Old Jan 03, 2014, 01:41 AM
United States, CA, Orange
Joined Aug 2013
Question
SPC voltage reading lower than actual pack voltage?
History, my A9 is around 7 months old, has the latest firmware as do all my receivers.
Been running my A9 on a lot of my models, most if not all run 3S lipos. As far as I could tell the SPC voltage displayed on the screen was spot on to the pack voltage in the aircraft.
Just built a Katana 50ep with a 5S setup, an Optima 7 receiver and noticed that the SPC voltage is reading a few points lower than the voltage as read by any of my volt meters.
For example, today I put a fresh pack that has only ever seen 5 charge cycles in my plane, and instead of reading 20.9v that the pack was at I was seeing 20.6v - 20.5v on the A9's screen. This is resting voltage with the BEC switched off, so the only load is a non spinning motor.
This isn't a huge issue, but I really don't want to have to guesstimate an offset when it comes to my low voltage alarm, and really don't have the time while flying 3D to glance at the screen and do quick math to figure out what voltage I am really at.
I guess I could swap receivers and see if that helps.
Any ideas?
icedomin8r is offline Find More Posts by icedomin8r
Old Jan 03, 2014, 04:08 AM
Joined Aug 2002
Any ideas?
"so the only load is a non spinning motor." = leads? also some switches incorporated with BEC units have
a residual current draw even when switched off, e.g. Turnigy 10A..
Your other tests should also be through same circuit so same parameters are included.
Then check the wire and solder to SPC port and yes, try another transceiver to ensure matter is repeated
Check the section on leads and pin sizes about half way down:
. After Market Accessories - Caution re Switches, Leads etc.
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS 2.4Ghz Module, Transceivers_Receivers & Telemetry,
- FAQ, Setups & Tips
Much more information available under sub sections
"ESC & BEC - Setup to prevent majority of all RF Problems, Brownouts & Crashes"
"Glitches & Jitter in Receiver, Servo & ESC - Causes and Cures"
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline Find More Posts by A.T.
Old Jan 07, 2014, 01:16 AM
Joined Aug 2013
FWIW, I swapped out another Optima 7 and sure enough the voltage reading was spot on.
Not sure if I should contact Hitec about this or not. I purchased the receivers back in July.
Discussion Wrong voltage reading with Graupner telemetry module zaguruinzasky Radios 3 Jan 27, 2014 08:53 AM
Sold Picture link in post SUPER LOWER PRICE *****less than 3 months old: Spektrum DX 7s TX crosby Aircraft - General - Radio Equipment (FS/W) 3 Oct 26, 2013 10:16 PM
Question CC Bec what are your actual voltage readings ? Spidious Castle Creations 9 Jul 15, 2008 07:27 AM
Voltage Running with 'Watts up', lower than LVC Nethole Power Systems 5 Mar 15, 2005 11:44 AM
Lowering voltage from battery pack for camera 5teve Power Systems 24 Jun 29, 2001 11:03 AM
