Old Jul 08, 2011, 03:07 PM
United States, NJ, Absecon
Joined May 2008
Question
e flite power 10 shaft replacement
I know that the info is available, but I cant find it. Can someone tell me how to replace the shaft on my e flite power 10 motor, maybe a video I can watch, or web site to look at. THANKS
serairdog is offline Find More Posts by serairdog
Old Jul 08, 2011, 05:44 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Are you making a shaft or do you have a spare?
This link will show your the basics for getting the shafts out and back in:
http://www.maxxprod.com/mpi/tips1.html
If you're making a shaft or have to modify a shaft to fit it, this has some info on doing that:
Making and Replacing a Brushless Motor Shaft - http://www.rcgroups.com/forums/showthread.php?t=1240725
More motor diss-assembly info here:
How to repair an electric motor. - http://www.rcgroups.com/forums/showthread.php?t=1079423
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jul 08, 2011, 08:23 PM
Joined May 2008
thanks Jack, I should be able to repair the motor with the info you gave me. I'm replacing the bent shaft in the motor with a new shaft, at this point I'm waiting for the new shaft to arrive in the mail.
Old Jul 08, 2011, 09:20 PM
Jack
USA, ME, Ellsworth
Joined May 2008
If the shaft is bent in front of the rotating part, you'll have to push the shaft out the "long way". I use a vise and put the shaft in a small deep socket and press it down into the socket. You want all the pressure to be in the center and right around the shaft so that it does not deform the top of the housing.
I have some odds and ends of tubing and stuff that I use to support the housing as I push shafts either way into or out of a magnet housing. The shaft to housing fit is usually a light to moderate press fit.
If you can push a shaft out the "short way" you can put the socket or tube (aluminum works better than steel around the magnets) inside the housing, put a small cap screw or something smaller than that shaft on the end of the shaft, and press it down into the housing until it falls clear.
Good luck with it!
Jack
For Sale e-flite power 10 and Phoenix 45 esc Full Spool Aircraft - Electric - Power Systems (FS/W) 3 Apr 21, 2011 11:31 PM
Wanted E-flite Power 10 photocycler Aircraft - Electric - Power Systems (FS/W) 3 Apr 21, 2011 07:05 PM
Sold nib e-flite power 10 motor rcrick10 Aircraft - Electric - Power Systems (FS/W) 3 Mar 28, 2011 05:32 PM
Sold Used E-Flite Power 10 needs new shaft tarjas Aircraft - Electric - Power Systems (FS/W) 1 Dec 25, 2008 09:27 PM
Sold E-Flite Brio 10 & E-Flite Power 10 BL Motor Yardbee Aircraft - Electric - Airplanes (FS/W) 0 Oct 07, 2006 02:17 PM
