Old Jul 26, 2014, 12:33 PM
army_eod's Avatar
United States, PA, Windsor
Joined Jan 2010
Brodak Oriental ARC
Please recommend an engine for this model.
I am thinking O.S. .46 LA-S
Also thinking lots of other engines.
Recommendation?
Fox .35?
O.S. .40
It seems on the bench with the .46 LA I am consuming about one oz per minute. With a 4 oz tank (recommended by Brodak plans) that is a 4 minute flight at best...not long enough. I can look at a bigger tank, of course.
Seems the .46 has plenty of power. I saw a video of someone flying the Oriental with the O.S. 46 and lap time was about 4 seconds; pretty fast.
army_eod is offline Find More Posts by army_eod
Old Jul 26, 2014, 03:49 PM
Friend had an Oriental ARC, and it looked pretty good to me. If I were to build one, I would install a Fox stunt 35, the engine it was designed for. Back when I was flying, I could fly the pattern with 4 sec lap times, but slower than that is better if the airplane and engine are happy. Around 5 sec is the usual recommendation. A four oz tank is pretty standard for a Fox.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Jul 26, 2014, 04:29 PM
army_eod's Avatar
Joined Jan 2010
Jim; I was thinking of using the Fox. I have four of them. I can keep it light. I am old school. I appreciate the recommendation. I will go with the Fox. I can use the .46 for something else.
Old Jul 28, 2014, 08:02 AM
Joined Sep 2011
Fox 35 likes 35-40oz... the OS Max 35S likes up to 45 oz... My own experience with the LA 46 has been not as good as I had hoped, I have not given up on this engine... it could have been my fuel ... the Brodak 40 is impressive. Lap time is a funny thing... if the plane is heavy then you will have to fly it on shorter lines at a faster speed... my own Oriental weighs 43oz, I am using 59 ft eye to eye lines and lap times are right around 5-5.1 sec per lap.. I ended up using a 10x6 TF Power Prop. The LA 46 is a lot of engine compared to the little 35S... I was using a Dixon FP 40 in my Humongous with no problems... my best score in Advanced was made on a Dolphin that had gone lean and was flying what I would estimate to be 4.5 sec laps.. go figure...
JC Johnson is offline Find More Posts by JC Johnson
Old Jul 29, 2014, 03:31 AM
army_eod's Avatar
Joined Jan 2010
Cancel Christmas; Just decided to go electric with this Oriental...
Old Jul 30, 2014, 05:37 PM
Joined Jul 2014
Dee Rice designed this airplane. If you would like to contact him, I am sure he would be able to answer any power questions you may have. He has two of them and both look great.
His email address is golfrice1@yahoo.com.
Good luck,
Colin
cander06 is offline Find More Posts by cander06
Old Aug 02, 2014, 03:02 AM
robinson727
USA, MS, Byhalia
Joined Nov 2010
Recommendation?
Fox .35?
O.S. .40
We used an OS 40 spinning a 11X7.5.. Aftermarket delrin venturi insert with ST needle valve.. (origional.. no aftermarket crap) You need the largest tank that will fit.. 6oz??
5.1 to 5.2 sec. laps on 60 foot 012" lines..
Ours was fun.. until it quit on an overhead.. aftr 3 flights last week with my son on the handle. Rats..
Now ?? ARF Nobler with a Turnigy 3536 X 1200 kV spinning a 10X 5 and a 3s 3000mah pack.
eFligjt timer and a Turnigy 40A esc.. We test flew it today and it's a hoot..
Quiet.. and reliable.. 2 lb. 8 oz..
robinson727 is offline Find More Posts by robinson727
Old Aug 02, 2014, 04:37 AM
army_eod's Avatar
Joined Jan 2010
Well the OS .46 sucks up fuel very fast and a 4 oz tank will not allow enough time for the pattern. Crazy thought; if a Fox .35 stunt will fly this ship, then the OS .25 LA swinging a 10-5 should fly it as well. The OS .25 makes as much power as a Fox .35 on paper and is very reliable and gets a real good breaking run. What say you? OS .25 for the Oriental?
Old Aug 02, 2014, 08:20 AM
BWA
Joined Jun 2012
I would, but, then again, I like a little bit of slack in the lines.
BWA is offline Find More Posts by BWA
Old Aug 02, 2014, 09:11 AM
BWA
Joined Jun 2012
sorry, double post....
Old Aug 02, 2014, 12:07 PM
Old Timer
The Kiwi's Avatar
USA, TX, San Antonio
Joined Jun 2010
I've had a couple of them, and wasn't well impressed. Of the more current engines, the Brodak 40 would be fine. An Oriental is a 1950s design, and "small", while the Fox 35 is a 1947 design, and I'd rather match thr plane to the period powerplants, like an OS Max-S 35, a Johnson "S", or a Fox 3-bolt 25 stunt.
That latter one would do a pattern on 3 ounces, I think. The Johnson would need the full four ounces, and the Fox would fly quite a few extra laps at the end of the pattern on four ounces, unless the plane was a bit overweight. A custom tank for a Fox in a plane that size would be about 3.7 ounces' worth, offhand (I can't recall a Max-S 35's fuel consumption rates).
Kiwi
The Kiwi is online now Find More Posts by The Kiwi
Announce RTF Brodak Oriental gavoss Control Line 0 Jun 12, 2014 01:27 PM
Discussion Brodak ARC Cardinal and Oriental army_eod Control Line 3 May 14, 2014 10:41 AM
Sold NIB Brodak .15 c/l motor doug47 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 14, 2013 11:10 AM
Discussion Brodak/Norvel .061 engine questions MikeCr 1/2A Planes 5 Sep 22, 2013 12:59 PM
Sold Control Line .40 ARC kit - Brodak P40B Flying Tiger w/ OS LA 46 C/L NIB Engine midwest_plans Aircraft - Fuel - Airplanes (FS/W) 1 Oct 25, 2010 10:06 PM
