Old Mar 21, 2005, 12:48 PM
California
Joined Dec 2004
Actuator Help
can someone help me with this problem? I have 36 awg wire and i need to make a 30 ohm actuator, how many feet of wire should i use and how do i solve this problem?
anyoneelse is offline Find More Posts by anyoneelse
Old Mar 21, 2005, 01:36 PM
Coventry
Joined May 2004
Just done a quick search for you. look at the stuff I posted here.
http://www.rcgroups.com/forums/showthread.php?t=324779
None of it is mine, I'm not that good yet
davidcollins001 is offline Find More Posts by davidcollins001
Old Mar 21, 2005, 02:05 PM
California
Joined Dec 2004
cant really find anything that will help.
Old Mar 21, 2005, 02:21 PM
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
36 awg is a bit large, but measure out 30 feet or so and check the ohm reading. You should be able to do some math and figure it out from there. When I first started winding coils I just made one until it looked right and checked the resistance, keeping track of the number of turns, wire guage etc. It's good practice and shouldn't take you too many practice coils to zero in on your 30 ohms.
Dave
Dave Wulff is offline Find More Posts by Dave Wulff
Old Mar 21, 2005, 02:35 PM
California
Joined Dec 2004
do i measure the ohms by simply putting a voltmeter between the circuit with power going to the coil?
Old Mar 21, 2005, 02:48 PM
Inventor
conversion's Avatar
Sweden, Gothenburg
Joined Mar 2005
Hay Im no king at this ither.. but I tried my way.. my first atemt was 0.25mm coil-wire.. and that meassured about 3.3ohms.. big setback, but then I tried 0.12 and got 57ohms - try wind and siply meassure ohm between the two ends of your actuator
'peace.
conversion is offline Find More Posts by conversion
Old Mar 21, 2005, 03:07 PM
California
Joined Dec 2004
you got 57 ohms from 30 ft of .12mm wire, correct?
Old Mar 21, 2005, 03:23 PM
phil stevo's Avatar
Sydney
Joined May 2004
From the referred spreadsheet you need 22.65m of 36swg wire to make 30 ohms. It is way too big, 12mm OD for 4.5mm ID and 2.5g. Thats about 880 turns.
You need finer wire.Try old coils from fish tank bubbler, cheap clocks or wall timers.
phil stevo is offline Find More Posts by phil stevo
Old Mar 21, 2005, 03:31 PM
California
Joined Dec 2004
ok, thats what i thought. ill get some thinner wire. where did you find the information on turns and resistance of coils? and what are some good ways of getting the enamel off?
Old Mar 21, 2005, 03:42 PM
phil stevo's Avatar
Sydney
Joined May 2004
I've attached the spreadsheet again I think the link is in here somewhere but not sure where. You will need to unzip it. Credit to the author who I do not remember, he posted it here before.
I can get the enamel off with soldering flux and heat.
When using fine wire braid the tails so you have 5 or 6 strands twisted together. keep a couple of turns of each braid on the coil so you are much less likely to break the tails off.
Old Mar 21, 2005, 03:49 PM
Dave Wulff's Avatar
Joined Feb 2002
To measure resistance you need an ohm-meter, part of any multi-meter I have ever seen. $25 at RadioShack or what have you should do the trick. Do NOT have current in the wire when you measure it's resistance, or you will need to go get a new meter.
Dave
Old Mar 21, 2005, 04:07 PM
Tn
Joined Aug 2003
Hey anyoneelse....
I really like the way you come to my thread and hijack it by being a smart ass and then pretty much ask the same thing that I did.... ... Next time save your comments Jack ass..
Ben
Ben McCoy is online now Find More Posts by Ben McCoy
Old Mar 21, 2005, 04:17 PM
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
I can endorse Ben's comments but please keep it civil.
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Mar 21, 2005, 04:29 PM
Coventry
Joined May 2004
I didn't realise that the threads 'belonged' to anyone? I thought that it was best post/ask questions regardless of who started the thread to forward knowledge from the thread - granted this isn't the case but still!
Old Mar 21, 2005, 04:39 PM
Sticky Shepherd
Oxford/England
Joined May 2001
To nip this in the Bud:
Ben posted a thread asking about actuators, anyoneelse took it upon himself to be abusive to Ben for not searching and reading the index. This is why Ben is annoyed, when anyoneelse has done about the same. The problem was not hijacking.
Back on topic please
Help! Plantraco Actuator Help. Butters Scratchbuilt Indoor and Micro Models 31 Aug 16, 2007 03:40 PM
Discussion 18" linear actuator help boyntonstu Dock Talk 19 Apr 27, 2007 07:06 PM
micro actuator help FlyRC4Life Scratchbuilt Indoor and Micro Models 12 Jan 24, 2005 09:39 PM
Alert Actuator help!? Jbiker31691 Scratchbuilt Indoor and Micro Models 2 Sep 25, 2004 10:12 PM
Actuator Help CAFplanekid Scratchbuilt Indoor and Micro Models 6 Jul 06, 2003 05:44 PM
