Old Aug 28, 2010, 05:19 AM
nick 30
nick30head's Avatar
Joined May 2009
spark eliminator
here are some photo's of the spark eliminator i hve made from a diagram found on this forum
i have used male & female 3.5mm bullet connectors, 14g wire and 20 ohm, 0.65w resistor's to make this
all wire's MUST be soldered together to get a strong hold and contact, i tried to video it working but the sparks did'nt show up well
nick30head is offline Find More Posts by nick30head
Old Aug 28, 2010, 06:49 AM
Bradles's Avatar
Australia, VIC, Sunshine West
Joined Jul 2010
i dont mind the hearing the large crack!! keeps you on your toes, lol
i get this with 2s packs, cant imagine how large it is with 6s packs
Bradles is offline Find More Posts by Bradles
Old Aug 28, 2010, 09:06 AM
nick 30
nick30head's Avatar
Joined May 2009
massive, will be doing this to my 3s packs aswell
Old Sep 26, 2010, 09:03 AM
Closed Account
Joined Jul 2006
spark eliminator
Also on Offshore is a indepth info on this subject. I copied both sites info and both are good!!!!
Mikedown is offline Find More Posts by Mikedown
Old Sep 26, 2010, 07:47 PM
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
You should hear the crack on 12s. Nearly deafens ya. Not mine mind you, but one of our club members.
Some say that the spark is a healthy thing. It proves that your caps are in working order, as that's what causes the flash, the inrush current charging the caps.
Cheers.
Paul.
785boats is offline Find More Posts by 785boats
Old Sep 27, 2010, 01:55 AM
nick 30
nick30head's Avatar
Joined May 2009
i completely forgot about this thread, i've installed safety loops om my boats and use 6mm bullets, certainly reduces the spark
Old Sep 29, 2010, 04:39 PM
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
hi Nick.
If you have installed safety loops, an easy way to add the resistor is to solder it across the wires inside the boat.
That way, as soon as you plug your batteries & ESC together (with the safety loop out) the circuit is complete & the caps charge. No extra messy wires or connectors.
Just be sure to remove the batteries at the end of the day. Don't leave them connected for a week as I did once as the resistor will discharge your pack. Mine went down to 1.7V/cell. But they came up OK as it was such a light discharge rate. A picture to show the resistor.
Cheers.
Paul.
Old Sep 29, 2010, 05:56 PM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
I read somewhere that the VALUE of the resistor was IMPORTANT because it could trick some ESC auto-LVC setting to not function properly. Did you notice anything about this.
freechip is offline Find More Posts by freechip
Old Sep 29, 2010, 07:45 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Electrons will take the path of least resistance, which will be through the main bullet and not the resistor. If you're really concerned about it, you could always unplug the resistor loop after plugging in the main bullet.
wparsons is offline Find More Posts by wparsons
Old Sep 30, 2010, 01:47 AM
nick 30
nick30head's Avatar
Joined May 2009
i've never noticed that to happen
Old Oct 02, 2010, 04:09 PM
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Freechip.
That seems to be with the Castle Creations & Mamba ESCs. I don't thnk the Shultz like a resistor either.
Here's a calculator for the resistor & connections.
Note that it says it is mainly for high voltages. Anything up to 6s should be fine without them.
I don't use resistors on any of my boats. I only tried it on the little mono but I've sold that one.
http://scriptasylum.com/rc_speed/_nospark.html
Paul.
Discussion Eliminator Time Getmore Rc Electric Ducted Fan Jet Talk 58 Nov 07, 2010 07:49 AM
Discussion First run of BH Hansen Boat Motor. NO spark? Excogitate Racing Boats - Internal Combustion 9 Aug 24, 2010 12:53 AM
Discussion First run of BH Hansen Boat Motor. NO spark? Excogitate Dock Talk 3 Aug 22, 2010 08:32 PM
For Sale Eliminator 90RTF(DS51/HV85/Nue1515 1.5Y) MrMac98 Aircraft - Electric - Jets (FS/W) 0 Sep 09, 2009 07:08 PM
Discussion A Connector Spark Eliminator Chophop Electric Heli Talk 3 Oct 17, 2008 09:35 AM
