Old Feb 17, 2011, 11:12 AM
Speed Nut
Joined Jan 2010
I built a SP out of 1mm steel music wire.
I wrapped a thin copper wire at the solder points to help with soldering. It worked.
Now I have a cloverleaf on the tx and a SP on my trimersion rx.
It works so far very well with very clean video in the house, and I can go to different rooms (walls are made with bricks and cement ) with little or no disturbances.
MarcAntonio is offline Find More Posts by MarcAntonio
Old Feb 17, 2011, 12:09 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That's the exact setup I use! Same TX antenna, RX antenna and even goggles It works great. 1 mile is easy on a BoB 700mW. However somebody is doing 2 km on 10mW! I have no idea how.
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Feb 17, 2011, 12:16 PM
Speed Nut
Joined Jan 2010
-Alex
Oh, that's me doing 2km on 10mw (actually the trimersion tx is 12mw).
I have the luck of living on the mountains in south Italy (used to live in Virginia USA), and there is no wi-fi , the spectrum is pretty clean bar the cellular frequencies and umts 900-1800-1900-2100 mhz.
Where I fly from the top of the slope I can get huge range with not so great setups so my results don't really count and are not replicable near towns.
Old Feb 20, 2011, 03:43 AM
KF5LDN FPV Junkie!!!
Wizzard033's Avatar
United States, TX, Lubbock
Joined Nov 2009
OK so I read the thread and have decided this is the way to go. I'm just unsure how to get those very nice symmetrical bends? Any tips? I can make a nice jig for the antenna but I'm not sure what's the best way to get those.
Originally Posted by Derek_S View Post
I flew with the SPW and 3 turn Helix today. IMO I got very good results. I beat a personal record and hit 2 miles with ok video.
You said you were using 72Mhz?
Wizzard033 is offline Find More Posts by Wizzard033
Old Feb 20, 2011, 06:35 AM
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
IN that case I was using TLRS.
Derek_S is offline Find More Posts by Derek_S
Latest blog entry: Iconic X
Old Feb 20, 2011, 07:01 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I hand bend everything. I couldn't figure out how to make a jig for this one. I just used a measuring board. Everything else is done by hand.
-Alex
Old Feb 20, 2011, 10:55 PM
Wizzard033's Avatar
Joined Nov 2009
Cool, I have an idea to build a jig that might make this easier to build and could be adjusted and remade if necessary.
Old Feb 22, 2011, 05:06 PM
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
Originally Posted by Hugeone View Post
Found out my AIO goggle and 5.8tx from Foxtech use RP-sma, if anybody want my 5.8ghz pin-wheels just PM me.
-Hugo
They showed up in the post tonight Hugo. Merci beaucoup!
I just tried screwing them onto my RC305 and am sad to report that it looks like these SP antennas have the RP-SMA connectors, not your goggles & reciever.
I'll dig around for adapters so I can do initial ground tests and throw them on the FieldFox for antenna measurements. It may take a while before I can get to it because work is getting a bit nuts right now.
These are gorgeous pieces of tech sculpture but the axial symmetry is a bit wobbly, so I'm expecting the performance may be a bit off as well.
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Old Feb 22, 2011, 05:16 PM
Joined Mar 2010
Originally Posted by Dirt-Torpedo View Post
...I just tried screwing them onto my RC305 and am sad to report that it looks like these SP antennas have the RP-SMA connectors, not your goggles & reciever.
They are as you say, my mistake, as I say it's hectic at work and the pressure is getting to me. In either case I will get some adapters.
Thanks again.
Old Feb 23, 2011, 01:05 PM
Happy FPV pilot
lucianozan's Avatar
Italy
Joined Feb 2009
Following this tutorial I built an SPW for my 5.8Ghz 200mW kit and today I've tested it on my FPV EasyStar.
I did 3 tests...but the results with SPW are not very cool:
1 - standard whip antenna on VTX and VRX
2 - SPW on VRX and whip on VTX
3 - SPW on VTX and whip on VRX
On flight 1, without SPW, I reached 1.000m with some grain after 600m and some disturbance around 900-1000m but the visual was good
On flight 2 I reached 500m with a good image, probably better than flight 1, but after 500m I got a lot of disturbance and around 800m I had to come back as there were a lot of grain and disturbance
On flight 3 I was not able to get 500m and I had to came back very soon.
I know that my SPW is probably not perfect as geometry ...but building these 5.8Ghz antennas it's not so easy.
Next days I'll try with a Cloverleaf or a Vee on VTX and the SPW on VRX and see if I can get better results.
Any suggestion?
lucianozan is offline Find More Posts by lucianozan
Old Feb 23, 2011, 01:44 PM
Alberta, Canada
Joined Sep 2001
If you have the extra antenna try Skew Planar wheel (SPW) -> SPW or cloveleaf (CL) -> CL or SPW -> Cl or CL -> SPW and see if that helps.
Mikey-flies is offline Find More Posts by Mikey-flies
Old Feb 23, 2011, 01:49 PM
Speed Nut
Joined Jan 2010
Any suggestion?
Hello Luciano,
do you have a close-up of the solder job?
It looks like there might be a large gap between the ground and feed point.
Also your connector (ground) is touching the wires, effectively shortening those legs of the element, but without a close-up picture, it's hard to tell.
I would leave a few cm of antenna wire coming out of the connector so you can be precise with the soldering.
I had the same problem with the antenna directly soldered to the connector.
Old Feb 23, 2011, 02:25 PM
SW England
Joined Aug 2009
Having the antenna so close to surrounding metalwork of the VTx can 'block' or distort the radiation pattern from the S-P.
I made my 5.8GHz S-P at the end of a short piece of coax cable, which was recommended to me by the Canadian Radio Amateurs where I re-discovered the S-P antenna from.
They said it was better to keep the S-P at least one wavelength away from surrounding metal parts.
A S-P will always be 3db down on cross polarised antennas, that is to say, a S-P on the VTx and a whip on the VRx (or vice-versa).
The best CP performance will always be with a S-P on the VTx and either a S-P on the VRx or another CP antenna on the VRx, eg a CP helical beam.
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Feb 23, 2011, 08:10 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I find the cloverleaf (3 blade) is a bit easier at 5.8GHz. It performs just as well as the skew-planar wheel in my tests. You need to compensate for the added length given from the coaxial cable sticking out of the connector by shortening the lobes a bit.
-Alex
Old Feb 24, 2011, 12:33 AM
Happy FPV pilot
lucianozan's Avatar
Italy
Joined Feb 2009
Thank you for your comments and suggestions. I'll keep you informed about my next tests.
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 44 Jun 04, 2011 06:41 PM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
