Old Oct 20, 2013, 12:39 PM
Burlington, NJ
United States, NJ, Burlington
Joined May 2009
Yeah I have about 15 flights on mine and they only thing that comes down hot is the motor. Which is temping at 115ish. I let it sit for 8-10 minutes and then im back in the air. Having wide open throttle for most of the flight could kill the brick but I'd like to think if your only flying for 5 minutes you'd be ok. I only go up for 5 1/2 minutes and use about 80% throttle most of the time. At least you got a free replacement. Trying shorter flight and keeping the throttle around 75-80%.
joeyhatch11 is offline Find More Posts by joeyhatch11
Old Oct 20, 2013, 12:51 PM
United States, GA, Woodstock
Joined Jul 2013
This happens at about 60% throttle for 3-4 minutes is the problem. Like I said, the ESC really has no way to cool down from air flow
Coopier is offline Find More Posts by Coopier
Old Oct 20, 2013, 03:53 PM
Burlington, NJ
Joined May 2009
Not sure what to tell yo, I don't know if cutting into the plane is the best idea or if it'll even help much. I dont know if this was heat related or now but I did recently loose my rudder controll. It no longer works but I'm not too concerned because everything else is still fine plus I'm looking into doing a full brushless conversion soon anyway. Was going to do with the signal converter but for another $40 I can get 3 servos and a new Tx/Rx and be much happier, plus fly longer.
Old Oct 20, 2013, 04:37 PM
Joined Jul 2013
So I just finished flying and tried out the 300. The plane didn't even make it a full two minutes. The same problem happened like the first time the ESC went out. The motor dies but I can still control the elevator / ailerons / rudder. I've had this plane for about 2 months now and have only able to fly it a total of 6 times, each flight no longer than 5 minutes due to this issue. Now this ESC is completely burnt just like the first one. I'm not sure what I need to tell Cox about this.
Old Oct 20, 2013, 07:33 PM
yank and bank!!
Joined May 2013
So the circuit board is visibly burnt? Are you using the stock battery?
I would contact cox/hobbico and see if they'll replace the whole plane if the board is fried. Never happened to me, even when I've had motors burn out.
failboat is online now Find More Posts by failboat
Old Oct 21, 2013, 08:41 AM
Joined Jul 2013
You can see a smokey black color from where it looks like it puffed out some smoke. It was extremely hot to the touch. This happened to both ESCs. I've sent them an email and we will see what happens.
New Product Cox Hobbies Extra 300 EP 2.4GHz RTF 20" huckleberg Scratchbuilt Indoor and Micro Models 6 Mar 19, 2011 05:12 AM
Sold Extreme Flight 78" Extra 300 Electric RTF *CHEAP* Z06kal Aircraft - Electric - Airplanes (FS/W) 5 Nov 27, 2010 08:59 AM
Sold Extreme Flight 78" Extra 300 RTF Z06kal Aircraft - Electric - Airplanes (FS/W) 11 Nov 24, 2010 08:34 AM
Discussion cox 049 for rcpowers extra 300? jwalker590 1/2A Planes 26 Nov 03, 2010 10:36 AM
Discussion cox 049 rc on a rcpowers extra 300 balsa wood 3d? jwalker590 3D Foamies 1 Oct 01, 2010 10:56 AM
