Old Jul 04, 2011, 09:27 PM
dmcquinn is online now
Find More Posts by dmcquinn
dmcquinn's Avatar
Chesterfield (St.Louis) MO
Joined Jan 2004
Spektrum AR7010 - data logger shows "L999"
Who's got the Spektrum AR 7010 receiver and the data logger?
My brand new system shows "L999" after a one minute flight.
This system is the one that has two receivers -- one receiver is built-in to the main receiver package and the satellite receiver is on a 6 inch pigtail. This is a DSM2/DSMX system, but since my transmitter (JR10X with Spektrum 2.4 module) is DSM2 only, I am running in DSM2 mode.
When the receiver is first powered on the data logger shows this:
A000
b---
L002
r---
F000
H000
After one minute of close-in flying, I land and the logger shows this:
A017
b---
L999
r---
F000
H000
Also, if I walk 14 steps away with the transmitter in low-power mode, the "L" setting goes from "L002" to "L999". In full power mode, I can get about 300 feet away and then the logger goes to "L250", then "L500" then L999"
So I think the satellite receiver is faulty.
dmcquinn is online now Find More Posts by dmcquinn
Old Jul 07, 2011, 06:29 PM
dmcquinn's Avatar
Joined Jan 2004
I ordered and received another remote DSMX receiver. Same thing happens. So now I think the main unit is defective. I'm calling Horizon tomorrow.
I'm doing my testing now outside of the airplane. I have the receiver with one servo plugged in to the throttle channel. Battery plugged directly into one of the ports and the data logger plugged into the data/bind port. After I walk 15 steps away, the data logger shows "L999"
Old Jul 07, 2011, 09:47 PM
Guz is offline
Guz
Find More Posts by Guz
Guz
Gutless wonder
Guz's Avatar
Tempe, AZ
Joined Dec 2005
You're reading it upside down. It should be 666ן, and it means that it needs more sacrifices.
Guz is offline Find More Posts by Guz
Old Jul 25, 2011, 02:02 AM
Gunnycig is offline
Find More Posts by Gunnycig
Joined May 2011
L999 fade problem
Hello, Can you tell me if you found the reason you were getting the fades on your receiver. I recently purchased the AR7010 and Im also getting L999 fades at very short range no matter where I place the receivers. Any help would be great.
Gunnycig is offline Find More Posts by Gunnycig
Old Jul 25, 2011, 08:26 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
It doesn't have an L antenna - just ignore it.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Jul 25, 2011, 03:47 PM
Gunnycig is offline
Joined May 2011
l999 problem
Thanks for the reply Andy. Maybe I"m confused but the Spectrum flight log reads all receivers and satellites. This is the way it works on my old AR6210 and thought it should be the same with this new AR7010 receiver.
A000 "Main receiver"
b---
L002 "satellite receiver"
r---
F000
H000
This is an FPV setup and I really need to know the receiver performance. It gets a little expensive range testing a receiver by trial and error with a loaded T-Rex 500
Old Jul 25, 2011, 07:59 PM
dmcquinn's Avatar
Joined Jan 2004
I called Horizon and they agreed it wasn't right and to send it in. Apparently they are pretty busy now -- their web site says electronics service is backlogged 14 days. They've had mine for 12 days now and it shows a status of "product checked in".
When it comes back I'll post the resolution.
Old Jul 25, 2011, 09:36 PM
Gunnycig is offline
Joined May 2011
Ar7010
Sounds like I will be sending mine back too. Thank you for the help and quick reply.
Old Sep 19, 2011, 07:17 AM
janch is offline
Find More Posts by janch
Joined Apr 2007
Hi,
I have had this recever for one week and I have had same experiencies.
janch is offline Find More Posts by janch
Old Sep 19, 2011, 09:41 PM
dmcquinn's Avatar
Joined Jan 2004
I have decided that this is normal for this receiver. I duplicated the problem on the bench with two different transmitters and three different receivers.
Horizon service said "No problem found". But they sent me a new receiver anyway. The new receiver does the same thing.
I borrowed a friend's DX8 transmitter and it behaved the same way.
Old Sep 20, 2011, 05:28 AM
janch is offline
Joined Apr 2007
It is really funny. I orded SPM9540 loger, because I would like to check my RX system. Now I can read information about L-999 is OK.
Old Sep 20, 2011, 05:33 AM
Bob P is offline
Find More Posts by Bob P
Senior Member
Bob P's Avatar
Wiltshire England
Joined Feb 2001
I have the same problem with an AR 9010 DSMX Rx operating on a Graupner Tx with 9 channel DSM2 module. At switch on the counters on the logger Rx channels rapidly count up to the maximum. Sometimes on all sometimes on some. The Tx works just fine with all my other DSM2 Rxs and other models selected on the TX. The model performed with no problems in the air, but I'm reluctant to fly with this Rx again until the issue is resolved.
I returned the Rx to Horizon UK and they reported no fault found, but replaced the Rx with a new one.
Interesting!
Are DSMX Rxs compatible with modules?
Bob
Bob P is offline Find More Posts by Bob P
Old Sep 22, 2011, 06:28 AM
Bob P is offline
Senior Member
Bob P's Avatar
Wiltshire England
Joined Feb 2001
Whoops
My post, last line should have read DSMX not DSM2. Now corrected
Bob
Old Sep 22, 2011, 08:55 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Yes, but they will be operating in DSM2 mode since the modules only do DSM2.
Andy
Site Sponsor
Old Sep 24, 2011, 07:53 AM
Bob P is offline
Senior Member
Bob P's Avatar
Wiltshire England
Joined Feb 2001
Andy
Yes, I understand that but why has this problem shown up on DSMX Rxs working DSM2 from a module. DSM2 Rxs on the same Tx don't show the logger max counts.
Bob
Discussion data logger tsenecal Power Systems 0 Jun 29, 2011 10:45 AM
Sold spektrum AR6210 dsmx receiver jimbo1 Aircraft - General - Radio Equipment (FS/W) 1 Jun 28, 2011 03:10 PM
Sold NIP Spektrum Data logger $20 shipped Con/US Phil Davy Aircraft - General - Radio Equipment (FS/W) 1 Dec 11, 2009 06:12 PM
Help! Spektrum Data Interface on V3 shows 56K fades lavi Eagle Tree Systems 1 Dec 17, 2008 02:22 PM
Discussion Spektrum Data Logger sweetpea Radios 1 Dec 30, 2007 01:23 PM
