Old Jan 07, 2010, 12:05 AM
Modarius is offline
Find More Posts by Modarius
"Watch out for...CRUNCH!!
Modarius's Avatar
United States, UT, Provo
Joined Jul 2008
Wingdragon BL Motor too Powerfull?
Hi, a while back a got a 2212/6 Brushless motor to use in a plane and it has been sitting on the bench here for a while now. My question is, would it be too much for my poor humble WingDragon? I would run it on a 3 cell battery with a 6/4 prop attached. If it does work and not rip the plane apart, would someone with reasonable flying skills, such as myself, be able to fly it? Thanks for any input, it is greatly appreciated.
Modarius is offline Find More Posts by Modarius
Old Jan 07, 2010, 05:40 AM
road_rascal is offline
Find More Posts by road_rascal
Crashasaurus Dumbthumus
road_rascal's Avatar
USA, MN, Apple Valley
Joined Dec 2008
I currently use TowerPro 2409/12T motors in both my Wing Dragon's/Begin Air planes. With a 3S2200mAh lipo and 7x4 props I get around 190w or so. Both have heavily reinforced wings, tails and motor mounts. I have one with an onboard GPS logger and I got 86mph in a dive. It should handle the power with proper mods. DO IT!
road_rascal is offline Find More Posts by road_rascal
Old Jan 09, 2010, 11:09 PM
Modarius is offline
Modarius's Avatar
Joined Jul 2008
Thanks for the response but I don't think that you realize that the 2212/6 is a motor with almost twice the Kv of the motor that you listed as using. It is a 2200Kv motor and I think that's way to powerful for the WD. Again, thanks for the reply.
Old Jan 10, 2010, 12:56 AM
C₄H₁₀ is offline
Find More Posts by C₄H₁₀
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
I don't have a Wing Dragon but I do have that motor and you should be fine on a 6x4 or 6x3 prop. It is seriously powerful, though. Make sure the airframe is up to it because you'll be going over 50mph easily.
Remember, prop pitch governs speed and diameter governs thrust. The biggest prop this motor can handle on 3S is a 6x4.5 or 6x4. That'll give you a lot of speed and I don't think a stock Wing Dragon will handle it. Reinforce it a little or just go with a small prop (5x3 or 5x4). When you have a motor like this you've got enough power to rip your plane apart, but you don't have to use it all.
I say bolt it on and experiment with props, starting small. Find one you like.
Edit: Road Rascal, where do you fly? I see under your username it says "Twin Cities Parkflyers". Is that a club, perchance?
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Jan 13, 2010, 03:27 PM
Modarius is offline
Modarius's Avatar
Joined Jul 2008
Thanks for the response! I did not know about what the pitch and size affected, that's really good to know. I think that I will try it out.
Old Jan 14, 2010, 09:52 PM
foxy29 is offline
Find More Posts by foxy29
foxy29's Avatar
scunthorpe/england
id tape and cf rod/tube the wings and if you can glue them together i use duct tape to hold them together for transport but they are reinforced and needs it for a bp21 so you WILL NEED IT do both sides top and bottem and good luck and get a vid if poss please id luv to see that
foxy29 is offline Find More Posts by foxy29
Discussion Is a stock Trex 450 v2 motor too powerfull? cadders FPV Talk 8 Sep 10, 2009 07:04 AM
Discussion Wingdragon 4 - New Motor - not too sure which wire to solder where? mdavenport Electric Plane Talk 3 Jul 14, 2009 05:30 PM
Discussion BL motor Too much/too little resistance? Propjob81 Power Systems 11 Jun 03, 2006 03:45 PM
Mega motor too powerfull in E-starter?????? bboydeezturb Parkflyers 2 May 07, 2004 01:18 AM
Too much info available- Help with a BL motor and controller basmntdweller Power Systems 1 Oct 17, 2003 09:04 PM
