Old Mar 25, 2014, 07:47 AM
canvey island
Joined Jul 2002
Thanks, i just got to translate now and find out how to buy them.
steve bisco is offline Find More Posts by steve bisco
Old Mar 25, 2014, 08:10 AM
Crashing is a way of life, too
xs4reak's Avatar
Joined Nov 2010
I use these ones (because they fit)
https://www.hobbyking.com/hobbyking/...idProduct=7567
with
https://www.hobbyking.com/hobbyking/...idProduct=9727
Or use any battery you like (picture = 240mAh)
xs4reak is offline Find More Posts by xs4reak
Old Mar 25, 2014, 03:33 PM
United Kingdom, Walsall
Joined Mar 2013
Bit of slo-mo fun with the Mini Z
Kyosho Mini Z Moto GP "backing it in" (3 min 54 sec)
Syncro is online now Find More Posts by Syncro
Old Mar 25, 2014, 03:54 PM
canvey island
Joined Jul 2002
Nice Vid, I bought the soft high grip tires but it would not steer with the back wheel and spin up so easy, I now find best set up with soft front, and standard rear.
Old Mar 26, 2014, 04:24 AM
Nice
Joined Nov 2008
I use this one but need to cut the plastic head to fit and you can't close the bay battery because they are more long but 130 mah is a nice run.
https://www.hobbyking.com/hobbyking/...zone_Etc_.html
Helicoy is offline Find More Posts by Helicoy
Old Mar 27, 2014, 03:25 AM
Joined Jan 2010
i use an
Turnigy_nano_tech_160mah_1S_25_40C (https://www.hobbyking.com/hobbyking/...zone_Etc_.html)
with modifications on the bike, see...
https://picasaweb.google.com/noidl64/KyoshoMotoracer#
lg rene
vcfuzzi is offline Find More Posts by vcfuzzi
Old Mar 27, 2014, 04:06 AM
Nice
Joined Nov 2008
I think not too bad with lipo under the tank ,it not kill too much the look of the bike .
I think they are same size as 130 mah
Old Mar 27, 2014, 06:20 AM
xs4reak's Avatar
Joined Nov 2010
Unfortunately they are not.
Old Mar 27, 2014, 02:09 PM
Nice
Joined Nov 2008
In the Spec the 160 mah is just wider of 1mm than the 130 mah Nanotech
Old Mar 29, 2014, 04:00 PM
Bruce
Palmdale, CA
Joined Sep 2005
Originally Posted by steve bisco View Post
I am looking for cells for these bikes, The Kyosho ones are so expensive 15 my last one and are not very good, what you all using?
I have the Kyosho batteries for $12 (7.21) if that helps.
http://2wheelhobbies.com/product_inf...oducts_id=1613
Bruce
slawsonb is offline Find More Posts by slawsonb
Old Mar 30, 2014, 07:33 AM
canvey island
Joined Jul 2002
Bruce
Thanks Bruce, but I got some coming from Germany.
Old Mar 30, 2014, 08:32 AM
Joined Mar 2013
they don't look like the same for both side , one go down and one not the same angle .
With the bearing bar when i crash the bike seems to be more down and don't go up easily.
I fitted a set of the bearing sidebars and I've found them to be very good.
They're also exactly the same both sides.
I've been running the mini z on a carpet track and found the stock plastic balls wouldn't slide well across the carpet which sometimes made cornering unpredictable.
The bearing sidebars are much better on this surface as they're able to roll along the carpet.
Old Apr 02, 2014, 12:48 PM
Nice
Joined Nov 2008
Yes effectively it's good for cornering but for mine they don't look similar , one side the bike turn well and other side the bike come to down and made take bad corner , I will try to put more upside this bar bearing.
Sold QRF400 Dirt Bike R/c Motorcycle with gyro reddyrightnow Cars - Motorcycles (FS/W) 2 Mar 25, 2011 02:06 AM
Sold Anderson Racing M5 Race Bike RTR with Gyro reddyrightnow Cars - Motorcycles (FS/W) 0 Mar 22, 2011 07:18 PM
Sold Kyosho HOR bike & Spare Bike Plus New TIres and Gears. verticalpilot Cars - Motorcycles (FS/W) 4 Feb 04, 2009 10:23 PM
Kyosho EP Concept with zeal seesaw head duel mode gyro and for micro servos RTF littlepiston Aircraft - Electric - Helis (FS/W) 16 Sep 23, 2004 06:22 AM
