Old Mar 28, 2007, 06:12 AM
Joined Aug 2004
Help!
optoglo with PCM
I have done a few of the C.Brent Dane's optogloII onboard glow drivers - and nice they are too
However, a friend has tried one of them with his futaba and says it will NOT work on his PCM receivers I have a ZPCM JR receiver, and that is fine on it, but is there an issue with trying to use these units with Futaba PCM ? IF so...what is the workaround guys ? TY
flybyday is offline Find More Posts by flybyday
Old Mar 28, 2007, 06:22 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi,
do not forget Futaba's Rx have a Low servo signal output voltage ... ( ~ 2v7 ). A level shifter might be needed. ( Already had these problems with Schmitt trigger inputs of Pics ÁP )
PCM has nothing to do with that kind of problems ... as the servo signals are the same shape, PCM or Not ...
Alain
Acetronics is offline Find More Posts by Acetronics
Old Mar 28, 2007, 06:57 AM
Joined Aug 2004
Hi Alain, so are the output signals lower on PCM futaba than on PPM futaba ? It works fine on his futaba ppm stuff
Old Mar 28, 2007, 07:20 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
I do not know if it is linked to PCM Rxs production ... but the Futaba's level problem is well known !!!
Here is an adapter scheme I did for a friend ...
Alain
Old Mar 28, 2007, 08:02 AM
Brentwood
Joined May 2005
I made one about 5 or 6 years ago and it was fine with Futaba PCM (129DP RX)
heliphil is online now Find More Posts by heliphil
Old Mar 28, 2007, 11:05 AM
Joined Aug 2004
Thats interesting....Anyhow, in the meantime I have a friend bringing me a futaba PCM set over tomorrow, and I am going to try it out.
Ace - thanks for the circuit, I read this ( not being very techie really ) as a simple 2 transistor amplifier Yes?
I take it that this would be inserted in the input lead to the optoglo, and boost the level to the circuit? sorry for being a bit thick
Old Mar 28, 2007, 12:05 PM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, Tim
You understood everything ... nothing to add !!!
Alain
Old Mar 29, 2007, 09:45 AM
Joined Aug 2004
Well, received the unit back today, and have tried it on a friends Futaba PCM receiver, and it does NOT work. The led flashes intermittently, but never goes out, or comes on "strong" unless of course I reverse the jumper, when everything stays the same, but at opposite ends of the throttle stick movement.
I am wondering whether having slightly deviated from the capacitor specs has affected the onbord signal generation enough to cause the problem ?
It works fine with all my JR stuff, PCM and PPM, as well as with my Spektrum 2.4Ghz set.
Capacitors called for are C1 = 0.056uf C2 = 0.010uf
I used C1 = 0.068uf ( 68nf) C2 = 0.01uf
Do you think this may be the problem ?
Old Mar 29, 2007, 10:28 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi,
1) did you see the little note about 74HC123 ... at the bottom of page 8 ???
2) if it works with one receiver, it might work with EVERY receiver ... respect to that input level problem ...
You could check datatasheet for your own HC132 ... may be truth here, in the
datas :
Philips HC132 shows, 6v supply, thresolds of 3.14v and 2.26 ..., 4.5v : 2.38 and 1.67 v
those are typical ... not so far from our critical 2.7v !!!
AND Won't work with 5 cells
Try the adapter ...
Alain
Old Mar 29, 2007, 12:30 PM
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
I was reading about the driver on RC_U just now. The original links to the docs is broken, so I only understand what was being discussed. I noted that they were using a gear channel for a function. IF this one also monitors the throttle channel, I think I know what's going on. Futaba (side note: a little girl at the field pronounces it Foo-Ta-Ba ) uses parallel timing of (I think) 4 channels at a time. That is, it sends out 4 channels at the same time (EDIT: Web says 2 channels - never question The Web ), then sends out the next 4. This is true ONLY on their PCM receivers in the PCM mode. If, for example, you need to 'read' the throttle channel AND read the aux (gear) channel, they might be presented at the same time. IF it's setup to read first one, then the next, this driver might get lost, unable to do both at the same time.
I ran into this problem with my Hamster, where I needed to read the rudder channel and read the aux channels. When they were presented at the same time, it messed up what I was expecting in the code and it failed.
Just thinking out loud - I've made a lot of assumptions about the driver. Still, note that Futaba dose pair channels to drive at the same time on a PCM system.
Gary Warner is offline Find More Posts by Gary Warner
Old Mar 29, 2007, 01:13 PM
Joined Aug 2004
Originally Posted by Acetronics
Hi,
datas :
Try the adapter ...
Alain
Hi Alain - yep noted the difference in capacitor spec if NOT using the HC123.
Mine are "genuine" labelled MM74HC123 AN
Old Mar 31, 2007, 04:32 AM
Joined Aug 2004
sorted !
Well after changing C1 from 47 nf to the original specified .056 it works.
I actually used 2 x in parallel, a 47 and a 10nf, as I didnt have any 0.056
Incidentally, math ( maths as we say in the UK ) was never my strong point, and decimal classes seemed to be held every time I was playing truant but please just confirm a couple of things for my brain regarding the very confusing world of capacitor markings and stuff......
0.010uf is effectively the same as 0.01uf or indeed .01uf , which is also 10nf
am I correct ? TYIA
Old Mar 31, 2007, 09:28 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi,
Surprising result ...
Might that mean there's a small difference in the signal repeating freq. ??? ( no sync. delay needed with PCM ... ) a look with a scope would confirm ...
Alain
Old Apr 21, 2007, 05:04 AM
Joined Aug 2004
more info and surprises !
Having got the unit to work at home with all my receivers, PCM and PPM, I sent it back to the guy. He claimed it would still not work
We then hit on the answer !! he was using a 5 cell receiver pack
when he used a 4 cell, all was fine. Seems like the unit does NOT like 5 cell packs ( apologies Alain...but just noticed you mentioned something about this in an earlier post )
As a fix...which seems to work, and allows useage on either 4 or 5 cell, I added a couple of small diodes in series with the the positive supply from the receiver output, just to drop the voltage slightly and it appears fine.
What do you guys think to this mod ?
Old Apr 21, 2007, 06:35 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, Tim
This mod is the other way to have it running ... I do so with a pair 1N400x when using PIC's ( max voltage is 5.5v !!! ) with 5 cells , and it works fine !!!
but you must short them if using 4 cells
you could also think to use a LM2940-5 reg. ( low drop ) or MIC 29150-5 ( Ultra low drop ) and it would work fine with both voltages ...
Alain
triton or Astro 109 charger with PCM-guard rcguy01 Batteries and Chargers 1 Feb 22, 2005 01:03 PM
FS Big Stik40 with PCM Radio-Ready to fly nhansemann Aircraft - Fuel - Airplanes (FS/W) 1 Aug 11, 2004 02:34 PM
Yippee! GP Pitts with PCM radio and Brison 2.4 Ulf Rieder Aircraft - Fuel - Airplanes (FS/W) 1 Jan 12, 2004 01:35 PM
Can I use a R1000DS Rx with PCM 10S? henke Electric Plane Talk 0 Nov 25, 2002 05:36 PM
