Old Jan 22, 2014, 03:38 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally Posted by flieslikeabeagle View Post
... The motor constant Io is supposed to represent the constant no-load current, but as I found, it is not a constant at all, and is in fact not even remotely close to being a constant, instead varying quite strongly with rpm. ....
Hysteris losses in the iron go up linear with rpm, eddy current losses go up squared with rpm.
Vriendelijk groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jan 22, 2014, 08:46 AM
Christian Lucas is offline
Find More Posts by Christian Lucas
Germany, BY, Gräfelfing
Joined Jan 2003
Because of the search of a high efficancy elektric motor i have a little test modelmotor .i yoused this motor to slide different backiron materials outside the windings no need to change any thing on this motor.So i can select + and - of different materials.
So first i slide now some air outside and check the motor running with this freeflux system. Motor has a 2 pol rotor from neodym 22mm dia and 30mm long.
Winding is 5 turn of 245 x 0,1 litzwire ,to get low eddy current in the wire and now i have switcht to parallel wind of this litzwire with 5 turn each phase . Internal resistance is 0,004022 ohm ,no load amps are 3,2 amps.The coils are y terminated to get no circle circuite amps. So kv = 7860 rpm . I run this motor on 1 cell 3,6 volt to mesure no load amps.
Flux calculating show on the surface of the rotor we have 0,560 tesla ,at 0,5mm distenz= 0,52 tesla,at 1,0mm 0,48 tesla,at 1,5mm 0,44 tesla,at 2mm 0,41 tesla,at 2,5mm 0,38 tesla ..... at 5mm 0,27 tesla. So you see the flux is very low.but low flux will give low fluxrelated los.
Christian Lucas is offline Find More Posts by Christian Lucas
Old Jan 22, 2014, 09:15 AM
flieslikeabeagle is offline
Find More Posts by flieslikeabeagle
Got shenpa?
flieslikeabeagle's Avatar
Los Angeles
Joined May 2004
Ron, I came to that same conclusion after some head-scratching. Hysteresis losses cause a fixed amount of energy lost every time the magnetic field reverses, so the total energy lost should be proportional to the number of revolutions, so the total power lost (time derivative of energy lost) should be proportional to the rpm.
The same argument seems to hold for bearing friction as well.
So what sort of actual physical motor losses are accurately represented by the constant, unvarying Io in the 3-constant motor model? Are there any, or is the constant Io a purely mathematical convenience with no direct connection to any actual physical energy loss mechanism in motors?
-Flieslikeabeagle
flieslikeabeagle is offline Find More Posts by flieslikeabeagle
Old Jan 22, 2014, 09:32 AM
MilesH is offline
Find More Posts by MilesH
London UK
Joined Jun 2006
It doesn't represent anything, really. It sort of works in cases where eddy current losses are the minor component.
MilesH is offline Find More Posts by MilesH
Old Jan 24, 2014, 07:17 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
The best graph is to represent Io x Vin versus rpm
See the picture for the Scorpion SII 4020 family (3 windings, 3 Kv)
At no load, the copper losses are ridiculously low
BB losses and aerodynamics drags are probably(?) also very low
Conclusion : curve is not linear
A good regression is an order 2 polynomial
Louis
Fourdan is offline Find More Posts by Fourdan
Old Jan 24, 2014, 12:00 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I've found motors to generally fit idle watts is proportional to delta V^(3/2). That is, if a motor is 10W at 10V (1A) no load it will be 2^1.5*10 = 28W at 20V. But I haven't often tested this with junk motors.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Jan 24, 2014, 02:04 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Greg
Hi Greg
with the formula Wo = K V^(3/2) you have only one degree of freedom (K)
with the formula Wo = A + B rpm + C rpm^2 you have three
and the formula is respecting hysteresis losses + eddy currents losses
generally A is very small
Louis
Old Jan 24, 2014, 05:36 PM
E-speed buff is offline
Find More Posts by E-speed buff
186mph Funjet Ultra
E-speed buff's Avatar
nieuw vennep, the netherlands
Joined Feb 2010
I have measured a rewound junk motor!
Turnigy SK50-55 580kv, phase resistance .011Ohm.
On ~11.1V Io ~3A, on 22.2V Io >7A!
Laminations are .35mm
René
E-speed buff is offline Find More Posts by E-speed buff
Old Jan 25, 2014, 04:59 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
René
Hi René
As a comparison
Scorpion SII 4025-520
weight 341g
measured Kv 526 rpm/V
Rm 0.0164 ohm
On 11.1V Io = 1.5A
On 22.2V Io = 2.2A
Louis
Old Jan 26, 2014, 04:16 AM
MilesH is offline
London UK
Joined Jun 2006
Regarding simple modelling: https://www.academia.edu/1360191/Bru...Fixed_Wing_UAV
Question 7"-10" LCD/LED Highest Quality Monitors???? LexusFPV FPV Talk 3 Jun 09, 2011 06:57 AM
Question Difference between BLDC motor & PMSM amith123 Electric Motor Design and Construction 2 May 10, 2011 06:11 PM
Discussion Maximum efficiency/flight time question. boingk Power Systems 11 Mar 19, 2011 07:29 PM
Discussion 2 BLDC motors on one shaft with the same drive? Raag90 Power Systems 2 Mar 10, 2011 01:38 PM
Discussion 5 Phase Unipolar BLDC Motor INewton Electric Motor Design and Construction 40 Jan 20, 2006 09:31 PM
