Old Mar 31, 2009, 05:42 AM
Joined Oct 2008
High amp esc low amp motor
Hello,
Can I use a high amp esc in combination with a low amp motor?
I'm planning to reuse a 30A esc in combination with a 10A motor (peak 16A).
kreno is offline Find More Posts by kreno
Old Mar 31, 2009, 05:47 AM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Yes, no problem what so ever. You can always go bigger, the reason why most dont is to save weight. They want to make their plane as light as possible so getting a small & light weight ESC that just has enough amps to work with the motor is good for them.
freechip is online now Find More Posts by freechip
Proper ESC for Mega Motor 16/15/3 & Corona YOGIGURU Electric Heli Talk 3 Feb 04, 2004 01:13 AM
Qualcomm & Charger and ESC & Motor NIB Slow Riser Aircraft - Electric - Airplanes (FS/W) 5 May 13, 2003 06:55 AM
Connector between ESC & Motor Randall Power Systems 3 Mar 14, 2003 05:48 AM
FS: NIB 30 Amp ElectriFly C30 Mini High Power ESC with BEC J R Purcell Aircraft - Electric - Airplanes (FS/W) 2 Mar 05, 2003 10:46 PM
FS Zagi, 35 amp ESC, and 400 motor for $60 JordanS Aircraft - Electric - Airplanes (FS/W) 9 Jan 20, 2003 06:35 PM
