Old Sep 11, 2002, 10:29 AM
San Antonio, Tx
Joined Jul 2002
Just got my Kyosho T-33, which battery to use?
I just received a used Kyosho T-33 (no instructions). I was suprised at the toughness of the wings! The ailerons seem to use a weird bellcrank system? It was loose and shakey feeling so I redid it last night. I was wondering what size/mAh battery I should be using to power this thing. I have three 8 X 3000mAh NiHm I would like to use. It came with a 9cell pack which is smaller than the Sub c's I have. They are shrink wrapped so I'm not sure of their MaH or size?
The seller had replaced the motor with a stronger unit. I tried a Great planes Electrifly combination 30 amp esc/receiver on the plane last night on the bench, after around 20 seconds the motor shut down. I pulled back the throttle to idle and reapplied and the motor started back up for around 15 seconds. I'm guessing the ESC is going into thermal shutdown? How big does the esc need to be?
Thanks for all your help!
Steve
SteveO is offline Find More Posts by SteveO
Old Sep 11, 2002, 10:34 AM
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
It depends on the motor. What motor is in your T-33?
Daren
Daren is offline Find More Posts by Daren
Old Sep 11, 2002, 11:02 AM
San Antonio, Tx
Joined Jul 2002
Oops. I did some checking in the original threads and found out the motor is a Plettenberg 200-25-4 and battery that came with the plane is a 9cell panasonic 2000 nimhs. After reviewing all his emails he mentioned a 40 amp esc might be needed? I'm guessing my 8X3000 NiMh might not be up to the task? And they are larger/heavier also than the 2000s that came with the plane.
40 amps is allot! I used to run R/C cars with modified motors (10 turns) that usually only pulled 30-35 amps.
Old Sep 11, 2002, 11:23 AM
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
Stay with the 9 cell packs. Weight is the big enemy of the T33.
The heavier 8 cell packs will result in higher wing loading, lower thrust. What's to like?
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Sep 11, 2002, 11:51 AM
San Antonio, Tx
Joined Jul 2002
Wow..after checking prices for cp-1700 cells I'm in shock! They are much more expensive than standard sub c batteries! Which batteries will I want to use? They listed cp-1300, 1700 and 2400. Is it just the capacity that is different or weight as well? I really would prefer to use the cells I have now until I save up some $$ for new cells.
Old Sep 11, 2002, 12:02 PM
Joined Sep 2000
I use the 8Xcp1700 packs in my T33. With the stock motor the plane hand launches easily, gets about 4 minutes.
I purchased mine from Tony La at
www.eflightpacks.com
Good service and the packs (last spring) were $40 ea.
Old Sep 11, 2002, 12:08 PM
San Antonio, Tx
Joined Jul 2002
The cp-2400 are only $2 more per pack, would they offer longer runtime?
Old Sep 11, 2002, 12:43 PM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
yes, but your weight will increase 4oz. ..............gregg
gregg f is offline Find More Posts by gregg f
Old Sep 11, 2002, 01:21 PM
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
It seems like everyone is using 8 cp-1700, they are light weight for the cell and duration - 2400 would give you more time but a higher weight and this plane needs to be light. Your esc dying means the batt pack low, it does this to tell you to come down while you have enough batt to run the servos, you can reapply power for a short burst if you are in a bad spot - but it doesn't run long! My setup is stock with a pegasus 35 and it runs great. Does the same thing when the batt gets below 4V the safety kicks in and the motor quits - but the plane glides fairly well.
skyhawk is offline Find More Posts by skyhawk
Old Sep 11, 2002, 03:59 PM
San Antonio, Tx
Joined Jul 2002
Thanks for the info guys. I suppose I'll have to suck it up and buy some new battery packs. One reason I purchased this plane was because I thought it would use my R/C car packs..oh well, live and learn.
Old Sep 11, 2002, 04:16 PM
Joined Sep 2000
SteveO,
Lesson NO. 1.
In the world of EDF's, everything costs more
Old Sep 11, 2002, 04:23 PM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Wow..after checking prices for cp-1700 cells I'm in shock! ...
I bought quite a few CP 1700 cells at TNR Technical (an authorized Sanyo distributor) for $3 each. Now they charge me $3.5 a cell, still that's only about $28 for an 8 cell pack.
I buy all my Sanyo batteries there, they are local for me
http://www.tnrtechnical.com/
Herb is offline Find More Posts by Herb
Old Sep 12, 2002, 01:47 PM
San Antonio, Tx
Joined Jul 2002
Flies awesome!
I took the T-33 out last night for it's madien flight. It was awesome! Easily one of the best flying planes i have. I used the included 9 cell pack then used my 8X3000mAh. It had so much power i flew most the time at half throttle. I managed around 7 minutes with the 3000 pack. I think now I've flown this used one I'll look for NIB kit to build and really make sharp!
Old Sep 12, 2002, 03:07 PM
nashua nh 03060
Joined Dec 2000
T-33
Steve,
Glad It worked out . That plettenberg really makes a difference.
Enjoy your new jet
Derrek
Derrek Curtis is offline Find More Posts by Derrek Curtis
Old Sep 12, 2002, 03:56 PM
San Antonio, Tx
Joined Jul 2002
Thanks Derreck for everything. This is easily the best online transaction I've ever made.
Just Got My New T-rex Brushless It Really Scared Me To Death !!! agapornis Mini Helis 22 Dec 15, 2005 05:53 PM
Just got my kyosho HOR in the mail. Have a few questions before I build it. ^jynx^ Motorcycles 10 Jun 18, 2005 09:23 PM
My Kyosho T-33 Flew!!! Brill 1 Electric Ducted Fan Jet Talk 5 May 17, 2005 04:07 PM
Help! HELP!!!!!!! Just killed my Kyosho T-bird Vamooska Power Systems 11 Mar 26, 2004 07:59 PM
Kyosho T-33 Best Battery roadhor Electric Ducted Fan Jet Talk 11 Feb 23, 2002 05:29 PM
