Old Jan 02, 2012, 06:40 PM
crashtested's Avatar
USA, RI, East Providence
Joined Jun 2010
Help!
heli stabilization
What are the options for auto stabilization for a 500 sized heli?
I have seen a few in the past, but more interested to know what is working for the AP comunity.
crashtested is offline Find More Posts by crashtested
Old Jan 02, 2012, 09:18 PM
by Alary Design
Photoship One's Avatar
Mesa, AZ
Joined May 2002
My personal favorite, the Helicommand HC3-SX
Photoship One is offline Find More Posts by Photoship One
Old Jan 02, 2012, 09:58 PM
United States, CA, Ventura
Joined Aug 2007
+1 for that
MauiNate is offline Find More Posts by MauiNate
Old Jan 04, 2012, 08:27 AM
Member FPV UK
IWCoburg's Avatar
Isle of Wight, UK
Joined Apr 2010
DJI Ace one is also worth a look.
Mike.
IWCoburg is offline Find More Posts by IWCoburg
Old Jan 04, 2012, 09:01 AM
Staying Frosty
Hellsiege's Avatar
United States, CO, Colorado Springs
Joined Feb 2008
I use helicommand as well. All of the models should be an option, since your not flying 3d and you didn't mention flybar less. They don't have GPS hold unless you get to profi model, but don't think that's needed if you are just using it to hold the heli while you work the camera.
Hellsiege is offline Find More Posts by Hellsiege
Latest blog entry: Construction Projects - Updated
Old Jan 05, 2012, 12:08 PM
Joined Jun 2010
Is the flymentor junk?
Im not %100 sure this heli will be going top of the line (it IS a HK heli after all)... and i want to get some experience flying FPV on a single rotor.
Old Jan 05, 2012, 12:23 PM
Joined Aug 2007
I had one on my 450. Once I got rid of the vibes it worked pretty good. You really have to know how to fly a single rotor already to get it set up right though.
Old Jan 05, 2012, 12:33 PM
Joined Jun 2010
OK, i started this hobby on a trex 450se and was working on mild 3D when i got bit by fixed wing. If i can get some professional camera gear together i will go for the big 700 setup or multi rotor, but for dabbling now, i think i will have to go the cheap route and get a flymentor or similar to fly my gopro around.
Old Jan 05, 2012, 12:38 PM
Staying Frosty
Hellsiege's Avatar
Joined Feb 2008
This applies to all stabilization and flybarless systems.
Old Jan 05, 2012, 02:32 PM
Arducopter Developer
R_Lefebvre's Avatar
Joined Oct 2010
I had a Flybar. It worked ok for stabilizing a hover. I could never get optical stabilization to work however. But the biggest problem I had with it was that it doesn't have accelerometers, only gyros. So if you fly around for a while it looses track of which way is actually *down*. I flew fast forward for a while, came to a stop, released the sticks, and it automatically pitched the nose down. I couldn't figure out what was happening fast enough and crashed.
I'm now working on the ArduCopter system.
R_Lefebvre is offline Find More Posts by R_Lefebvre
Old Jan 05, 2012, 07:06 PM
Joined Aug 2007
Yeah, it's definitely not for those who know how to fly. If you can already do 3d, then just strap your camera on and go. No stabilization hardware will help your video get better, but fpv will
Old Feb 28, 2012, 03:16 AM
Aviation Technician
GetToDaChopper's Avatar
Joined Feb 2012
Hey what up Photoship One i think you know my name ?
GetToDaChopper is offline Find More Posts by GetToDaChopper
Old Mar 01, 2012, 06:50 PM
Teesside
Joined May 2009
Hi Crashtested
I run flymentors on 2 trex 500s and a FMA Co-Pilot 2 on a stretched SWIFT 16 (620). The flymentors are just great. The FMA when fitted to a 500 is more locked in ! BUT never used it in a built up environment ?
Trex 500 Flymentor & 4 GWS Park HPX Servo 19g/.05sec/3.6kg servos is spot-on The flymentor does NOT like high quality digital tail servos ;-) hey we aint doing 3D here ! Look at the Environment your going to be in ? and choose!
Note; either way buy the field programmer as these are quick and portable
My 500sI use a 200g camera and a 5000mA battery for 10 minute flight times (with some to spare)
Trex 500 has a MASSIVE power to weight ratio ;-) it can "Haul"
70% on the Flymentor is good.
I get were I am going, switch on 65% rates before shooting ? an the 500 turns Coaxial ! ;-0
Funkygrib is offline Find More Posts by Funkygrib
Discussion Rate Gyros and eCCPM mixer for Heli Stabilization scrtsqrl Aerial Photography 0 Nov 22, 2008 03:42 PM
Discussion Heli stabilization Crash Pilot UAV - Unmanned Aerial Vehicles 3 Jan 03, 2008 07:26 PM
Discussion Multiple gyro gains, levels of stabilization or camera tilts on DX7 in heli mode Arthur P. Aerial Photography 0 May 06, 2007 06:19 PM
Discussion Spartan AP2000i Heli Stabilization for AP IamLegend Aerial Photography 1 Aug 22, 2006 02:07 PM
Discussion new stabilization system for heli, usable for AP? askman Aerial Photography 24 Apr 10, 2006 11:01 PM
