Old Nov 04, 2007, 11:22 AM
Precision Aerobatics Team
demonGti's Avatar
South Africa, GP, Randburg
Joined Dec 2006
Build Log
Big 46" EDGE 540 (The next step after BFU)
Hi All
Those of you who built my BFU , or followed the thread, will appreciate the next level... a full-fuse Edge 540 with profiled wings and flight characteristics not unlike a balsa kit.
Constructed mainly from the same 10mm Polystyrene panels (similar to packaging foam) and a dowel to brace the wing. After having loads of fun with the BFU, I decided to build something with better gliding ability but still cheap and light. So hear it is.... with a wingspan of about 46" (1175mm) and 500 square inches of wing area. My proposed AUW is 800g including 2200 3S lipo and a 100g 1000kv outrunner.
I started the project by scaling the official dimensions from the FAI for their scale aerobatic F3M Edge 540 to suit a plane of 800g, then tweaked it for my own needs.
Direct links to Build guide PDF's:
Part 1
Part 2
Part 3
Part 4
Part 5
Addendum
CG is 76mm from the leading edge measured at the fuse.
demonGti is offline Find More Posts by demonGti
Last edited by demonGti; Jul 24, 2012 at 02:52 AM. Reason: Added links to build PDF guide
Old Nov 04, 2007, 11:36 AM
demonGti's Avatar
Joined Dec 2006
Cut and glue
I cut out the panels for the fuselage and tail feathers from 10mm polystyrene sheet and started glueing. I used 40mm thick firm polystyrene to shape the nose, I sanded the shape in with some 400 grit sandpaper on a sanding block.
The base for the LG was also made from thicker 40mm firm polystyrene.
To get the shape of the tail end of the fuse I had to cut some grooves out of the panel about 2 thirds deep to allow the foam to bend without breaking.
Latest blog entry: PA Addiction XL
Old Nov 04, 2007, 11:50 AM
demonGti's Avatar
Joined Dec 2006
My rudder and elevator were hinged with thin pieces of polycarbonate (works great and friggin' strong). The turtle deck is made from a 20mm thick panel which I tapered slightly toward to nose (sorry no pics of this process). A piece of thin ply was glued to the LG base from the bottom. The LG is a piece of ally which I bent into shape and screwed onto the ply. I covered the base of the LG with foam to conceal the screws (looks nice but I may regret this later)
I had to put some colour on this thing to see if it was gonna look the way I planned.
Old Nov 04, 2007, 12:07 PM
demonGti's Avatar
Joined Dec 2006
I will post a detailed PDF of the build process later once I have compiled it, but for now the Edge has grown wings. Here it is nearly complete, just canopy and electronics are missing. The motor is installed though, I glued a piece of thin ply to the inside of the nose with holes pre-drilled. The outrunner screws onto the ply from the inside using the ally cross mount that comes with most outrunners. Don't worry, the nose was carefully cut pre-assembly to achieve the correct thrust angle when the ply is glued in place, give or take a thin washer or two.
Old Nov 04, 2007, 12:13 PM
demonGti's Avatar
Joined Dec 2006
Servos are in... ESC installed and nearly ready to go!
Old Nov 04, 2007, 12:17 PM
demonGti's Avatar
Joined Dec 2006
All done!
The Egde is done, ready for a test flight, pilot, wheelpants and all.......
Old Nov 04, 2007, 12:38 PM
Time for another motto!
Utrecht, The Netherlands
Joined Jul 2006
May I be the first to demand those plans! Quick, it's a matter of life or life!
JelleB is offline Find More Posts by JelleB
Old Nov 04, 2007, 12:40 PM
ededge2002's Avatar
Newmarket,Ontario, Canada
Joined Dec 2002
nice job! what was the all up weight? good luck.....
ededge2002
one of mine(http://www.rcgroups.com/forums/showthread.php?t=757160)
ededge2002 is offline Find More Posts by ededge2002
Old Nov 04, 2007, 12:54 PM
demonGti's Avatar
Joined Dec 2006
My AUW came in at 809g after I added some bracing in the tail end of the fuse.
Old Nov 04, 2007, 04:11 PM
demonGti's Avatar
Joined Dec 2006
Dxf
Here is a DXF of the panels you need to cut out. It is not a pretty file, it is from my workings..... a nice clear scale PDF is in the pipeline. I just thought I'd post this in case anyone wants to get ahead start on cutting out the bits.
PS. you will need four of the same panels for the wings.
Old Nov 04, 2007, 05:47 PM
Blue Collar DLG Marshall
Greensboro, NC
Joined Jun 2007
OH BUDDDY, Man do I need some plans for this baby. I was going to upscale a Nano Shark for a buddy of mine but this is a much better choice. Please post some plans asap. I can figure most of it out from your excellent build thread but I need patterns to use to cut my parts.
Thanks, PP
Double Pappa is offline Find More Posts by Double Pappa
Old Nov 04, 2007, 06:02 PM
LI, NY
Joined May 2006
That's awesome, DemonGTI!
I'm looking forward to PDFs so, I can get building!
Adam
raceradam is offline Find More Posts by raceradam
Old Nov 04, 2007, 09:19 PM
shockflyer12345's Avatar
United States, MD
Joined Nov 2004
Nice job!
shockflyer12345 is offline Find More Posts by shockflyer12345
Old Nov 05, 2007, 12:38 AM
Just one more.......
Sim69's Avatar
Brisbane, Australia
Joined Nov 2005
This thing is going to be a HUGE hit! I've been searching the web for full fuse plans for an edge 540 ever since Tim H hinted at a full fuse version of his profile edge. Bring on the PDF!!!
I've subscribed to this thread!
Sim69 is offline Find More Posts by Sim69
Old Nov 05, 2007, 04:13 PM
golem's Avatar
Maryland, USA
Joined Mar 2006
Looks like another winner! Has all the qualities - Looks, Ease of Build, and Value.
My loss I know, I never got around to the BFU this past summer. Guess I now have two of yours on my list.
Cheers,
golem
golem is offline Find More Posts by golem
Next step after Corona RabelRouse Electric Heli Talk 14 Oct 19, 2004 08:04 AM
E-Tech 3s 1200 too big for Edge 540? mwarner57 3D Flying 3 Sep 10, 2004 07:46 PM
Question Aleron Trainer-next step after the s.s. BRIANRC Beginner Training Area (Aircraft-Electric) 10 Mar 11, 2004 10:01 AM
Next step after GWS Pico J3-F lowviz Parkflyers 4 Jun 10, 2001 02:25 AM
