Old Jun 15, 2014, 08:02 PM
Traverse City, Mi.
Joined Oct 2003
Need help with Taft viperjet!
I just bought a Taft Viperjet. I cannot get the motor to spool up to top RPM...I've tried 3. Different 6 cell batteries, and always the same. Jet barely gets off the ground, and flies at best, just above stall... I 'm using a Futaba 10 c radio.....how do I fix this problem? Please email me at kmay21@ aol.com
Kim Couturier is offline Find More Posts by Kim Couturier
Old Jun 15, 2014, 09:13 PM
EDF Jet Jam 2015, May 28-31st
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Do you have a watt meter?
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Jun 15, 2014, 09:23 PM
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
I wonder if the ESC needs throttle calibration?
Try having full throttle selected when plugging in battery. Then select idle once the ESC beeps the first set of beeps.
Also check that the throttle channel has 100% travel in both directions.
4stripes is offline Find More Posts by 4stripes
Old Jun 15, 2014, 10:14 PM
Traverse City, Mi.
Joined Oct 2003
Taft viperjet
I'll try that. I don't know much about electrics....don't have a watt meter...
Old Jun 16, 2014, 04:43 AM
I beat the man from Atlantis
United Kingdom, England, Lincoln
Joined Dec 2013
yep, you need to do the throttle calibration...then it SHOULD be ok!!
Coddy is offline Find More Posts by Coddy
Found Taft viperjet fuse and nose gear indydrt33 Aircraft - Electric - Jets (FS/W) 1 Oct 13, 2014 11:08 PM
For Sale Taft Viperjet stock 6s power system Tam jet struts. Chopper1 Aircraft - Electric - Jets (FS/W) 4 Sep 17, 2014 05:27 PM
Sold stock Taft viperjet 6s power system Chopper1 Aircraft - Electric - Jets (FS/W) 0 Feb 10, 2014 11:54 AM
Sold Taft Hobby Viperjet Mannyman535 Aircraft - Electric - Jets (FS/W) 1 Dec 29, 2013 08:34 AM
Sold Going to keep it!! Taft 90mm Viperjet BNF 3rd-dem Aircraft - Electric - Jets (FS/W) 8 Dec 21, 2013 06:03 PM
