Old Jun 05, 2012, 06:34 PM
Joined Dec 2011
Should motors spin when armed and throttle stick down?
I was testing my multiwii and when I armed the motors, they did not spin until i moved the throttle stick up slightly. This was before I calibrated the ESC's. I have now calibrated the ESC's and as soon as I arm the motors, they begin to spin. Is this the correct operation?
FYI...
minthrottle=1150
mincommand=1000
maxthrottle=1850
Thanks!
SplitFire is offline Find More Posts by SplitFire
Old Jun 05, 2012, 06:47 PM
United States, NV, North Las Vegas
Joined Sep 2009
Yes it's normal in MW, myself I don't like this feature but I do understand the value. if you want the motors to not spin up as soon as you arm, open the MW sketch> config.h tab and look for and uncomment MOTOR_ STOP it's down near the bottom of the config.h page. once this is done the motors will not spin up until you apply throttle.
Edit: go with FullmoonCat's post... he went all out with the fancy code paste
shultz is offline Find More Posts by shultz
Old Jun 05, 2012, 06:48 PM
Rank Amatuer
FullmoonCat's Avatar
United States, ID, Boise
Joined Dec 2011
There's also this setting:
Code:
/****           motor, servo and other presets                   ****/
/* motors will not spin when the throttle command is in low position
   this is an alternative method to stop immediately the motors */
#define MOTOR_STOP
If that's not uncommented, the blades will spin at lowest position.
Otherwise, you could try changing the mincommand to 900.
EDIT: Ninja'd!
FullmoonCat is offline Find More Posts by FullmoonCat
Old Jun 05, 2012, 07:00 PM
Joined Dec 2011
Thanks a lot! I just got a little confused since they spun BEFORE calibrating the ESC's and then after calibration, they didn't spin up. I would have looked through the code, but since I didn't make any code changes and had different results, I wasn't sure what was going on
Help! Xieada 9958 spins to left when throttle is increased danagelh Mini Helis 9 Aug 15, 2013 12:17 PM
Discussion Great Wall Xieda 9958 spins rapidly to the left when I give it throttle the desolate one Micro Helis 4 May 09, 2012 01:44 AM
Discussion Down With The 10% Throttle Cut and High Arm Northstar32 Multirotor Talk 3 May 07, 2012 05:59 AM
Discussion mCX2, upper blades not spinning down as they should... ChopperBopper Coaxial Helicopters 0 Jan 10, 2012 12:51 AM
Discussion Can't get my brushless motor to spin, it beeps when I arm it Wolygon Power Systems 14 May 21, 2011 10:37 AM
