Old Apr 30, 2012, 04:06 AM
fball1208's Avatar
United States, PA, Latrobe
Joined Sep 2011
Help!
Hk 250 spinning out of control
My HK 250 that i just got set up just spins on the ground. As soon as i start spooling the Heli up it starts to spin uncontroabbly on the ground to the point it almost tips its self over. I cant stop the spinning by adding any rudder or increasing the head spead. HELP Please
fball1208 is offline Find More Posts by fball1208
Old Apr 30, 2012, 06:00 AM
Multi rotors and foamy planks
Biffa's Avatar
Bedford, UK
Joined Dec 2004
You more than likely have the gyro reversed.
Biffa is offline Find More Posts by Biffa
Old Apr 30, 2012, 10:36 AM
fball1208's Avatar
Joined Sep 2011
Ill have to try that, Have a new tail servo ordered to
Old Apr 30, 2012, 03:34 PM
fball1208's Avatar
Joined Sep 2011
Reversing gyro didnt help
Old Apr 30, 2012, 08:30 PM
Activist
Joined Jun 2009
Lettuce C hear:
Are the mains spinning clockwise looking down onto the HK?
Is the tail rotor spinning CCW when looking at it from the right side of the HK?
daveapplemotor is offline Find More Posts by daveapplemotor
Old May 01, 2012, 09:03 PM
fball1208's Avatar
Joined Sep 2011
The tail is spinning ccw will check the mains when i get home
Old May 02, 2012, 06:43 PM
fball1208's Avatar
Joined Sep 2011
Well the heads spin the right way but the tail wont hold still, This also started happening with my 450clone after i added an orange rx. Could thsi be the problem
Old May 02, 2012, 08:34 PM
wlee1017's Avatar
Joined Jul 2011
can you tell us what brand name and model tail rudder servo and gyro use. Do you configure and setup gyro for tail rudder servo.
actually, you may do few test to see if your tail servo and gyro are working proeprly. I suggest you disconnect motor wiring from ESC before doing test, safety.
1. Bypass gyro, connect tail servo to rx rudder channel directly. Apply left rudder stick and see if tail servo and slider respond. then apply right rudder stick and see if tail servo and slider move in opposite direction.
2. hook up your gyro as per wirng instruction. I assumed what you said, main rotor turn clockwise view from top and tail rotot turn ccw view from side, in front of tail rotor. Assume you set gyro in HH mode.
a. rotate heli head to right, your tail slider should move in and tail rotor blade leading edges deflect toward boom.
b. rotate heli head to left, tail slider should move out and tail rotor blade leading edges deflect away from boom.
3. check if you hook belt in reverse.
Then let's find out result and see what brand name and model of gyro and tail servo you use.
wlee1017 is offline Find More Posts by wlee1017
Last edited by wlee1017; May 03, 2012 at 01:17 PM. Reason: edit :check if belt hook up reverse
Old May 02, 2012, 08:35 PM
Joined May 2011
Are you moving the tail servo backwards or forwards to slow the spin. Which way is the spin cw or ccw? Adjusting the tail is a headache, I made kind of a spindle that I strap my heli to, to kinda get it into the ball-park, it is a BIG help, being that 250s are very sensitive the set-up. Also make sure your blades are balanced and tracked, plus allow ten minutes before flying to let your gyro adjust to temperature; mine's did the same thing.
hope this helps
mugen 1 is offline Find More Posts by mugen 1
Old May 03, 2012, 09:07 AM
fball1208's Avatar
Joined Sep 2011
I will try that wlee1017 when i get home. The gyro is the HK one they suggest and the tail servo right now is a hxt900 but i have an align digital on order. I will also try your suggestions when i get home Mugen1 Thanks
For Sale Hk 250 heli must go fordarrick Aircraft - Electric - Helis (FS/W) 1 Feb 24, 2012 12:41 AM
For Sale 250 Clone HK 250 GT AustinTatious Aircraft - Electric - Helis (FS/W) 5 Nov 06, 2011 12:26 AM
Discussion HK Buddy codes. (HK-250 parts included ) Ottomite Multirotor Talk 3 Aug 28, 2011 04:35 AM
Discussion HK 250 : hard to be cheaper for a 250 KABAL99 Micro Helis 638 May 11, 2010 01:39 PM
Wanted HK 250 / Exi 250 HeliStyle Aircraft - Electric - Helis (FS/W) 0 Apr 20, 2010 02:01 PM
