Old Nov 01, 2012, 11:42 AM
Greece, Peloponnisos Dytiki Ellada ke Ionio, Thouria
Joined Oct 2010
Help!
How I can do lighter blades
Hello
Every time Im' making my own blades I face the problem of the CG which located
far above the center line between the motor axle and the stab.
This forse me(in order to have the "F"from the motor about "near" to the CG )to increase the down thrust a lot.
So Im' asking for ideas to help me making lighter blades than the clasic way we are making.
All cool ideas are acepted
Thanks in advance...
Fanis.
F.FANIS is offline Find More Posts by F.FANIS
Old Nov 03, 2012, 03:55 PM
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Fanis,
I struggled to understand, am I correct in thinking your CG is too high? if so why not add weight below it?
Regards
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Nov 04, 2012, 11:44 AM
Joined Oct 2010
lighter blades
Hi Rich...
thanks for your response...
Yes, because the blades we are making are rather "heavy" I wand to know if there is another way of making our blades lighter.
I mean for example to use other materials or "building" in a way the blades...
Rich, the whole thing is about to have our CG lower near to the thrust line of the motor...(I think so)
You are a very experience builder and perhaps you can give me some ideas.
Thanks in advance.
yours Fanis.
ps. dear Rich I saw a very interesting video of yours (all your videos are ) with a pusher A/G named ARIAN 2-150 (if I remember correctly the No ).
Have you finished the project ? If it is so I wand to inform me how can I have (from you) the plans .
By my opinion it is a superb pusher.
Fanis.
Old Nov 05, 2012, 06:01 PM
Jockadopolus's Avatar
Scotland
Joined Jan 2010
Hi Fanis I have seen blades lightened by drilling large holes in the balsa trailing part I will look for pictures and post
The Avian Pegasus thread is here http://www.rcgroups.com/forums/showthread.php?t=1581651
Jockadopolus is online now Find More Posts by Jockadopolus
Old Nov 05, 2012, 07:44 PM
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
I am using built up blades on many of my models ,using balsa and ceder..........
Chris...........
britinoz is offline Find More Posts by britinoz
Old Nov 06, 2012, 10:13 AM
Joined Oct 2010
lighter blades.
Thanks Joe ,Crish, YES this is what I had in my mind to do but first I wanded to know if somebody else has done something similar .
Both ideas are clever .
In this way the blades ,perhaps,does not need extra weight in the frond and they
would be much lighter which is a must to our flying machines.
I will try to do something similar and I will let you know
yours friendy Fanis.
ps . Joe thanks for the thread I will see it and I will come in touch with you...
Discussion How do you place a value on a rare model when you can't ever one for sale? garyzda1 Trader Talk 9 May 29, 2012 09:15 PM
Help! Dle 55 how can do I use crank pressure for smoke? jamesrini Engines 3 May 17, 2012 04:15 PM
Discussion Dymond D47 servo, Which version do you have on hand, how can you tell??? TDboy Hand Launch 5 Apr 21, 2012 02:26 AM
Discussion Spot landing Blade mcx on a can of pringles - how many can you do? jblackmore Coaxial Helicopters 3 Dec 28, 2008 05:37 PM
Question How do you produce lighter and lighter models??? snakeX2 Scratchbuilt Indoor and Micro Models 19 Sep 30, 2004 11:29 AM
