This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Apr 06, 2014, 12:48 PM
semperfi1970's Avatar
Joined Feb 2012
Cut a hole into the cockpit and it will hold a 2650mah 4s battery with ease. Not that it needs that much power but it sure is fun. Here is an old video of the EPO hinges pulling some serious G's With a grossly over powered P-40. The vid starts out slow and then I turn it up at the half way mark. The only bad thing about the EPO P40 is that you will struggle to fly it with a 450 motor unless you build super light and it is very calm out. A 480 is as small as I dare go with the P40. In the video if memory serves me correct I believe I am running a 1500kv 10 size motor on 4s. Note there is no cowl to keep the motor cool as it was running a APC 8x8 prop and cranking some serious rpm's.
GWS Warhawk (1 min 59 sec)
semperfi1970 is offline Find More Posts by semperfi1970
Old Apr 06, 2014, 06:19 PM
Como's Avatar
United States, MO, Raymore
Joined Sep 2011
Thanks, I was planning on using a suppo 2212/13 1000kv with a 9X6 E APC. It has been my standard on all my GWS, but as this is my first EPO and it does seem to be heavier. I am thinking I may need to go bigger.
Como
Como is offline Find More Posts by Como
Old Apr 06, 2014, 06:35 PM
Joined Feb 2012
Here is a great combo for the GWS EPO P40. It gives you the nose weight that you will need and enough power to stay out of trouble.
http://www.headsuphobby.com/Power-Up...otor-E-570.htm
http://www.headsuphobby.com/APC-9-x-...ller-G-171.htm
http://www.headsuphobby.com/Stick-Mo...tors-E-731.htm
Old Apr 06, 2014, 07:46 PM
Como's Avatar
Joined Sep 2011
Semperfi1970, How does that stick mount hold up to the heat?
Also I have a EPO Corsair and at T6 Texan that I will be building once the P40 is off the bench. Any insights on those?
I am now in search of the EPO FW190 to add to the hanger.
Como
Old May 22, 2014, 04:30 PM
Joined Feb 2012
Wow Como, pardon the super late response. The 35mm motor mounts are not effected by heat and trust me I get my motors hot at times. Here is a GWS EPO Corsair using a 35mm mount and it handles a 42mm motor at almost 1200 watts and 139 ounces of thrust. The mounts are very tough just use a hardwood stick not the pine ones that come with most kits if attempting this level of stupidity.
Also here is one of the last EPO FW190's to be had to the best of my knowledge.
GWS Corsair EF-1 Racing Motor (4 min 30 sec)
FW190 GWS (3 min 41 sec)
Old Jun 27, 2014, 11:51 PM
Never look down
Hack73's Avatar
United States, MD, Elkton
Joined Jun 2007
I just finished putting together my EPO P40 and she is heavy. I just need to paint it (can only do spray cans or brush). I don't have an airbrush or air compressor. It has a Park 480 1020kv motor, 3s 2200mah battery, and 3" Dubro spinner, but she is really nose heavy. When I measured my CG, it's about 35mm to 40mm. Just hair past the first panel line on the top of the wing. Anyone else having the same issue with CG?
Battery is pushed all the way back in the compartment.
Hack73 is offline Find More Posts by Hack73
Old Jun 28, 2014, 03:29 AM
swede
denial15's Avatar
United States, UT, Vineyard
Joined Aug 2005
I found mine was quite nose heavy with the dubro spinner I had on it when running the 3-blade. Looks like you have a similar spinner.
I originally added weight to the tail, but I found it flew much better with the original foam spinner and no tail weight.
What battery are you using? Mine was using a 3S2200.
denial15 is online now Find More Posts by denial15
Old Jun 28, 2014, 08:44 AM
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Mine has retracts so additional weight and its also EPS but I did add a 9g lead block in each side of the Horiz stab. Can't remember the exact CG but I think it likes to be a tad nose heavy and I have no nose over issues with mine on a hard surface but I do have a 450 size motor in mine. I also push the battery as far back as I can get it.
Alan
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Jun 28, 2014, 09:59 AM
Never look down
Hack73's Avatar
Joined Jun 2007
I forgot to mention, it is a 3s 2200mah battery. How do you attach the foam spinner?
Old Jun 29, 2014, 05:46 PM
Como's Avatar
Joined Sep 2011
Does anyone have the foam two blade spinner they would like to part with? Please PM me. I do have the three blade and will trade it if that is what it takes.
Como
Old Jun 29, 2014, 08:08 PM
swede
denial15's Avatar
Joined Aug 2005
Used the top of a soup can lid. I drilled a hole in the center, put it on the shaft behind the prop. Then I glued the foam spinner to the can lid with canopy glue. I turned it by hand to get it close to center as possible.
I've done it that way on a couple planes, and again to repair broken props. It wasn't too difficult to get it centered. The canopy glue comes off easy enough when you need to remove it. I would think white school glue would work similar to canopy glue.
It's kind of ghetto, but it worked for me.
Old Jul 04, 2014, 02:19 PM
Joined Feb 2012
The best way to adjust the CG on any electric plane is by moving the battery. If you cut out the inside of the cockpit firewall you can go as big as a 3000mah 4s battery. The end result is that you will have no pilot but rather a battery in the cockpit.
Old Aug 01, 2014, 08:10 PM
nsg
Yardley, PA
Joined Sep 2006
Hello GWS fans.
Good to see GWS is still around.
My GWS P-40 is for sale.
nsg is offline Find More Posts by nsg
Old Aug 08, 2014, 10:23 PM
Never look down
Hack73's Avatar
Joined Jun 2007
Here is my finished P-40.
Motor: E-flite Park 480 (1020kv)
ESC: Sky Power 30A ESC with Switchmode BEC
Receiver: OrangeRx R615x dsm2/dsmx 6Ch 2.4Ghz
Servos: Towerpro 9g SG90 Sub Micro Servo (4)
Prop: MasterAirscrew 9x7 3-blade
Spinner: Dubro 3" also using stock foam 3-blade
Paint: Top - Master Model - Olive Drab
Bottom - Master Model - Light Sea Gray
I found a way to attach any spinner to the front of the P-40. I used the small rubber bands that are used for making kids bracelets. I used 7 total. Just use one to wrap around the nose of the spinner then loop 3 other rubber bands close to the spacing of the prop blades. Then loop one extra on each loop coming off the center to make it long enough to go around the prop blades. It was real simple to make. I tested by spinning up the motor full throttle and no signs of any issues using this method. The pictures probably make it more clear.
For the stock spinner, I carved out the rubber spinner so it fit over my metal collect with the hole in it. I pressed a bamboo skewer through the rubber spinner & straight through the metal collect hole to the other side of the rubber spinner. Then cut off the excess. This allows the stock spinner to go over the metal collect and sit firmly on the prop. Then use the rubber band method. This also helps with centering any other spinner.
*Update - Further testing proves that the rubber band mod doesn't hold up.
Old Aug 10, 2014, 01:49 AM
Joined Feb 2012
Great looking P40 you have there.
Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** RAY GWS Product Announcements 2 Sep 01, 2007 10:45 AM
NIB GWS 40 EDF units bruff Aircraft - Electric - Airplanes (FS/W) 2 Sep 10, 2004 09:39 PM
hypethetical idea re: a never ending e-flight Dax Parkflyers 7 Feb 20, 2003 05:24 PM
Flying Tigers AVG dottney Scale Kit/Scratch Built 2 Feb 13, 2003 10:45 PM
Never ending problems adam_jorgensen Electric Heli Talk 7 May 28, 2002 12:51 PM
