Old Jan 05, 2007, 05:51 PM
Watch out for that TREE!
Houston, Tx
Joined Oct 2006
Torque roll
I've been flying my estarter with a GWS 9050HD prop, and today I stuck a 8060HD on it. Seems with the 9050 I was always having to correct for straight/level flight. Change in throttle position would throw the trim off, a lot if throttle changed a lot. This didn't seem to be a problem with the 8060, flew straight and level no matter what throttle position was set. Is this torque roll? Or was I just imaging it along with the pink elephants and purple gophers.
John
GD5015 is offline Find More Posts by GD5015
Old Jan 05, 2007, 06:34 PM
Livermore, CA
Joined Sep 2004
Sounds like it to me. My GWS 109 would fly nice and stright with the stock motor. Since I got one with a Axi outrunner and bigger prop, I cant launch it full power, without it wanting to roll into the ground!
Butch777 is offline Find More Posts by Butch777
Old Jan 05, 2007, 07:41 PM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
The Estarter is rudder -elevator?
Changes in thrust will have effects on the directional trim.
And changes in lateral trim are more likely to be the result of wing warps than torque on these low powered planes.
Sparky Paul is online now Find More Posts by Sparky Paul
Old Jan 05, 2007, 07:58 PM
Houston, Tx
Joined Oct 2006
SP, it is full 4 channel with a skatty 400xt, 1250 3s lipo.
John
Old Jan 06, 2007, 02:51 AM
Christchurch, New Zealand
Joined Jun 2006
It's torque roll, you're not imagining it. Fullsize planes do it too, and so will the smaller prop, it's just lessened it enough so you don't notice anymore. If you have a computer radio you can make it go away with a bit of throttle to rudder mix.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Jan 06, 2007, 08:01 AM
Texas Buzzard
Texas Buzzard's Avatar
McAllen,Texas
Joined Mar 2004
If any of you have flown full-sized planes with a tailwheel ( Aeronca Champion, etc.) you noticed that beginning the take off roll as you applied throttle the nose would swing to the LEFT. We apply a bit of Right rudder to maintain a straight path down the runway. THAT WAS TORQUE that swung the nose to the left. From the pilots position the prop was turning clockwise ( a right handed prop.).
With overpowered glow RC planes when making a slow approach and the Jamming the throttle to full power suddenly, the plane will roll to it's left, sometimes even do a diving Left turn....a no,no. Apply throttle smoothly and be ready to give a tiny bit of right rudder and some right aileron to compensate....smooth application of throttle is a good practice.
Newton's Third Law: For every force applied, there will be an equal but opposite force. Or something like that! **** The right hand prop is forcing the air to move ( that's it's job !!). The prop is moving clockwise. The prop is resisted by the air. The air pushes back against the prop. Since the prop is attached to the plane throught the shaft..... the prop is forcing the shaft to rotate in a counterclockwise direction. ** So the entire plane is forced to roll left by a right-handed prop. Use a tad of right rudder!!
Lots of "old-timers" used 2 to 3 degrees of RIGHT THRUST to compensate for TORQUE. It is standard practice on low speed aircraft. Try right thrust- you might like it!!!
WARPS: A small warp in a wing or a misaligned tail surface will be quite noticable at higher speeds. The effect of a warp may not show up at low speeds.
Lets say our WW II Thunderbolt's left wing has a warp so that the trailing edge is warped down ( it has some positive incidence). At high speed with controls at neutral this plane will have a tendency to have a Right Roll. But at landing speed it's rolling tendency will not show up as much.
The Moral of the Story IS Warps Are BADD. Take a few minutes more to build straight and check for warps 2 times then check one more time. Remove them!
Texas Buzzard is offline Find More Posts by Texas Buzzard
Old Jan 06, 2007, 10:09 AM
Frederick Maryland USA
Joined Jul 2004
Although what you noticed is often commonly called torque roll there are actually alot of different forces at play. As explained in Scott Stoops' "Mastering Radio Controlled Flight" the yaw to the left is called P-factor. This yaw occurs when the angle of the nose is changed and is due to differences in thrust produced by the propellor's blades when their angles of attack change moving upward or downward in their rotation. With the standard direction of rotation, when the nose point up the yaw is to the left and when the nose points down the yaw is to the right. This can be conteracted using the rudder.
There is also an effect of uneven airflow (spiral airstream) that tends to push more on one side of the rudder also causing a yaw to the left. This effect can be countered by a few of degrees of angle in the motor mount.
As you have noticed, these effects (along with gyroscopic precession) are reduced with a smaller prop diameter.
Torque is a seperate beastie and will instead roll (not yaw) the plane and has to be handled by careful application of the throttle on take off or any time the airspeed gets too low to provide good control authority.
Duetto is offline Find More Posts by Duetto
Old Jan 06, 2007, 10:14 AM
Fly Fly Fly Crash
Dragon 2's Avatar
Montrose Co
Joined Aug 2005
gastonmc@sbcglo
Well put.I think that will help alot of people.
Dragon 2 is offline Find More Posts by Dragon 2
Old Jan 06, 2007, 10:39 AM
Texas Buzzard
McAllen,Texas
Joined Mar 2004
Duetto, oh yes - the "p" factor. All that you posted was correct. You are quite knowledgeable.
But since this thread seemed to be for the beginner, er...ah, wanted to keep it as simple as possible , yet give enough info to be useful.
Right motor/engine thrust and an application of right rudder + a judicious ( gentle) increase in the throttle setting just might save a rebuilding job for someone.
#1 Check for Warps, #2. Advance throttle gently, #3 Be ready to apply a bit of right rudder and or right aileron when acceleration from low speed.
Did you ever see a video of a WW II prop job making a take off from a carrier w/o the use of a catapult? You will see a generous use of Right Rudder! It is real not imagined. Thanks Duetto for completing this concept. The "p' factor is easily seen in a high-powered Free Flight as it accelerates. The swirlng airstream hits the pylon and forces a roll. Assume a free flight with a pylon (ala Playboy)
Old Jan 06, 2007, 11:01 AM
Joined Jul 2004
I didn't want to complicate things unduely either but with relatively cheap brushless motors available many beginners are flying quite powerful planes. Having "torque rolled" a couple of my planes on take off before educating my left thumb, I didn't want anyone to think that it was always enough to simply counter with a bit of trim or rudder application without taking the throttle into account.
Old Jan 06, 2007, 11:28 AM
Ascended Master
Palmdale, CA
Joined Oct 2000
P-factor problems are more often encountered with models than "torque rolls" because we abuse the takeoff speed... taking off too slowly, at high angles, or throw too steeply when hand launching.
With proper technique, such effects go away.
For the ultimate "torque roll", one of our test pilots had flown the Grumman F8F Bearcat in the Navy. He said they delighted to take it straight up, pull back on the power until it lost forward speed, and cram on full power... it would torque roll for real!
Old Jan 06, 2007, 11:50 AM
Houston, Tx
Joined Oct 2006
Wow, ask for a crumb and get a whole loaf. Thanks guys, for the info. The effect seemed to be most noticable when jamming throttle full for aerobatics (at least what I call aerobatics), nose would pull up and roll out. Nice to know why.
Thanks again,
John
Old Jan 06, 2007, 12:16 PM
Joined Jul 2006
I think true torque roll is what you experience when you turn on an electric drill and it wants to roll left. A drill rotates the same way as the prop on a plane, and the torque produced while it's either accelerating, or counteracting an applied force, acts to spin it in the opposite direction.
I'm not a physicist though, and it's really only a thought I had. I could be way off.
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Jan 06, 2007, 09:43 PM
oh crap! did I do that?
JTStone's Avatar
cochran,GA
Joined Oct 2005
GD I have the exact same setup as you and I too have experienced this mainly when taking off at full speed. I have mine trimmed to fly level at about 1/2 to 2/3 throttle so that I have some power left to get out of trouble if I need it. I usally fly a few mistakes high as I have found that this plane likes to tip stall at low speed aileron induced turns.
JTStone is offline Find More Posts by JTStone
Old Jan 07, 2007, 10:46 AM
Houston, Tx
Joined Oct 2006
JT, I also, have noticed the tip stall. I thought it was all the epoxy in the nose & tail dragging it down. I am kind of surprised after reading how docile a plane the estarter is. I guess thats what happens when you ASSUME to much. Gotta stop taking things for granted, so far I have been lucky that it hasn't bit me harder in the butt, but the SS taught me so many bad habits. That thing will fly no matter how it is setup, I think.
Engage brain, then think, TWICE, before you do.
John
Question ultra stick 40 torque-roll Dan and son Bry Competition Aerobatics 0 Jul 16, 2002 01:55 PM
My best torque roll ever! DeaninMilwaukee Foamies (Kits) 7 Dec 20, 2001 03:17 PM
Aerobatic 'park flyer'? Hover, torque roll, etc? Any ideas what to get? Joe B Parkflyers 25 Nov 09, 2001 11:44 AM
Torque Roll Question JasonG Electric Plane Talk 5 Sep 25, 2001 05:24 PM
"Torque roll" with Twin-Jet Jurgen Heilig Foamies (Kits) 23 May 17, 2001 05:06 PM
