Old May 30, 2012, 09:19 AM
Joined May 2012
Help!
damaged v4? or what?
Welcome.
I purchased a set of Eagle Tree almost complete (OSD Pro. Altimeter v4. GPS v4. Guardian Stabilization. Elogger v4 heavy duty)
when you connect it turns out that the Guardian does not work, it does not see the program on a PC, you can not upload new firmware, none of the LED is not lit.
OSD Pro none of the LED is not blinking.
Altimeter and osdpro and elogger can upload new software.
The gps still flashing yellow LED.
marcin_ is offline Find More Posts by marcin_
Old Jun 02, 2012, 03:02 PM
billpa's Avatar
Joined Nov 2003
Hi Marcin, sorry for your issue.
The OSD Pro does not have an LED.
If the Guardian's LED is not blinking, that means it is not getting power. is it possible that it is not connected correctly? If you connect only the Guardian to the eLogger (without the OSD pro and without the altimeter) does the Guardian's LED blink? And, does the Guardian show up on the "Firmware Control" page in the PC software at this point?
billpa is offline Find More Posts by billpa
Site Sponsor
Discussion What do you do with all the damaged planes you aquire? xrx1113 Electric Plane Talk 38 May 29, 2013 07:25 PM
Help! It helps Xaircraft X 650 V4 or V8? Xaircraft FC1212-P or DJI Naza? Ruyman Multirotor Talk 2 May 20, 2012 09:50 PM
Discussion Hooked my ESC & battery up backwards, what's damaged? flyboy320 Power Systems 5 Nov 23, 2011 10:04 PM
Yippee! Flying a cx2, lama v3, or v4 outside, what you need? leethetreeguy Coaxial Helicopters 2049 Aug 01, 2011 02:26 PM
Discussion What to get? Lama v4, KOB, or other? coby Coaxial Helicopters 21 Aug 10, 2009 01:28 AM
