Old Dec 09, 2013, 05:00 AM
Grow old disgracefully!
dickw's Avatar
Luton, UK
Joined May 2006
HS-7115TH question
Is it OK to use this servo with a 2s Lipo Rx battery or do I need to put a diode in series?
Dick
dickw is offline Find More Posts by dickw
Old Dec 09, 2013, 02:29 PM
Joined Aug 2002
Originally Posted by dickw View Post
Is it OK to use this servo with a 2s Lipo Rx battery or do I need to put a diode in series? Dick
Yes, it is OK to use this servo with a 2s Lipo Rx battery, diode not required.
. Servo - Operating Voltage Range - (Hitec) usuage with NiMH, Lipol & A123 batteries.
extract "update Oct10"
High Voltage Digital Servos now offer 7.4V performance. This means that you can drive these servos using a 7.4V Lipo
without having to step the voltage down to 6 volts (however the servos can still work well on 6V)
. HS-7115TH High Voltage, Titanium Gear Slim Wing Servo
. Hitec HS-7115TH
Features:
- 2 cell Li-Po (6 cell NiMH) Compatible
- High Standing Torque
- Gold Plated Connector
- Ultra Slim Wing
- Durable Titanium Alloy Metal Gears with Dual Ball Bearings
- Programmable Digital Amplifier w/ MOSFET drive
Much more information available below sub section:
"Servo - Digital & Brushless Servo, Programmers and Software" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline Find More Posts by A.T.
Old Dec 09, 2013, 03:02 PM
dickw's Avatar
Luton, UK
Joined May 2006
Thanks Alan.
I was looking for a voltage range that included 8.4v, but I guess Hitec is using 7.4v as the nominal voltage for a 2s Lipo which can lead to misunderstanding.
I have already seen warnings against using it on 2s Lipo without a diode, hence my question, so I wish Hitec would make the voltage range clearer on their website .
Dick
Old Dec 10, 2013, 07:18 AM
miche's Avatar
Joined Oct 2008
I use them with lipo 2S 450mah (no diode) in the Enigma hotliner, more than a year, no problem.
Regards
Dick
miche is offline Find More Posts by miche
Old Dec 10, 2013, 08:53 AM
dickw's Avatar
Luton, UK
Joined May 2006
Regards
That's good to hear Miche. Mine are going in a Speedfire 2 and I plan to use 2s 350 Lipo for Rx and servos.
Thanks again for the confirmation.
Dick
Question OS 46 AX II HS Needle Adj and Front Bearing Question AWAvistar Engines 4 Dec 08, 2013 12:38 AM
Question Hs-7955 question Ohio AV8TOR Hitec/Multiplex USA 1 Nov 29, 2013 08:37 PM
New Product In stock! Hitec HS-7115TH Ultra Slim Wing Servo! ServoCity ServoCity.com 0 Jul 06, 2012 04:21 PM
Discussion HS-805 or HS-815 question jrbackus Radios 2 Feb 18, 2008 05:08 PM
Discussion Weasel Pro and HS-65 vs. HS-81 Servo Question? rcGman Slope 33 Aug 05, 2007 04:12 PM
