Old Aug 31, 2013, 09:38 AM
Joined Aug 2013
How much of a gap should I leave between the rudder and the fin? Same gap when installing the elevator to the stab?
Should the gap be enough to allow 90 degree movement?
flair is offline Find More Posts by flair
Old Aug 31, 2013, 10:50 AM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
NO! you only need maybe 10 to 12 degrees of deflection on your elevator!
your not building a 3D machine here.
whiskykid is offline Find More Posts by whiskykid
Latest blog entry: Sig Mustang 450
Old Aug 31, 2013, 11:04 AM
Joined Aug 2013
Wow so the clearance must be fairly tight... 1/16 inch is good?
Old Sep 01, 2013, 01:22 AM
team sleprock
whiskykid's Avatar
Joined Dec 2009
sorry was busy today, but ya a 1/16th would be good!
Old Sep 01, 2013, 05:03 PM
Master of the Figure "9"
hogflyer's Avatar
Wichita, Kansas
Joined Dec 2005
You generally want the gaps between the two surfaces to be as tight as possible without binding.
Hogflyer
hogflyer is offline Find More Posts by hogflyer
Old Sep 03, 2013, 01:54 PM
Joined Sep 2013
One of the easiest ways i found to install cloth hinges is to insert 2 sewing pins in the middle of the hinge ( one on each edge). That will ensure you get half into the structure and half into the control surface. It also gives you a tight fit and room for movement. After you glue the hinges you simply remove the pins. Dont forget... You dont glue them until the plane is covered.
Mack53 is offline Find More Posts by Mack53
Old Sep 05, 2013, 01:20 AM
YAY the tourists are GONE
United States, MA, Sandwich
Joined Feb 2010
When I built the Eagle 2 it came with the CG all plastic hinges. I have to say that those hinges are the worst out off all the possible hinges.
Kit_Builder is offline Find More Posts by Kit_Builder
Discussion need very basic info on multi-copters to begin reading Jimse Multirotor Talk 0 Jan 12, 2011 03:01 PM
Discussion need very basic info on multi-copters to begin reading Jimse Electric Heli Talk 0 Jan 12, 2011 01:37 PM
Discussion Beginning 3D - How to learn the VERY basics?? sgomes 3D Flying 14 Jun 18, 2010 12:19 PM
Discussion A very good site for beginers SoliSab Beginner Training Area (Aircraft-Electric) 0 Jul 14, 2008 11:28 AM
Cool a model very simple to begin? Bigsax Submarines 5 Jan 29, 2005 12:05 PM
