Old Jun 30, 2013, 08:36 PM
Registered DLG addict
NighthawkF-117's Avatar
Minnesota
Joined Jan 2009
AR6410 elevon setup
Hey guys,
I built a micro delta based on the spectrum AR6410 brick. When trying to program the radio I can't seem to be able to get the elevens functioning properly. With my dx7 in delta mode, the rudder stick moves what should be the elevator control (both servos moving in one direction) while the elevator controls what should be ailerons (servos in opposing directions). Any idea how to solve this problem?
Bill
NighthawkF-117 is offline Find More Posts by NighthawkF-117
Old Jul 01, 2013, 11:11 AM
Minnesota
Joined Jan 2009
Figured it out.
Enter these setting into your radio
Mix1: AILE->RUDD
RATE: L +65%, R +65%
Mix2: ELEV->RUDD
RATE: L -65%, R -65%
Turn Delta mixing on
Then play around with the Aile and Elve reversing until you get the right movement out of the servos.
Old Jul 01, 2013, 12:26 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Brick orientation is important with Delta setups, because the servo sides are fixed.
The DX6i and the DX7/DX8 require opposite servo sides for Delta, because the servo sides are different in the delta mix in the TX.
With a DX7, the Brick needs to mounted "upside down" or have the gear wheels facing aft.
The Easiest mix for the DX7 is to put TX in "delta" mode, then Aileron>Rudder Mix @ 100%, then have mix 1 be Rudder>Rudder -100/-100 to kill the rudder stick input.
The mix you have still has an active rudder stick.
UNGN is offline Find More Posts by UNGN
Discussion Rebuild of 1ch toy plane with AR6410 - Experience gbusker Electric Plane Talk 3 Jun 27, 2013 02:58 PM
For Sale AR6410 DSMX 6-Channel Ultra Micro Receiver/ESC twoplanekid Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 May 12, 2013 04:06 PM
Discussion AR6410 centering issue djhurlbut Scratchbuilt Indoor and Micro Models 9 Mar 10, 2013 12:44 AM
Question Maiden flight elevon setup: how? rhodesengr Flying Wings 10 Feb 08, 2013 07:11 PM
Sold Micro electronics Ar6410 + 2 servos PilotDragonfly Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jan 14, 2013 03:12 PM
