Old May 28, 2008, 08:09 AM
mguw's Avatar
Toulouse, France
Joined Jul 2007
interlaced and jerky images
Hi guys.
I am very new in FPV. Ordered and just recieved my first FPV equipement:
HeadPlay googles
KX191 PAL
2.4GHz 300mW TX/RX
and I am a bit disappointed because when panning quickly the cam, the image in the googles is very interlaced and jerky. I doesn't look like this on the videos you are posting.
Is that normal, or is there some adjusting to make?
thanks
Marcel
mguw is offline Find More Posts by mguw
Old May 28, 2008, 08:17 AM
I'm Ginger & called Adam
Ginger Adam's Avatar
Hereford, UK
Joined Oct 2002
Marcel,
Are you using a seperate power source for the video TX ?
Maybe post a quick example video may help?
Adam
Ginger Adam is offline Find More Posts by Ginger Adam
Old May 28, 2008, 08:25 AM
Impulze's Avatar
Sweden
Joined Jul 2004
Make sure u got the latest firmware for the headplay goggles. I know Håkon on this forum had interlace problem but got it fixed with the latest firmware 1.19r.
//Matte
Impulze is offline Find More Posts by Impulze
Old May 28, 2008, 08:36 AM
mguw's Avatar
Toulouse, France
Joined Jul 2007
Originally Posted by Ginger Adam
Marcel,
Adam
I am powering cam and TX on a dedicated lipo.
thnaks I am in 1.18 I'll give a try...
Marcel
Old May 28, 2008, 08:53 AM
mguw's Avatar
Toulouse, France
Joined Jul 2007
Thanks Impulze.
The upgrade did solve the de-interlace issue! much better now!
nevertheless it is still jerkier then on a TVset.
Marcel
Old May 28, 2008, 12:27 PM
Impulze's Avatar
Sweden
Joined Jul 2004
No problem
//Matte
Old May 28, 2008, 12:40 PM
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
I noticed some of the jerkyness you're describing. I noticed it after the flash. I think it has to do with a bad video signal and it's trying to fill in the blanks. It's not really jerky but more a noticeable flicker.
typicalaimster is offline Find More Posts by typicalaimster
Latest blog entry: Airframes Side-By-SIde
Old May 28, 2008, 01:15 PM
mguw's Avatar
Toulouse, France
Joined Jul 2007
Hi,
I took some time to analyse the problem, and it is worse then expected.
On my TVset I have a perfect fluid image without any glitch never.
when connected to the headplay, depending on the image content the headplay will have trouble synchronizing on the signal. (I use a KX191 PAL) this will cause jerks, freezes, glitches. With some content I can have only a frozen bad synchronized picture that will restart fine just by putting my hand in the picture.
using another camera the problem is existing but much much less, you could even not notice it.
HELP please.
I am not far from sending the whole thing back to HP. and take a FS!!!
Marcel
Old May 29, 2008, 03:03 AM
mguw's Avatar
Toulouse, France
Joined Jul 2007
Ok, glitches may come from TX/RX. I did connect on the TV and on the HP simultaneously and I could see the glitches on the TV. moving my hand in front of the camera can generate different 2.4GHz environement.
Nevertheless a reception glitch is very short on the TV (1 frame) but takes much longer on the HP. To me this is due to a low frame rate on the HP. I guess the frame rate in not better then 10FPS in composite mode. With a VGA or USB the fps are perfect.
can you confirm the low FPS ?
thanks
Marcel
Old May 29, 2008, 03:28 AM
Norway
I was having problem with really low fps (about 10fps) and de interlacing on my headplay unit. Upgrading solved both problems. But im experiencing some periods where the fps drops and the picture freezes abit. But it only last a couple of seconds. It happened once when i flew over a lake. I almost sh*t my pants
Im going to report this to headplay.com to see if they can come with another update to fix these problems.
Håkon Visnes is offline Find More Posts by Håkon Visnes
Old Jun 03, 2008, 08:23 AM
Joined May 2008
Headplay issues
Just been browsing thru many pages of forum stuff on FPV and goggle options; and from what i can determine - there is a choice between Fatshark and Headplay, but aparently the jury is still out on this...is this true. Does anyone out there have a definitive answer to this question? Would greatly appreciate some response....thanks in advance. Rob.
themagician is offline Find More Posts by themagician
Old Jun 03, 2008, 08:30 AM
mguw's Avatar
Toulouse, France
Joined Jul 2007
Hi,
I found some kind of work around and posted about here
http://www.rcgroups.com/forums/showp...&postcount=190
let's see how headplay support responds to that.
regards
Marcel
Old Jun 29, 2008, 04:33 PM
wep
https://vimeo.com/wep800
wep's Avatar
Joined Dec 2006
Received my headplay goggles and the picture is great but.....
I want to use it mainly for video flying.
The videosource is a PAL camera with composite out.
The problem I have is that I had a few FREEZES !!
So the picture stopped. Still a view but it stopped.
Frame freez happened about 3 times in 1 minute and lasted about 1 a 2 seconds.
This is (of course) not acceptable in video flying and is here already a sollution for??
The firmware I used is the 1.2a beta that sould have solved any PAL problems ....... I quess not?
You guys already found a sollution to this??
wep is offline Find More Posts by wep
Old Jun 29, 2008, 04:50 PM
No guts no glory
pratorian's Avatar
Quebec, Canada
Joined Sep 2007
in the other headplay thread you said you were gonna ask headplay, what did they say about it ?
Did you try with an other pal video source ? cable or whatever to see if youre having the same problem ?
Might want to try an other video receiver if you have one handy and an other cable... never know
I'm still using the original firmware forgot which version, I've never had any problems with it I'm scared something will mess up if I try to update
pratorian is offline Find More Posts by pratorian
Old Jun 29, 2008, 09:04 PM
wep
wep's Avatar
Joined Dec 2006
But you have a NTSC source right?
I still need to find some time to troubleshoot some more to reproduce these freezes.
It looks like that with playing movies there is no problem... but I have to try some more.
I haven't heard from Headplay yet; yesterday I wrote them again.
Which firmware are you running actually?
