
Help!
repairing the skin on a moldie
I would like to get the opinion as to what is best to use as a filler on the skin of a molded sailplane wing.....managed to put small crease in a wing I have and I want to repair it.....thanks in advance
Kenbogunz is online now Find More Posts by Kenbogunz
Old May 29, 2012, 08:03 AM
John Walter is offline
Find More Posts by John Walter
John Walter's Avatar
USA, IL, Naperville
Joined Feb 2003
A pic of the damage would help.
Many creases can be fixed by drilling a series of small holes along the crease then using CA in the holes to bind the damaged area together. Filler is typically for appearance and airflow, not structural repair
John Walter is offline Find More Posts by John Walter
Old May 29, 2012, 08:58 PM
wsmorton is offline
Find More Posts by wsmorton
United States, HI, Pearl City
Joined Aug 2006
Here's a link to some repair work I did on an Eraser Extreme.
http://www.rcgroups.com/forums/showthread.php?t=1165202
I used several different methods, included the CA trick that Mr. Walter mentions.
Scott
wsmorton is offline Find More Posts by wsmorton
Old May 31, 2012, 12:07 AM
Joined Sep 2008
thanks for the input fellas........what is the best filler to use on a molded skin that has a crease?
Old May 31, 2012, 01:12 AM
Tuomo is online now
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
It depends, difficult to say without seeing a picture of the damage.
When making repairs, strength is #1 thing to worry about. #2 is weight. Looks are only #3.
I would say, if you need filler, use something that is light, easy to sand and not brittle. If it is a smaller area dent, maybe just put tape or sticker on it?
Tuomo is online now Find More Posts by Tuomo
Old May 31, 2012, 01:17 AM
samwei1950 is offline
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
2 component bodyfiller (Unsaturated Polyester Putty)would be the best filler for the job,1-3% hardener added depending on the working temp,you can find the product from any car paint dealers
It;s a spot repair job on the said molded wing crease area
drysanding the crease with #180 grade---->clean--->apply 2 coats of thin bodyfiller--->curing
--->wetsanding bodyfiller with #120#240#320--->2 coats of primer--->drying--->
fine wet sanding primer and featheredging the old paint area with #600 grade wetsanding paper--->clean--->buffing the old paint area with rubbing compound--->topcoating and blending out old paint area....
Sam
samwei1950 is offline Find More Posts by samwei1950
Old May 31, 2012, 02:41 AM
Dale Thompson is offline
Find More Posts by Dale Thompson
TD- F3K- Slope - What to fly?
Dale Thompson's Avatar
Cupertino CA
Joined Aug 2005
SUPER FIL
Bondo for airplanes! Superfil is an ultra-lightweight epoxy filler for rough fill and contour repairs
http://www.aircraftspruce.com/menus/cm/fillers.html
This works well and is light.
Dale Thompson is offline Find More Posts by Dale Thompson
Old Jun 02, 2012, 08:00 AM
Joined Sep 2008
thanks everyone
Question Moldies as Carry-On chip.greely Slope 19 Apr 07, 2012 09:27 AM
Discussion I need to repaint a repaired moldie - how would you do it? screamin' eagle Slope 38 Feb 20, 2012 06:08 PM
Mini-HowTo Composite wipers on moldies??? Daryl Perkins Multi Task F3X 7 Jan 27, 2012 01:41 PM
Whoops! minivec moldie repair Big Gas Slope 41 Jan 20, 2012 07:01 PM
Question How to repair swollen skin John Kim Composites Fabrication 6 Mar 26, 2006 12:38 PM
