Old Mar 11, 2011, 11:27 AM
Joined Mar 2011
Question
SuperVee 27R Mods?
Are there any awesome substitutions for the rudder arrangement?
Cuz the stock setup sucks... or more metal upgrades, or anything LOL
EPB686 is offline Find More Posts by EPB686
Old Mar 11, 2011, 01:58 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Why do you think the stock setup sucks? It'll be easier to suggest something if you have a specific problem you're trying to fix.
wparsons is offline Find More Posts by wparsons
Old Mar 11, 2011, 02:45 PM
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
the only mod i have seen people do beyond different propellors, is upgrade to the lipo ready 60amp ESC from the aquacraft UL-1, and that more for the lipo LVC than for anything else. It would be cheaper to simply put a lipo saver on each of the battery connectors.
original ESC:
http://www.offshoreelectrics.com/pro...od=dh-aqum7005
UL-1 ESC:
http://www.offshoreelectrics.com/pro...od=dh-aqum7011
tsenecal is online now Find More Posts by tsenecal
Old Mar 11, 2011, 03:51 PM
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
The motor in the sv27r is a beast. The esc is the ok I added a lipo shield to mine. Cheaper then a new esc http://www.offshoreelectrics.com/pro...hld-32&cat=136
I had the blue can motor the gold can is suppose to be much MUCH better. With a grim 42x55 and some lipos that thing should be running pretty good. I will say it took some work to get it running correctly and she doesn't like speeds in the 50mph range and higher very much lol. I found that one out the hard way.
Diesel6401 is online now Find More Posts by Diesel6401
Old Mar 14, 2011, 06:40 AM
Joined Mar 2011
Do you not know how to read? Well I have a SuperVee that's why I think the steering sucks... That's my problem.
Then I was just wondering if there was any upgrades to convert the plastic on it. Seems the original had a nicer rudder setup, with all the aluminum.
Old Mar 14, 2011, 06:48 AM
Joined Mar 2011
Diesel, how does that lipo shield hookup? Can you post me a pic?
Also, what about running the UL-1 motor on the stock ESC? Would it be a little faster?
Old Mar 14, 2011, 09:55 AM
siberianhusky's Avatar
Canada, ON, Peterborough
Joined Nov 2009
Everything on the back of the SV27r is black anodized aluminum unless somebody changed it on you.
The boats work great stock if you have any clue how to set them up.
siberianhusky is offline Find More Posts by siberianhusky
Old Mar 14, 2011, 11:13 AM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
^^ 100% agreed! EPB686, can you post a picture of your setup? What exactly "sucks" about the steering? Not responsive enough? Racing style boats aren't meant to turn super sharp, and generally only turn well to the right.
Old Mar 14, 2011, 11:45 AM
Joined Mar 2011
It felt like a hardened plastic to me when I touched it, but y'all are probably right.
I just got the boat and ran it once and noticed it was leaking inside pretty bad. Even tested it in the tub. I was so pissed! So I just mailed it back to returned it and there supposed to send me a new one soon.
No it wasn't too responsive at all. It just seemed to only turn descent when slowing down a lot.
Maybe a longer rudder blade would help idk if they make something that would fit.
Old Mar 14, 2011, 12:01 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
It hooks it to the power side of esc.
* If you want a ul1 motor. It won't work on the stock esc. The stock esc will go POOF.
The ul1 motor was a lot better then the old blue can sv motor which is why I went that way. The gold can sv motor you should be great and I wouldn't change the motor. On a grim 42x55 should be a nice running boat. I would work on your steering issues and leaks before moving up in motors. JMO of course.
Here's my sv on ul1 power:
Aquacraft SV27 (1 min 52 sec)
Old Mar 14, 2011, 12:31 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
It shouldn't need any modifications to turn well. Did it have the turn fins on it? When you tried to turn which direction was it? Did it slide/skip, or just plow straight?
Old Mar 14, 2011, 03:43 PM
Joined Mar 2011
I have a grim 42x55 coming in tomorrow... just waiting on the boat to get shipped back. How much more speed does the new prop produce compared to the stock?
Yeah it had all the fins. It seemed to have a hard time turning both right and left....Maybe I just had a bad servo. But like I said I have a new one coming in, and hopefully the steering won't be a problem this time.
Old Mar 14, 2011, 04:25 PM
Joined Mar 2011
How you know that the esc can't handle that motor? I looked at the specs of both motor's. They seem the same.
kV: 1800
Input Voltage: 7-18.5V
Max Constant Current: 50A
Max Surge Current: 80A/5 seconds
kV: 2030
AquaCraft Marine 45 Amp Brushless Electronic Speed Control:
Input Voltage: 12-14 NiMH, NiCd cells, 8-20V input w/o BEC Output Current: 45A continous maximum, 60A surge maximum
BTW I got two 7 cell batteries for the SuperVee coming in tomorrow. I wonder how much faster it will be.
Old Mar 14, 2011, 05:19 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
kV: 1800
kV: 2030
Don't rely on those specs, they are pretty much unloaded specs. Put a eagletree data logger to that 2030 motor and you will find the truth. There is a reason the ul1 has 60amp esc in it!
* To run the 7 cell nimh you will need to dis-able the bec on the stock esc and run a external rx pack. It will run low 30s on those cells. You need lipos for any good results. With 2 2s lipos you will be in the high 30s low 40s mph range.
Old Mar 14, 2011, 05:23 PM
Joined Mar 2011
Ok I gotcha... Should I have a problem running 16.8v to that ESC?
For Sale Supervee 27R with 4600mah batts connorryder100 Boats (FS/W) 2 Dec 08, 2010 08:47 PM
Article AquaCraft SuperVee 27R Brushless RTR Boat Review Michael Heer Racing Boats - Electric 12 Dec 02, 2010 01:30 PM
Discussion New SuperVee 27R pictures Michael Heer Racing Boats - Electric 2 Jul 20, 2010 10:47 PM
Discussion Supervee 27 Brushless mods cuzican Racing Boats - Electric 66 Aug 10, 2008 12:06 AM
